javanse Posted February 1, 2011 Posted February 1, 2011 Hi, It looks like AIDA64 uses the wrong formula for calculating the Texel Fillrate for GeForce GTX 400 GPUs, while Pixel Fillrate is calculated correctly. Pixel Fillrate = Core Clock * ROP Count My GTX 470 has 40 ROPs and is clocked @ 750 MHz => 30 GPixel/s, that value is correctly shown by AIDA and GPU-Z. Texel Fillrate = Core Clock * TMU Count My GTX 470 has 56 TMUs and is clocked @ 750 MHz => 42 GTexel/s, that value is correctly shown by GPU-Z while AIDA64 shows exactly 4 times as much, 168 GTexel/s. FYI, this calculation error is visible in all P-States. Second thing, i can't understand some of the readings on the Mainboard -> Memory page. I've 8 GB RAM with a fixed 2 GB min / 2 GB max pagefile which AIDA shows correctly. But it calculates a swap space of 10 GB, apparently RAM+Swap, and 18 GB virtual memory, apparently RAM+swap space, which doesn't make any sense to me. Shouldn't it read a swap space of 2 GB and 10 GB virtual memory, as confirmed by the 10 GB commit charge limit reading from Process Explorer from Sysinternals? Quote
Squall Leonhart Posted February 2, 2011 Posted February 2, 2011 apparently, the Texture fillrate is also incorrect, on my 275 it should be between 46000 and 54640 Mtexels/sec (clock dependant) but aida displays it as over 80,000Mtexels/s when ramped up to full clocks. Quote
Fiery Posted February 2, 2011 Posted February 2, 2011 We've fixed the texture fillrate calculation in the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1243bw4ylkfd0mzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. As for the memory sizes, they can be confusing, but that's how Windows manages swap space and paging files. Even if you disable paging files completely, Windows will still manage some swap space. Quite hard to follow that logic, but that's just how Windows works Quote
Squall Leonhart Posted February 3, 2011 Posted February 3, 2011 Texel Rate is most certainly fixed Quote
Fiery Posted February 4, 2011 Posted February 4, 2011 Texel Rate is most certainly fixed Thank you for the feedback Quote
javanse Posted February 4, 2011 Author Posted February 4, 2011 Thanks for the update Fiery, Texel Fillrate reading is now correct But there's another issue related to the TMUs: For my GTX 470, AIDA reads 40 Pixel Pipelines (aka ROPs), which is correct, but also "TMU Per Pipeline = 1", which is wrong in two ways at once. First, it implies 40 while there are 56 TMUs. And second, the item name "TMU Per Pipeline" itself is only correct up to G71. Since G80, ROPs and TMUs are decoupled from each other, so IMHO it should be renamed to "Texture Mapping Units" only as the amount of ROPs is related to the bus width of the memory interface while the amount of TMUs is related to the streaming multiprocessors. Amount of TMUs: 448 Shader / 32 Shader per SM gives 14 SM. Each SM has 4 TMUs for a total of 56 TMUs. Amount of ROPs: 320 bit MI / 64 bit width per ROP-Partition gives 5 ROP-P. Each ROP-P has 8 ROPs for a total of 40 ROPs. kthxbye and a have a nice weekend Quote
Fiery Posted February 10, 2011 Posted February 10, 2011 We've fixed the TMU issue, and also implemented TMU count detection and texel fillrate calculation for R600 and later GPUs by ATI/AMD. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1251oq1xi5ergvzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
javanse Posted February 11, 2011 Author Posted February 11, 2011 Thx Fiery, Build 1251 works fine, i don't have any complaints anymore. Quote
Fiery Posted February 11, 2011 Posted February 11, 2011 Thx Fiery, Build 1251 works fine, i don't have any complaints anymore. Thank you for the feedback Quote
