hi every one
i have a problem with my 8.8 inch type-c monitor , my device only have a one type-c connect port ..when i connect to pc nothing to show and only black screen apears
but when on my phone show screen miroring on it and every things good (work)
i read all tapic and always have hdmi and adapator cable separate  and nothin for this only type-c topic to help me
when i use turzx and any software message apears not connect device test on win 10 and win 11
it seems need driver like usb-display or something else..
this is my 8.8 frome bewinner
https://www.amazon.de/Bewinner-Display-Monitor-Computer-Secondary/dp/B0CJCN7W32?ref_=ast_sto_dp&th=1&tag=operapc-def-sp-cos-de-21
can anyone help me to install and find driver for display ?
thnk
12 hours ago, ebi said:
hi every one
thnk
I think you need to connect to Aida64 as an LCD screen.  Go here and see if you can find an option that works with your display
The first step is to enable our external display in AIDA64 by selecting the device in File / Preferences / Hardware Monitoring / LCD.
thank u for help  i try this even more and nothing ..
the message is usb device not found 😔
i think we need driver pack first for device to install first correct and then for software
work perfectly with usb type - c on phone
and this is main board  of device 8.8 type-c pannel
anyone can help me to find driver for this ?
and aida64 can support this board ?
On 6/30/2024 at 5:17 PM, ebi said:
hi every one
thnk
As far as I can understand, this display should appear as a secondary monitor under Windows, and then you can put your AIDA64 SensorPanel on it.  In that case you don't need a USB device driver or any special tricks.  If it fails to appear as a secondary monitor in Windows, then most likely it's faulty and you should return it (RMA).
THNK U FOR REPLY
but with my dump usb it possible to know what  my display name or made factory ?
File / Preferences / Hardware Monitoring / LCD..??
No, since your display appears as an unknown USB device with zero (blank) device ID:
------[ Unknown Device]------
Device Description   : Unknown Device
Device ID            : 0000-0000
Device Class         : 00 / 00
Device Protocol      : 00
Revision             : 0000h
Supported USB Version: 0.00
Current Speed        : Low  (USB 1.1)
Revision             : 0000h
so my device not work at all ...
i can not return it 😪
On 7/8/2024 at 4:38 AM, beada said:
The device is a DisplayPort screen. Your graphics card or mainboard should have a USB Type C port with DisplayPort feature.  And then it will work as a secondary monitor as soon as you plugin it. You can refer to this page for more info-->https://www.displayport.org/displayport-over-usb-c/
thank you ..this is my mother board ROG STRIX Z690-A GAMING WIFI D4
https://rog.asus.com/motherboards/rog-strix/rog-strix-z690-a-gaming-wifi-d4-model/
is that support this feature ?
@ebi this monitor is not a USB device - it's a display. Like any other normal monitor.
It will only work when it's sent a video signal over the USB input - this is how you can see it working on your phone.
It's not going to work from your ASUS Motherboard because that board does not have a USB C video output. It only has an HDMI Port and a DisplayPort.
You'll need to use one of these - https://www.amazon.com/WJESOG-DisplayPort-Adapter-Converter-Support/dp/B0BNX7MS6N/ - to convert your DisplayPort video output, into a USB C video output.
See - https://dancharblog.wordpress.com/2020/05/10/bi-directional-usbc-dp-cables/ - for more information.
Alternatively, you can buy a Graphics Card that has a USB C output, like this one - https://www.newegg.com/powercolor-radeon-rx-7900-xt-rx7900xt-20gb/p/N82E16814131813R
@NOM  Thank u for reply
yes this is possible and i think about to bought this cable
but one question any 8.8 inch screen like wownova and smart turing can work without cable and need only 1 type-c cable or normal cable type -a ...only my device have a this problem ?
