AIDA64 not showing correct temps (Asus P7P55-M)
Fyew-jit-tiv
Hi Fierry,
I just installed Aida64 on my Home server (Asus P7P55-M Running win7 64bits & i3-550) and i just noticed the CPU temp & CPU FAN RPM isn't showing correctly. In the screen shot provided you will see the core temps @ around 36c but the CPU temp is at 43c which is incorrect. Core temps are OK (compared with HWmonitor & Coretemp)but the CPU temp is much higher than the core temps. Also the CPU fan rpm is showing at 479rpm but should be around 1900rpm. Can you confirm that this may well be a bug within Aida64.?
Thanks
P.S I am running the latest Version of Aida v1.50.1212
Hi Fiery,
So i have installed ProbeII. Adia64 CPU temp matches ProbeII. What i find strange thou is (and correct me if I'm wrong)the core temps should be higher than the overall CPU temp? On my main Comp this is most certainly the case. ProbeII is on the other hand showing the correct CPU Fan RPM Speed whilst Aida is not. There seems to be 1000rpm's missing from Aida's readings. Screen shot inc. Compare with screen shot in OP.
Thanks.
1) Core temperatures are measured by the CPU itself, using Intel DTS. "CPU" temperature is measured by the motherboard, using the sensor chip mounted on your motherboard. Due to the fundamental difference on measuring methodology, it's not advised to compare core temperatures and "CPU" temperature.
2) As for the fan RPMs, please copy-paste the results of the following dumps and info into this topic:
- Computer / Sensor page
- right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump
Hi Fiery,
Here is a strange one, under Aida64 stress test ProbeII shows -55 on the mobo temp sensor and Aida doesn't (Screen shot inc), This is why i don't use ProbeII as it is so not accurate. Another thing to note is whilst under stress testing my core temps will go up to 60c+ but the CPU temps only goes up to 49c, normally it would idle @ around 44c which cant be right. Going to do this dump and post back in 5.
Thanks
Hi Fiery,
As requested here is the sensordump. As you can see this is showing the correct CPU RPM, But else where in Aida64 is doesn't.
Thanks
------[ AIDA64 v1.50.1212 Beta ]------
------[ Microsoft Windows 7 Home Premium 6.1.7600 (64-bit) ]------
Motherboard ID : 65-0903-000001-00101111-070910-P55$A1482001_BIOS DATE: 07/09/10 10:30:04 VER: 08.00.15
Motherboard Model : Asus P7P55-M
Motherboard Chipset : Intel Ibex Peak P55, Intel Ironlake
DMI MB Manufacturer : ASUSTeK Computer INC.
DMI MB Product : P7P55-M
DMI MB Version : Rev X.0x
DMI MB Serial : MT7006K29700217
DMI SYS Product : System Product Name
DMI SYS Version : System Version
DMI SYS Serial : System Serial Number
DMI BIOS Version : 0903
ITE 87xx Port = 00h
ITE 87xx Device ID = 0000h
ITE 87xx Version = 00h
Winbond SuperIO Port = 2Eh
Winbond SuperIO HWMonitor Port = 0290h
Winbond SuperIO Device ID = B353h
Winbond Sensor ID A3/5C/reg$58 = A3 / 5C / C1
Fintek SuperIO Port = 00h
Fintek SuperIO Device ID = 0000h
LPC47 SuperIO Device ID = FFFFh
------[ LM78 ISA Sensor Device at 0290 ]------
0000 04 FF 04 56 10 3C 32 22 9B 80 01 01 3C 3C 04 04
0010 04 FF 30 00 00 01 01 3C 53 27 00 00 27 FF FF CA
0020 99 DB D0 D0 D5 FF 26 C9 58 7A FF DA 00 99 9F F4
0030 E3 4B 56 EA F3 EE FA 1C 4B D4 53 90 05 9F 89 FF
0040 01 10 10 FF DF 00 3F F3 2D 21 00 C0 88 95 00 A3
0050 FF FF 00 FF FF FF 00 80 C1 9F FF FF 01 82 00 05
0060 FF FF 40 FF FF FF FF FF 0A FF 01 FF 01 FF FF FF
0070 04 04 0A 0A 00 64 4B 64 FF FF FF 1F 00 00 C9 00
0080 04 FF 04 56 10 3C 32 22 9B 80 01 01 3C 3C 04 04
0090 04 FF 30 00 00 01 01 3C 53 27 00 00 27 FF FF CA
00A0 99 DB D0 D0 D5 FF 26 C9 58 7A FF DA 00 99 9F F4
00B0 E3 4B 56 EA F3 EE FA 1C 4B D4 53 90 05 9F 89 FF
00C0 01 00 10 FF DF 00 3F F3 2D 21 00 C0 88 95 00 A3
00D0 FF FF 00 FF FF FF 00 80 C1 9F FF FF 01 82 00 05
00E0 FF FF 40 FF FF FF FF FF 0A FF 01 FF 01 FF FF FF
00F0 04 04 0A 0A 00 64 4B 64 FF FF FF 1F 00 00 C9 00
Bnk0 FF FF 00 FF FF FF 00 80 C1 9F FF FF 01 82 00 05
Bnk1 2C 00 00 4B 00 50 00 EA FF FF FF FF FF FF FF FF
Bnk2 4E 00 02 7D 00 7F 1E 54 FF FF FF FF FF FF FF FF
Bnk3 06 06 06 06 01 07 03 03 07 00 00 C0 63 01 00 00
Bnk4 39 13 FF 00 00 07 00 22 69 8E 1D B9 09 5F 20 FF
Bnk5 D5 72 03 FF 30 B1 74 65 B5 96 00 00 E4 00 00 00
Bnk6 7F 7F 7F 7F 7F 7F 07 7D 01 32 00 00 00 00 00 00
Reg$20 CPU Core: r = 153, r*0.016 = 2.45
Reg$21 CPU Aux: r = 219, r*0.016 = 3.50
Reg$22 +3.3 V: r = 208, r*0.016 = 3.33
Reg$23 +5 V: r = 208, r*0.016 = 3.33
Reg$24 +12 V: r = 213, r*0.016 = 3.41
Reg$25 -12 V: r = 255, r*0.016 = 4.08
Reg$26 -5 V: r = 38, r*0.016 = 0.61
_TZ_.THM0._TMP :
_TZ_.THM1._TMP :
_TZ_.THR0._TMP :
_TZ_.THR1._TMP :
_TZ_.TZ00._TMP :
_TZ_.TZ01._TMP :
_TZ_.RTMP :
_TZ_.RFAN :
_TZ_.RFAN(0) :
_TZ_.RFAN(1) :
_SB_.ATKD._HID :
_SB_.ATKD.TMPR :
_SB_.PCI0.LPC0.EC0_.CCTV :
_SB_.PCI0.LPC0.EC0_.LRPM :
_SB_.PCI0.LPC0.EC0_.HRPM :
_SB_.PCI0.SBRG.EC0_.ECPU :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0 :
_SB_.PCI0.SBRG.EC0_.TAH1 :
_SB_.PCI0.SBRG.EC0_.ST00 :
_SB_.PCI0.SBRG.EC0_.SC01 :
_SB_.PCI0.SBRG.EC0_.SC02 :
_SB_.PCI0.SBRG.EC0_.SC03 :
_SB_.PCI0.SBRG.EC0_.SC04 :
_SB_.PCI0.SBRG.EC0_.SC05 :
_SB_.PCI0.SBRG.EC0_.SC06 :
_SB_.PCI0.PIB_.EC0_.TCRT :
_SB_.PCI0.SBRG.EC0_.CTPM :
_SB_.PCI0.SBRG.EC__.CPUT :
_SB_.PCI0.SBRG.EC__.SYST :
_SB_.PCI0.LPC_.EC0_.CTMP :
_SB_.PCI0.LPCB.EC0_.CTMP :
_SB_.PCI0.LPC_.EC0_.TMP1 :
_SB_.PCI0.LPC_.EC0_.TMP2 :
_SB_.PCI0.LPC_.EC0_.TMPI :
_SB_.PCI0.LPC_.EC0_.TMPV :
_SB_.PCI0.LPCB.EC0_.A1TP :
_SB_.PCI0.LPCB.EC0_.A2TP :
_SB_.PCI0.LPCB.EC0_.FAN0 :
_SB_.PCI0.LPCB.EC__.TS1R :
_SB_.PCI0.LPCB.EC__.TS2R :
_SB_.PCI0.LPCB.EC__.TS3R :
_SB_.PCI0.LPCB.EC__.F1FL :
_SB_.PCI0.LPCB.EC__.F1FH :
_SB_.PCI0.LPCB.EC__.F2FL :
_SB_.PCI0.LPCB.EC__.F2FH :
_SB_.PCI0.LPC_.H8EC.RTMP :
_SB_.PCI0.LPC_.H8EC.LTMP :
_SB_.PCI0.LPC_.H8EC.MTMP :
_SB_.PCI0.LPC_.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.CTMP :
_SB_.PCI0.LPCB.H8EC.DTMP :
_SB_.PCI0.LPCB.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.ITMP :
_SB_.PCI0.LPCB.H8EC.MTMP :
_SB_.PCI0.LPCB.H8EC.STMP :
_SB_.PCI0.LPCB.H8EC.PFAN :
------[ Asus ATK0110 ]------
Motherboard ID: P7P55-M
ICPU/VCPU/PCPU: 780 / 0 / 15912
CPU Temperature : 44.0 C
MB Temperature : 42949667.4 C
CHASSIS1 FAN Speed: 1917 RPM
CPU FAN Speed : 1383 RPM
+12 Voltage : 12.264 V
+3.3 Voltage : 3.328 V
+5 Voltage : 5.112 V
Vcore Voltage : 1.224 V
Chassis1 Fan Speed: 1917 RPM
CPU Fan Speed : 1383 RPM
+12V Voltage : 12.264 V
+3.3V Voltage : 3.328 V
+5V Voltage : 5.112 V
CPU Over Voltage : 0.030 V
CPU PLL : 1.800 V
DRAM Bus Voltage : 1.650 V
IMC Voltage : 1.100 V
PCH : 1.050 V
BCLK Frequency : 133.00 MHz
CPU rated ratio : 24x
CPU Ratio : 24x
So here we can see the correct CPU RPM
Thank you for the dumps. We've tweaked a bit around the fan RPM measurement on Asus H55 and P55 boards. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at:
http://www.aida64.com/downloads/aida64extremebuild1219sdk6ngm0yczip
Let me know how it works.
Hi Fiery,
I can now confirm that the problem with CPU RPM has been fixed with build 1219.
I'm now re-install OS on P6X58D Comp and will let you know by the end of today if that makes any difference to the update freq
Thanks.
Thanks.
