Thermaltake Posted March 2, 2014 Posted March 2, 2014 When I set fan speed on 100% in MSI Afterburner, in aida64 latest version he is showing that it is on 92% I don't know if thats bug or something. GPU is POV GTX470 MBO: Asus p8h67 OS: Win 7 64bit SP1 Here is picture: Quote
Fiery Posted March 3, 2014 Posted March 3, 2014 First of all, please upgrade to the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/aida64extremebuild2815jtcqw4m3dzzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. If the problem persists, then do the following: 1) Please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic. 2) Then right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic. Thanks, Fiery Quote
Thermaltake Posted March 6, 2014 Author Posted March 6, 2014 I installed that beta version, but problem is still here. In debug he said "Fan Duty Cycle = 100 %" that means he is running at 100% but in sensors section he is saying 92%. here are Debugs that you asked: ------[ AIDA64 v4.20.2820 Beta ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7601.18247 Service Pack 1 (64-bit) ]------ ------[ Video Adapters ]------ nVIDIA GeForce GTX 470 (p1025) [10DE-06CD / 10DE-079F] ------[ Video Driver ]------ nvapi.dll: 9.18.13.3489 nvd3dumx||9.18.13.3489|||nvwgf2umx||9.18.13.3489|||nvwgf2umx||9.18.13.3489|||nvd3dum||9.18.13.3489 - nVIDIA ForceWare 334.89|||nvwgf2um||9.18.13.3489|||nvwgf2um||9.18.13.3489 nvd3dumx||9.18.13.3489|||nvwgf2umx||9.18.13.3489|||nvwgf2umx||9.18.13.3489|||nvd3dum||9.18.13.3489 - nVIDIA ForceWare 334.89|||nvwgf2um||9.18.13.3489|||nvwgf2um||9.18.13.3489 ------[ nVIDIA GPU #1 @ mem F4000000 ]------ GPU Clocks = 405 / 810 / 0 MHz Memory Clock = 324 MHz GPU Base Clock = 27000 kHz Shader Base Clock = 27000 kHz Memory Base Clock = 27000 kHz nvidia-000000 = 0C0680A3 [GF100] nvidia-0010F0 = 00000000 nvidia-001218 = 00000000 nvidia-001538 = 8001FFFF nvidia-001540 = 00000000 nvidia-0015F4 = 00000000 nvidia-0015F8 = 00000000 nvidia-0015FC = 00000000 nvidia-001600 = 00000000 nvidia-001704 = 8004FFC1 nvidia-001714 = C004FFC2 nvidia-001850 = 00000000 nvidia-004000 = 00000000 nvidia-004004 = 00000000 nvidia-004008 = 00000000 nvidia-00400C = 00000000 nvidia-004018 = 00000000 nvidia-00401C = 00000000 nvidia-004020 = 00000000 nvidia-004024 = 00000000 nvidia-004028 = 00000000 nvidia-00402C = 00000000 nvidia-004120 = 00000000 nvidia-004124 = 00000000 nvidia-004128 = 00000000 nvidia-004200 = 00000000 nvidia-004220 = 00000000 nvidia-00C040 = 00000000 nvidia-00E114 = 00000001 nvidia-00E118 = 00000000 nvidia-00E11C = 00000001 nvidia-00E120 = 00000000 nvidia-00E728 = 006B00AF nvidia-00E820 = 01030005 nvidia-00E8A0 = 00000000 nvidia-020008 = C0083665 nvidia-020014 = FA580392 nvidia-020400 = 00000029 nvidia-022430 = 00000004 nvidia-022434 = 00000004 nvidia-022438 = 00000006 nvidia-02243C = 00000000 nvidia-022440 = 00000000 nvidia-022540 = 00000000 nvidia-022544 = 00000000 nvidia-022548 = 00000008 nvidia-022550 = 00000000 nvidia-022554 = 00000001 nvidia-088000 = 06CD10DE [GF100] nvidia-08A000 = 0BE510DE nvidia-100000 = 00000000 nvidia-100200 = 00000000 nvidia-10020C = 00000000 nvidia-100214 = 00000000 nvidia-100474 = 00000000 nvidia-100714 = 00000501 nvidia-100914 = 00000000 nvidia-101000 = A040748E nvidia-10100C = 8003B010 nvidia-10F20C = 00000100 nvidia-10F290 = 030E0C0A nvidia-10F294 = 3420C287 nvidia-10F590 = 00100204 nvidia-121C70 = 00000001 nvidia-121C74 = 00000005 nvidia-121C78 = 00000004 nvidia-13C78C = 00000000 nvidia-17E924 = E3000E23 nvidia-300000 = EB7AAA55 nvidia-310000 = FFFFFFFF nvidia-419E9C = 00000030 nvidia-700000 = FFDDEB6B nvidia-7E0000 = EB7AAA55 ------[ nVIDIA GPU #1 / ForceWare Properties ]------ Memory Type = 8 (GDDR5) Memory Bank Count = 1 Memory Bus Width = 320-bit GPU / MC / VE Load = 2 / 3 / 0 VPE Count = 0 Shader Pipe Count = 4 Shader SubPipe Count = 14 Total SP Count = <unknown> Total TPC Count = 0 Total SM Count = <unknown> Core Count = 448 Partition Count = 5 (mask: 00000037) Fan RPM = 5250 RPM Fan Duty Cycle = 100 % Core Voltage = 887 mV Current Pstate = 8 Ventura State = 0 (unsupported) Physical Frame Buffer Size = 1310400 KB Virtual Frame Buffer Size = 1310720 KB Total / Free Video Memory = 1310720 KB / 1059180 KB ------[ nVIDIA GPU #1 / ForceWare Clocks (old) ]------ Perf. Levels = 4 Active Profile = 1 curr-core/shader/mem-0 = 50 MHz / 101 MHz / 135 MHz curr-core/shader/mem-1 = 405 MHz / 810 MHz / 324 MHz [Active] curr-core/shader/mem-2 = 405 MHz / 810 MHz / 1674 MHz curr-core/shader/mem-3 = 607 MHz / 1215 MHz / 1674 MHz orig-core/shader/mem-0 = 50 MHz / 101 MHz / 135 MHz orig-core/shader/mem-1 = 405 MHz / 810 MHz / 324 MHz [Active] orig-core/shader/mem-2 = 405 MHz / 810 MHz / 1674 MHz orig-core/shader/mem-3 = 607 MHz / 1215 MHz / 1674 MHz ------[ nVIDIA GPU #1 / BIOS Info ]------ BIOS Version = 70.00.21.00.03 Signon Message = GF100 P1025 SKU 0006 VGA BIOS Bootup Core Clock = 1095320 MHz Bootup Shader Clock = 1126187 MHz Bootup Mem Clock = 541149 MHz Ref. Clock 4000 = 0 kHz = 0 MHz *4 Ref. Clock 4008 = 0 kHz = 0 MHz *4 [Memory] Ref. Clock 4010 = 0 kHz = 0 MHz *4 Ref. Clock 4018 = 0 kHz = 0 MHz *4 Ref. Clock 4020 = 0 kHz = 0 MHz *4 [Shader] Ref. Clock 4028 = 0 kHz = 0 MHz *4 [GPU] Ref. Clock 4030 = 0 kHz = 0 MHz *4 Ref. Clock 4038 = 0 kHz = 0 MHz *4 Core Clock = 50 MHz Shader Clock = 101 MHz Mem Clock = 135 MHz Geom. Delta = 0 MHz Core Voltage = 0,00 V Fan Speed = 0 % Core Clock = 405 MHz Shader Clock = 810 MHz Mem Clock = 324 MHz Geom. Delta = 0 MHz Core Voltage = 0,00 V Fan Speed = 0 % Core Clock = 405 MHz Shader Clock = 810 MHz Mem Clock = 1674 MHz Geom. Delta = 0 MHz Core Voltage = 0,00 V Fan Speed = 0 % Core Clock = 607 MHz Shader Clock = 1215 MHz Mem Clock = 1674 MHz Geom. Delta = 0 MHz Core Voltage = 0,00 V Fan Speed = 0 % Diode Gain Mul = 0 Diode Gain Div = 0 Diode Offset Mul = 0 Diode Offset Div = 13090 Diode Offset Bin Mul = 0 Diode Offset Bin Div = 1 Temp Compensation Mul = 0 Temp Compensation Div = 1 Max Div = 0 Measured Temp Threshold (Raw) = 0 Measured Temp Threshold (Int) = 0 Celsius Measured Temp Threshold (Float) = 0 Celsius BIOS Temp Threshold = 125 Celsius Measured Diode Temp (Raw) = 0 Measured Diode Temp (Int) = 0 Celsius Measured Diode Temp (Float) = 0 Celsius Diode Temp by ForceWare = 43 Celsius ------[ NVAPI GPU Handles ]------ GPU Count = 1 GPU #1 = 00000100 ------[ nVIDIA GPU #1 / Thermal Settings ]------ Sensor Count = 2 Sensor #0 / Controller = VBIOSEVT Sensor #0 / Target = GPU Core Sensor #0 / Current Temp = 43 Celsius Sensor #1 / Controller = VBIOSEVT Sensor #1 / Target = GPU Board Ambient Sensor #1 / Current Temp = 32 Celsius ------[ AIDA64 v4.20.2820 Beta ]------ ------[ Microsoft Windows 7 Ultimate 6.1.7601.18247 Service Pack 1 (64-bit) ]------ ------[ Video Adapters ]------ nVIDIA GeForce GTX 470 (p1025) [10DE-06CD / 10DE-079F] ------[ Video Driver ]------ nvapi.dll: 9.18.13.3489 nvd3dumx||9.18.13.3489|||nvwgf2umx||9.18.13.3489|||nvwgf2umx||9.18.13.3489|||nvd3dum||9.18.13.3489 - nVIDIA ForceWare 334.89|||nvwgf2um||9.18.13.3489|||nvwgf2um||9.18.13.3489 nvd3dumx||9.18.13.3489|||nvwgf2umx||9.18.13.3489|||nvwgf2umx||9.18.13.3489|||nvd3dum||9.18.13.3489 - nVIDIA ForceWare 334.89|||nvwgf2um||9.18.13.3489|||nvwgf2um||9.18.13.3489 ------[ nVIDIA GPU #1 / B00-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B00-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B01-CR49 = 00 ]------ ------[ nVIDIA I2C Device GPU #1 / B01-D3A ]------ 0000 D0 6C 3F 3D 60 00 00 00 00 00 A2 00 00 00 00 00 .l?=`........... 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0040 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA I2C Device GPU #1 / B01-D3A ]------ 0000 6CD0 3F6C 3D3F 603D 0060 0000 0000 0000 0000 A200 00A2 0000 0000 0000 0000 0000 0010 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0020 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0030 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 8000 0040 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0050 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0060 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0070 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0080 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0090 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00B0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00D0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00E0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 D000 ------[ nVIDIA I2C Device GPU #1 / B01-D50 ]------ 0000 00 FF FF FF FF FF FF 00 4C 2D E5 03 32 32 57 54 ........L-..22WT 0010 02 12 01 03 80 2F 1E 78 2A EE 91 A3 54 4C 99 26 ...../.x*...TL.& 0020 0F 50 54 BF EF 80 B3 00 81 80 81 40 71 4F 01 01 .PT........@qO.. 0030 01 01 01 01 01 01 7C 2E 90 A0 60 1A 1E 40 30 20 ......|...`..@0 0040 36 00 DA 28 11 00 00 1A 00 00 00 FD 00 38 4B 1E 6..(.........8K. 0050 51 0E 00 0A 20 20 20 20 20 20 00 00 00 FC 00 53 Q... .....S 0060 79 6E 63 4D 61 73 74 65 72 0A 20 20 00 00 00 FF yncMaster. .... 0070 00 48 31 41 4B 35 30 30 30 30 30 0A 20 20 00 82 .H1AK500000. .. 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ nVIDIA I2C Device GPU #1 / B01-D50 ]------ 0000 FF00 FFFF FFFF FFFF FFFF FFFF 00FF 4C00 2D4C E52D 03E5 3203 3232 5732 5457 0254 0010 1202 0112 0301 8003 2F80 1E2F 781E 2A78 EE2A 91EE A391 54A3 4C54 994C 2699 0F26 0020 500F 5450 BF54 EFBF 80EF B380 00B3 8100 8081 8180 4081 7140 4F71 014F 0101 0101 0030 0101 0101 0101 0101 0101 7C01 2E7C 902E A090 60A0 1A60 1E1A 401E 3040 2030 3620 0040 0036 DA00 28DA 1128 0011 0000 1A00 001A 0000 0000 FD00 00FD 3800 4B38 1E4B 511E 0050 0E51 000E 0A00 200A 2020 2020 2020 2020 2020 0020 0000 0000 FC00 00FC 5300 7953 0060 6E79 636E 4D63 614D 7361 7473 6574 7265 0A72 200A 2020 0020 0000 0000 FF00 00FF 0070 4800 3148 4131 4B41 354B 3035 3030 3030 3030 3030 0A30 200A 2020 0020 8200 FF82 0080 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00FF ------[ nVIDIA GPU #1 / B02-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B02-CR49 = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B03-CR49 = 00 ]------ ------[ nVIDIA I2C Device GPU #1 / B03-D2E ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0020 00 FF C3 00 00 64 5F 64 0E 04 FF FF FF FF FF FF .....d_d........ 0030 EB FF FF 99 A4 A4 20 00 EB FF FF 00 00 73 41 69 ...... ......sAi 0040 25 10 00 1F 00 FF 00 FF 00 FF 00 FF 00 FF 82 A0 %............... 0050 01 FF 01 FF FF FF FF FF FF FF FF FF E0 60 70 E8 .............`p. 0060 CC CC 20 00 66 80 80 7C 9A 9A A5 A4 AB 10 00 00 .. .f..|........ 0070 00 00 00 00 FF FF 2C B8 1A 00 00 55 20 09 00 00 ......,....U ... 0080 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ------[ nVIDIA I2C Device GPU #1 / B03-D2E ]------ 0000 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 0010 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 0020 E500 16FF A2C3 E500 E500 DE64 7F5F DE64 CF0E F904 16FF 16FF 16FF 16FF 16FF 16FF 0030 7AEB 16FF 16FF 2399 90A4 90A4 0520 E500 7AEB 16FF 16FF E500 E500 BB73 2541 FD69 0040 1E25 9510 E500 B81F E500 16FF E500 16FF E500 16FF E500 16FF E500 16FF 6282 8CA0 0050 E201 16FF E201 16FF 16FF 16FF 16FF 16FF 16FF 16FF 16FF 16FF 4BE0 C260 B270 73E8 0060 8FCC 8FCC 0520 E500 D066 6C80 6C80 967C 2A9A 2A9A 97A5 90A4 BDAB 9510 E500 E500 0070 E500 E500 E500 E500 16FF 16FF 212C C4B8 A31A E500 E500 4955 0520 DA09 E500 E500 0080 9510 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 0090 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 00A0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 00B0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 00C0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 00D0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 00E0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 00F0 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 E500 ------[ nVIDIA GPU #1 / B04-CR1F = 00 ]------ ------[ nVIDIA GPU #1 / B04-CR49 = 00 ]------ ------[ Chips Found ]------ GPU1-B01-D3A: ***** Unknown Device ***** GPU1-B01-D50: EDID GPU1-B03-D2E: Analog Devices ADT7473 Total : 8.5 sec GPU1-B00: 1.6 sec GPU1-B01: 3.8 sec GPU1-B02: 0.5 sec GPU1-B03: 2.6 sec GPU1-B04: 0.0 sec Quote
Fiery Posted March 7, 2014 Posted March 7, 2014 Thank you for the data. I suppose the confusion comes from the fact that your GPU has an on-die integrated fan controlling logic that is currently not utilized, but set to 100% duty cycle; whereas your video card also has a sensor chip (ADT7473) that also has a fan controlling logic that is utilized and is set to 92%. On the Sensor page AIDA64 shows the more relevant information, the duty cycle for the on-board ADT7473 sensor chip. Regards, Fiery Quote
Thermaltake Posted March 8, 2014 Author Posted March 8, 2014 So that's normaln when he is set in afterburner on 100% to show in aida 92% ? Quote
Fiery Posted March 10, 2014 Posted March 10, 2014 Yes, because AfterBurner sets the other fan controller's duty cycle Quote
