MoonTime622 Posted October 15, 2025 Posted October 15, 2025 Hello, I’m currently using AIDA64 Extreme v8.00.8000 on Windows 11 24H2 with an NVIDIA RTX 5090 GPU. My setup includes three monitors, one of which is a small USB-connected display (1920×480) mounted inside the PC case and dedicated to the Sensor Panel. However, after every reboot or wake-up from sleep/hibernation, the Sensor Panel window automatically moves to another screen, even though I have: Locked the Sensor Panel position Set it to display only on the small USB screen This issue repeats every time the system restarts or resumes from sleep. Please let me know if there’s a known workaround or if a fix is planned for future updates. Thank you for your assistance. Best regards, Quote
rinaldop Posted October 16, 2025 Posted October 16, 2025 Post this in the Bug reports section for a faster reply or create a bug report to the devs. Quote
Fiery Posted November 9, 2025 Posted November 9, 2025 On 10/15/2025 at 11:28 AM, MoonTime622 said: Hello, I’m currently using AIDA64 Extreme v8.00.8000 on Windows 11 24H2 with an NVIDIA RTX 5090 GPU. My setup includes three monitors, one of which is a small USB-connected display (1920×480) mounted inside the PC case and dedicated to the Sensor Panel. However, after every reboot or wake-up from sleep/hibernation, the Sensor Panel window automatically moves to another screen, even though I have: Locked the Sensor Panel position Set it to display only on the small USB screen This issue repeats every time the system restarts or resumes from sleep. Please let me know if there’s a known workaround or if a fix is planned for future updates. Thank you for your assistance. Best regards, Please upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Quote
MarkL Posted December 12, 2025 Posted December 12, 2025 I have almost the same config and issue, a small 800x400 display with 2 34" 2k monitors. Not like I change monitors or resolutions, should stay where I put it. Quote
Fiery Posted December 12, 2025 Posted December 12, 2025 3 hours ago, MarkL said: I have almost the same config and issue, a small 800x400 display with 2 34" 2k monitors. Not like I change monitors or resolutions, should stay where I put it. Have you tried AIDA64 v8.20? Quote
Movingon007 Posted December 27, 2025 Posted December 27, 2025 Hallo, ich habe das gleiche Problem mit 2 Monitoren und habe alles probiert was ich dazu finden konnte. Ich habe die Version wieder auf 7.70.7500 downgraded und siehe da alles funktioniert wieder. Also bitte mal die neue Version überprüfen !!!! Quote
slipkidOG Posted January 16 Posted January 16 This is an outdated post, but I have tried everything with the same results as the others. I have 3x 34" monitors with a fourth that is 1920x1080 on the side. Regardless of the settings, when I reboot it goes to my primary screen. It is pinned to the correct monitor when I check the settings as well. I am on the latest version. Any help would be appreciated. 1 Quote
fossi Posted February 6 Posted February 6 On 1/16/2026 at 8:13 PM, slipkidOG said: Regardless of the settings, when I reboot it goes to my primary screen. It is pinned to the correct monitor when I check the settings as well. I am on the latest version same issue. using the latest beta version "v8.20.8116 beta" (licensed) this is my config: but after every reboot the SensoePanel is on DISPLAY1 instead of DISPLAY2 . Then I have to open the preferences screen ("Pin SensorPanel to monitor" still shows "DISPLAY 2: 1024 x 600" but the panel is on DISPLAY1) select "disabled" for the "Pin SensorPanel to monitor" setting then change it back to "DISPLAY 2: 1024 x 600" and hit apply to move the panel back to the correct display/postion. (only hitting "apply" without change to "disabled" and back to "DISPLAY 2" does nothing) Quote
Fiery Posted Monday at 12:14 PM Posted Monday at 12:14 PM On 2/6/2026 at 1:51 PM, fossi said: same issue. using the latest beta version "v8.20.8116 beta" (licensed) this is my config: but after every reboot the SensoePanel is on DISPLAY1 instead of DISPLAY2 . Then I have to open the preferences screen ("Pin SensorPanel to monitor" still shows "DISPLAY 2: 1024 x 600" but the panel is on DISPLAY1) select "disabled" for the "Pin SensorPanel to monitor" setting then change it back to "DISPLAY 2: 1024 x 600" and hit apply to move the panel back to the correct display/postion. (only hitting "apply" without change to "disabled" and back to "DISPLAY 2" does nothing) @Movingon007 @slipkidOG Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Please use the pinning facility (AIDA64 / Preferences / Hardware Monitoring / SensorPanel / Pin SensorPanel to monitor) to move the SensorPanel to the right screen. Let me know how it works. 1 Quote
fossi Posted 8 hours ago Posted 8 hours ago On 2/16/2026 at 1:14 PM, Fiery said: @Movingon007 @slipkidOG Let me know how it works. thanks a lot for the update/fix - looking good! the panel now stays on the pinned display, even after reboot, after disabling /reenabling another display, changing primary display, etc Quote
