Hey
it is possible the individual processes in the sensor panel display?
Thus, just as one sees in the Task Manager, it need not be so detailed, yes.
But I guess that does not work right?
Currently it's not supported in AIDA64.  For each process running, what property (or properties) would you like to see on the SensorPanel?  CPU utilization?  Memory utilization?  Handles count?  Threads count?  Something else than those?
