DefultNaem Posted May 12, 2025 Posted May 12, 2025 Hi, For some reason my Aida installation doesn't have permission to edit the installation location, which means that it's saving the aida64.ini config file in AppData/Local. I currently have it installed on a usb to make it easier to use on multiple computers but at the moment I have to set all the settings manually on each device. How do I change this so the preferences get saved on the USB with the .exe? Any help would be appreciated. Quote
Fiery Posted May 12, 2025 Posted May 12, 2025 7 hours ago, DefultNaem said: Hi, For some reason my Aida installation doesn't have permission to edit the installation location, which means that it's saving the aida64.ini config file in AppData/Local. I currently have it installed on a usb to make it easier to use on multiple computers but at the moment I have to set all the settings manually on each device. How do I change this so the preferences get saved on the USB with the .exe? Any help would be appreciated. If you start AIDA64 from your USB flash drive, it will save the settings file (AIDA64.INI) to the USB drive. Just make sure to use the portable ZIP package of AIDA64, or simply copy the installed files (including your existing AIDA64.INI file from there or from AppData/Local) to you USB drive. Quote
DefultNaem Posted May 14, 2025 Author Posted May 14, 2025 On 5/12/2025 at 8:11 PM, Fiery said: If you start AIDA64 from your USB flash drive, it will save the settings file (AIDA64.INI) to the USB drive. Just make sure to use the portable ZIP package of AIDA64, or simply copy the installed files (including your existing AIDA64.INI file from there or from AppData/Local) to you USB drive. ok, perfect, thank you, I'll give that a try! Quote
