Hi I'm hoping someone could shed some light on why my i7 3770k @ 4.5 is only scoring 12,024 on the CPU AES test.
All other tests are way above a stock clocked i7 3770k which fall in line with the high overclock. I have tried everything I can't put my finger on what's causing it. Any suggestions are very appreciated.
1) What version of AIDA64 are you using?
2) Are you sure your CPU isn't throttling (slowing itself down) while running the benchmarks, due to overheating?
I'm using version 3.00.2500. I am getting under 10000 stock settings and only 12024 overclocked to 4.5. It's just kinda weird that all the other scores are right where I expect them to be in every memory test, queen, vp8 they all are top notch. Just AES test is not showing the right score.
I just did a bios reset and using the Auto Turbo 4.0 setting and my memory overclocked from 1600 to 2000. Here is the scores I got
Memory Read = 29728
Memory Write = 30505
Memory Copy = 27801
Memory Latency = 55.4
Queen = 50505
Photoworxx = 16198
Zlib = 344.5
AES = 10717
Hash = 2999
Vp8 = 6385
Julia = 21091
Manedel = 11180
SinJulia = 5382
Temps on cores were as follows 70/66/67/67
I'm using a Coolermaster 212 + even on the most demanding benchmarks I've never seen Temps go over 85 when overclocked to 4.5. I really appreciate any help it's not a huge problem just looked funny seeing it so low when the chip runs flawless otherwise. Thanks for all your help and guidance.
Quite frankly, we've never seen such anomaly.  All benchmark scores seem to be in line with the expected performance from an oveclocked 3770K, except for the AES score.  If possible, please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump.  Copy-paste the full results into this topic.  That data will hopefully reveal something about your CPU that could explain the AES anomaly.
I really appreciate you trying to help with this weird scenario here is the info you requested from the CPID & MSR Dump
Program Version : AIDA64 v3.00.2500
BenchDLL Version: 4.0.568-x64
------[ CPU Info ]------
CPU Type           : QuadCore Intel Core i7-3770K, 4200 MHz (42 x 100)
CPU Alias          : Ivy Bridge-DT
CPU Platform       : LGA1155
CPU Stepping       : E1/L1/N0/P0
Instruction Set    : x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AES, AVX
CPUID Manufacturer : GenuineIntel
CPUID CPU Name     : Intel® Core i7-3770K CPU @ 3.50GHz
CPUID Revision     : 000306A9h
IA Brand ID        : 00h  (Unknown)
Platform ID        : 32h  (LGA1155)
HTT / CMP Units    : 2 / 4
Tjmax Temperature  : 105 Celsius
Max. NUMA Node     : 0
------[ Logical CPU #0 ]------
allcpu: Package 0 / Core 0 / Thread 0: Valid
CPUID 00000000: 0000000D-756E6547-6C65746E-49656E69 [GenuineIntel]
CPUID 00000001: 000306A9-00100800-7F9AE3BF-BFEBFBFF
CPUID 00000002: 76035A01-00F0B2FF-00000000-00CA0000
CPUID 00000003: 00000000-00000000-00000000-00000000
CPUID 00000004: 1C004121-01C0003F-0000003F-00000000
CPUID 00000004: 1C004122-01C0003F-0000003F-00000000
CPUID 00000004: 1C004143-01C0003F-000001FF-00000000
CPUID 00000004: 1C03C163-03C0003F-00001FFF-00000006
CPUID 00000005: 00000040-00000040-00000003-00001120
CPUID 00000006: 00000077-00000002-00000009-00000000
CPUID 00000007: 00000000-00000281-00000000-00000000
CPUID 00000008: 00000000-00000000-00000000-00000000
CPUID 00000009: 00000000-00000000-00000000-00000000
CPUID 0000000A: 07300403-00000000-00000000-00000603
CPUID 0000000B: 00000001-00000002-00000100-00000000
CPUID 0000000B: 00000004-00000008-00000201-00000000
CPUID 0000000C: 00000000-00000000-00000000-00000000
CPUID 0000000D: 00000007-00000340-00000340-00000000
CPUID 0000000D: 00000100-00000240-00000000-00000000
CPUID 80000000: 80000008-00000000-00000000-00000000
CPUID 80000001: 00000000-00000000-00000001-28100000
CPUID 80000002: 20202020-49202020-6C65746E-20295228 [       Intel® ]
CPUID 80000003: 65726F43-294D5428-2D376920-30373733 [Core i7-3770]
CPUID 80000004: 5043204B-20402055-30352E33-007A4847 [K CPU @ 3.50GHz]
CPUID 80000005: 00000000-00000000-00000000-00000000
CPUID 80000006: 00000000-00000000-01006040-00000000
CPUID 80000007: 00000000-00000000-00000000-00000100
CPUID 80000008: 00003024-00000000-00000000-00000000
L1    Data Cache:     32 KB,  8-way Associative, 64-byte Line
L1  Instr. Cache:     32 KB,  8-way Associative, 64-byte Line
L2 Unified Cache:    256 KB,  8-way Associative, 64-byte Line
L3 Unified Cache:   8192 KB, 16-way Associative, 64-byte Line
------[ Logical CPU #1 ]------
allcpu: Package 0 / Core 0 / Thread 1: Valid, Virtual
CPUID 00000001: 000306A9-01100800-7F9AE3BF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000001
CPUID 0000000B: 00000004-00000008-00000201-00000001
------[ Logical CPU #2 ]------
allcpu: Package 0 / Core 1 / Thread 0: Valid
CPUID 00000001: 000306A9-02100800-7F9AE3BF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000002
CPUID 0000000B: 00000004-00000008-00000201-00000002
------[ Logical CPU #3 ]------
allcpu: Package 0 / Core 1 / Thread 1: Valid, Virtual
CPUID 00000001: 000306A9-03100800-7F9AE3BF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000003
CPUID 0000000B: 00000004-00000008-00000201-00000003
------[ Logical CPU #4 ]------
allcpu: Package 0 / Core 2 / Thread 0: Valid
CPUID 00000001: 000306A9-04100800-7F9AE3BF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000004
CPUID 0000000B: 00000004-00000008-00000201-00000004
------[ Logical CPU #5 ]------
allcpu: Package 0 / Core 2 / Thread 1: Valid, Virtual
CPUID 00000001: 000306A9-05100800-7F9AE3BF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000005
CPUID 0000000B: 00000004-00000008-00000201-00000005
------[ Logical CPU #6 ]------
allcpu: Package 0 / Core 3 / Thread 0: Valid
CPUID 00000001: 000306A9-06100800-7F9AE3BF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000006
CPUID 0000000B: 00000004-00000008-00000201-00000006
------[ Logical CPU #7 ]------
allcpu: Package 0 / Core 3 / Thread 1: Valid, Virtual
CPUID 00000001: 000306A9-07100800-7F9AE3BF-BFEBFBFF
CPUID 0000000B: 00000001-00000002-00000100-00000007
CPUID 0000000B: 00000004-00000008-00000201-00000007
------[ All CPUs ]------
CPU   0: APICID   0 / Package 0 / Core  0 / Thread 0: Valid
CPU   1: APICID   1 / Package 0 / Core  0 / Thread 1: Valid, Virtual
CPU   2: APICID   2 / Package 0 / Core  1 / Thread 0: Valid
CPU   3: APICID   3 / Package 0 / Core  1 / Thread 1: Valid, Virtual
CPU   4: APICID   4 / Package 0 / Core  2 / Thread 0: Valid
CPU   5: APICID   5 / Package 0 / Core  2 / Thread 1: Valid, Virtual
CPU   6: APICID   6 / Package 0 / Core  3 / Thread 0: Valid
CPU   7: APICID   7 / Package 0 / Core  3 / Thread 1: Valid, Virtual
------[ MSR Registers ]------
MSR 00000017: 0004-0000-0000-0000 [PlatID = 1]
MSR 0000001B: 0000-0000-FEE0-0900
MSR 00000035: 0000-0000-0004-0008
MSR 0000008B: 0000-0015-0000-0000
MSR 000000CE: 0008-1010-F001-2300
MSR 000000E7: 0000-0000-0016-B204
MSR 000000E8: 0000-0000-001B-550F
MSR 00000194: 0000-0000-000F-0000
MSR 00000198: 0000-28FE-0000-2A00
MSR 00000199: 0000-0000-0000-FF00
MSR 0000019A: 0000-0000-0000-0000
MSR 0000019B: 0000-0000-0000-0010
MSR 0000019C: 0000-0000-8841-0000
MSR 0000019D: 0000-0000-0000-0000
MSR 000001A0: 0000-0000-0085-0089
MSR 000001A2: 0000-0000-0069-1400
MSR 000001A4: 0000-0000-0000-0000
MSR 000001AA: 0000-0000-0040-0000
MSR 000001AC: < FAILED >
MSR 000001AD: 0000-0000-2A2A-2A2A
MSR 000001B0: 0000-0000-0000-0000
MSR 000001B1: 0000-0000-883D-0000
MSR 000001B2: 0000-0000-0000-0000
MSR 000001FC: 0000-0000-0014-005F
MSR 00000300: < FAILED >
MSR 00000480: 00DA-0400-0000-0010
MSR 00000481: 0000-007F-0000-0016
MSR 00000482: FFF9-FFFE-0401-E172
MSR 00000483: 007F-FFFF-0003-6DFF
MSR 00000484: 0000-FFFF-0000-11FF
MSR 00000485: 0000-0000-1004-01E5
MSR 00000486: 0000-0000-8000-0021
MSR 00000487: 0000-0000-FFFF-FFFF
MSR 00000488: 0000-0000-0000-2000
MSR 00000489: 0000-0000-0017-27FF
MSR 0000048A: 0000-0000-0000-002A
MSR 0000048B: 0000-08FF-0000-0000
MSR 0000048C: 0000-0F01-0611-4141
MSR 0000048D: 0000-007F-0000-0016
MSR 0000048E: FFF9-FFFE-0400-6172
MSR 0000048F: 007F-FFFF-0003-6DFB
MSR 00000490: 0000-FFFF-0000-11FB
MSR 00000601: 1814-1494-0000-04B0
MSR 00000602: 1814-1494-0000-0170
MSR 00000603: 0000-0000-802C-2C2C
MSR 00000604: 0000-0000-8068-6868
MSR 00000606: 0000-0000-000A-1003
MSR 0000060A: 0000-0000-0000-883B
MSR 0000060B: 0000-0000-0000-8850
MSR 0000060C: 0000-0000-0000-8857
MSR 0000060D: 0000-0000-0000-0000
MSR 00000610: 0000-8FA0-0014-8FA0
MSR 00000611: 0000-0000-23B5-E184
MSR 00000613: < FAILED >
MSR 00000614: 0000-0000-01E0-0268
MSR 00000618: < FAILED >
MSR 00000619: < FAILED >
MSR 0000061B: < FAILED >
MSR 0000061C: < FAILED >
MSR 00000638: 0000-0000-0000-0000
MSR 00000639: 0000-0000-0D64-9F23
MSR 0000063A: 0000-0000-0000-0000
MSR 0000063B: < FAILED >
MSR 00000640: 0000-0000-0000-0000
MSR 00000641: 0000-0000-0001-39B6
MSR 00000642: 0000-0000-0000-0008
MSR 00000648: 0000-0000-0000-0023
MSR 00000649: 01E0-0000-0000-0000
MSR 0000064A: 01E0-0000-0000-0000
MSR 0000064B: 0000-0000-8000-0000
MSR 0000064C: 0000-0000-0000-0000
PerformanceFrequency = 3418027
CPU Clock M.Method = 8  (APIC SNB)
PM Timer Address   = 1032  (0408h)
APIC Clock = 100.00 MHz
APIC Clock = 100.01 MHz
  • 3 weeks later...
Thank you for the data.  I'm afraid we haven't found anything unusual in it.  Can you please try running the benchmarks using AIDA64 v3.20 (latest version) at both stock (default) clock speeds, and also at overclocked speed, and post both results?
Hey guys, I was having the same issue with low benchmark scores. for me disabling intel virtualization technology in the bios increased  my results from 13500MB/s to 19500MB/s. this is on MSI Z87-G45 and i7 4770k @4.2GHz.
thought it was strange myself but I can reproduce the results by enabling/disabling virtualization in bios.
1) Which exact option in the BIOS Setup did you alter?
2) Do you mean the CPU AES scores?
3) Did you use AIDA64 v3.20.2600?
4) What version of BIOS do you have for your motherboard?
Intel Virtualization technology feature, set to disabled. was enabled by default and since I don't plan to run VM ware I disabled it.
Yes after many hours overclocking AES scores where always lower than Intel core i7 2600k, after I disabled Intel virtualization Technology in bios the scores increased.
Yes.
Many versions over the last month v1.20, v1.30, v1.40, v1.50, and currently v1.61 beta.
My CPU @ 4.2GHz with intel virtualization enabled AES scores where 13500 MB/s, with intel virtualization disabled the AES scores are 19000+ MB/s
  • 5 years later...
Bringing this old thread from the grave, but it did resolve my issue 5 years laters, on an overclocked i7- 8700K and very LOW CPU AES.
The tests would result in 21000MB/s, with Intel Virtualization Technology enabled. Once that was disabled in BIOS, test results jumped 33000MB/s.
Thank you!
MB - Asrock Z370 Gaming K6 (3.20)
Thank you!
1) Are you running Windows 10 64-bit with all the latest updates installed?
2) Do you use AIDA64 v5.99? (latest version)
3) Is your CPU overclocked?
  • 1 year later...
Same problem. Aida64 Cache&Memory Benchmark shows low results for ram, l2 and l3 caches. This happens for overclocked CPU with virtualization enabled. For non-overclocked CPU everything is ok.
I7 8700k + msi z370 gaming pro carbon, last bios AB.
Aida64 v6.25.5400
Aida64 v6.25.5400
Please post a screenshot of the Cache & Memory Benchmark panel of AIDA64 so we can check all scores.  Also make sure to use the latest AIDA64 version of 6.30.5500.
  • 2 months later...
Here are screenshots for OC+xmp and Stock+xmp. As you can see Stock results is much better then overclocked. After disabling virtualization in Bios, everything starts work how it should and OC result is better then stock. So the problem in Virtualization technology (or judging other topics maybe the problem is in Windows sandbox feature since it uses Virtualization, but I already disabled Virtualization in Bios and don't want to restart PC just for checking this theory).
That indeed looks quite weird.  But, in case it works without virtualization, our conclusion is that the anomaly is caused by virtualization and not due to an issue about our benchmarks.
