Is it possible to integrate the Water Flow 3 pin sensor (W_FLOW) from the "Asus ROG Crosshair X670E Hero" into AIDA64 ?
Before the "Crosshair X670E Hero" i had the "Asus Rampage Vi Extreme" and it had exactly the same W_FLOW 3 pin sensor header and it worked in AIDA64 from the beginning till the end perfectly.
I checked if something is wrong with the sensor by itself, but there is no issues from that side. He is showing the Water Flow in BIOS and in HWINFO too. I made a picture from HWINFO to show that it is working and something is wrong with AIDA64. I made a picture of the x670e hero Mainboard 3pin W_FLOW header, maybe its needed. The W_PUMP+ header left and the 2 temp header W_OUT and W_IN on the right from the W_FLOW header are shown in AIDA64 and working as intended.
I would be very happy if this problem could be solved because AIDA64 is really a very good and reliable background program to read out internal values and ads in the OSD panel.
In AIDA64 please press Ctrl+D --> Sensor Debug --> Embedded Controller Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
  • 5 weeks later...
Here the Embedded Controller Dump from my Aida64. Thank you for your help @Fieryecdump.txt
