790 Posted July 25 Posted July 25 I have 4 Zalman fans with problem sensors. This works correctly only before a speed of 90%, but it works incorrectly at a speed of 95-100%. Their speed cannot be more than 950 RPM at 100%, but their sensors at 95-100% can show any value ... 1000, 1900 ... 38000, etc. This is not AIDA problem, this values in BIOS too. Is it possible to make a limit on the show of these values in 950 RPM? Quote
Fiery Posted July 25 Posted July 25 8 hours ago, 790 said: I have 4 Zalman fans with problem sensors. This works correctly only before a speed of 90%, but it works incorrectly at a speed of 95-100%. Their speed cannot be more than 950 RPM at 100%, but their sensors at 95-100% can show any value ... 1000, 1900 ... 38000, etc. This is not AIDA problem, this values in BIOS too. Is it possible to make a limit on the show of these values in 950 RPM? No, but in case you can see a pattern in how the measured values differ to real values, like if they're always 2x or 4x or 8x more than the actual values, then you can use the Correction facility of AIDA64 (in AIDA64 / Preferences / Hardware Monitoring / Correction) to divide down the values. Quote
790 Posted July 25 Author Posted July 25 Thanx, I know about Correction and use it, but this is another case. There is no pattern here, the values >1000rpm are always random. I understand that 950rpm +/-10% is normal, but 28000-38000rpm is too much Only logical solutions will help here (IF X>950 THAN X=950). I already offered to add more mathematical functions like AVERAGE/MAX/MIN for one-type values to Correction or SensorPanel. Quote
