VDDIO voltage incorrect for Ryzen 7000 series?
My ASUS B650E-E Gaming WiFi shows a "CPU VDDIO / MC Voltage" of 1.424V in BIOS > Monitoring section.
In AIDA64 v7.35.7024 Beta (and earlier), a single "VDDIO" voltage value of 0.712V is shown under Computer > Sensor - Voltage values.
The VDDIO value reported by AIDA64 is exactly half of the VDDIO value in BIOS, which I don't think to be a coincidence (but I could be very wrong though).
So my question is: what exactly is "VDDIO" voltage supposed to represent in AIDA64?
BTW I was actually searching for a way to display memory and memory controller voltage values in AIDA64. This seems to be my best bet though.
Attached both BIOS & AIDA64 pics for reference.
EDIT 1: Just confirmed my alleged assumption on this 'VDDIO - halved voltage' issue by disabling EXPO in BIOS: "CPU VDDIO / MC Voltage", which gives 1.100V in BIOS, but which results in a "VDDIO" voltage output of just ~0.560V in AIDA64.
EDIT 2: It seems that "VDD Misc" voltage is also being misreported in AIDA64. It shows 0.552-0.560V in AIDA64, but is reported as 1.100V in BIOS (same value for EXPO ON or OFF btw).
As a workaround, I decided to add two Correction Items for VDDIO and VDD Misc by using a 2:1 ratio on both.
This shows perfect results (in my book):
Notes:
- Purely cosmetic: Renamed (default) "VDDIO" to "VDDIO / MC" to be in-line with (ASUS) BIOS voltage monitor tab.
- VDD Misc is fluctuating between 1.104~1.120V, which corresponds with (ASUS) BIOS readings for VDD Misc.
- EDIT: Also lowered SoC Voltage from 1.22 to 1.20 in between screenshots btw.
