Hello,
I recently purchased an ROG Matrix 5090. However, with this specific graphics card I’m unable to view the power connect pin monitoring while HWinfo does allow me to see it. I would like to add the per pin power monitoring on my sensor panel.
I’m attaching the NVIDIA SMBus Dump and nvidiagpureg files.
nvidiagpureg.txt nvidiasmbusdump.txt
On 5/18/2026 at 8:09 PM, Meldie said:
Hello,
nvidiagpureg.txt 4.35 kB · 0 downloads nvidiasmbusdump.txt 11.95 kB · 1 download
Let me know how it works.
On 5/23/2026 at 11:45 PM, Meldie said:
Thanks! , this work now 🫡
Thank you for your feedback!
