GaHile Posted December 30, 2025 Posted December 30, 2025 Hello everyone, 🙏 We like to share a project we're working on with a lot of care and passion over the past months: SynQPanel. SynQPanel is a Windows desktop panel visualization application designed to present AIDA64 hardware telemetry in clean, compact, and highly customizable layouts - especially suited for secondary displays and dedicated monitoring screens. It will be available FREE OF COST!! This post is an early introduction and teaser ahead of a public release. We created this thread so that we can add the URL in the application UI and further, we will use it for discussions! What is SynQPanel? SynQPanel provides a visual layer on top of AIDA64 Shared Memory, allowing users to design information-dense dashboards composed of multiple visual elements. The focus is not on replacing AIDA64, but on presenting its data differently - with some different control over layout, density, and visual intent. The project is: Open-source Built with WPF (.NET ) Designed around clarity, precision, and long-term maintainability The purpose of the project is to act as an external visualization frontend for sensor data (for example, animated or stylized sensor panels). All rendering, UI, and animation logic are handled entirely within the external application; AIDA64 remains unchanged and is used solely as the data provider. To clarify the project’s scope: Uses only AIDA64’s documented shared memory interface Does not include or distribute any AIDA64 components Does not bypass licensing, UI limitations, or protections Clearly states non-affiliation: Does not use AIDA64 logos or branding Refers to AIDA64 only in a functional manner (e.g., “ensure AIDA64 shared memory is enabled”) What does it do? Presents CPU, GPU, memory, and system metrics using text, gauges, bars, tables, and charts Supports static and animated visual elements (for subtle motion, indicators, and themed panels) Allows pixel-precise layout control for compact or high-density panels Supports profile-based configurations for different layouts and resolutions Includes a small set of built-in Extra add-ons for runtime and system context All telemetry is read via AIDA64 Shared Memory - a compatible AIDA64 installation is required/must. Design Philosophy SynQPanel is designed to be: Minimal - Its simple and helps to what you choose to display Precise - exact positioning and controlled visuals Intentional - visuals serve information, not the other way around The goal is to give users the tools to design their own panels, whether simple or highly detailed. Project Origin & Status SynQPanel is derived from an open-source codebase originally authored by Habib Rehman, and has since been independently developed, refactored, and extended under the GNU GPL. Current status: Beta Core functionality is stable UI, add-ons, and internal APIs may continue to evolve 📅 Planned public release: 🎉First week of January 2026 🎉 We are Finalizing the Code, updating Free Licensing, Attributions, cutting things to make it as light as possible Open Source & Community Licensed under GNU General Public License v3.0 or later Source code will be available on GitHub Feedback, ideas, and discussion are very welcome and will continue in this thread Once released, we’ll share: GitHub repository link Screenshots / short animations Basic setup and usage guidance (Will need your help here too) Disclaimer AIDA64 is a registered trademark of FinalWire Ltd. SynQPanel is an independent project and is not affiliated with or endorsed by FinalWire Ltd. Thank you all for reading 🙏 We will need your love, support to make this project good 🙏 We're excited and looking forward to sharing more details soon and hearing your thoughts. __ SynQPanel contributors 5 Quote
GaHile Posted January 4 Author Posted January 4 🚀 SynQPanel v1.0 – Public Preview Released Hello everyone, Following up on my earlier teaser, SynQPanel v1.0 (Public Preview) is now available. SynQPanel is a panel-based desktop visualization tool for AIDA64 users, focused on: clean layouts pixel-precise control secondary displays & always-on dashboards ✨ Highlights Uses AIDA64 Shared Memory Runs on Windows 10 / 11 Profile-based configurations Multiple visual elements (text, gauges, bars, tables) Small set of built-in add-ons for system & runtime context ⚖️ Licensing & Attribution Released under GNU GPL v3.0 or later Derived from an open-source project originally authored by Habib Rehman Since then significantly modified, extended, and independently maintained as SynQPanel AIDA64 is a registered trademark of FinalWire Ltd SynQPanel is not affiliated with or endorsed by FinalWire Ltd Source code & license details: 👉 https://github.com/sursingh-hub/SynQPanel ⬇️ Download Windows installer (Public Preview) Available under GitHub Releases 👉 https://github.com/sursingh-hub/SynQPanel/releases ⚠️ Security Notice (Please Read) SynQPanel is a new, unsigned application. Because of this, Windows SmartScreen or some antivirus tools may briefly scan the installer or display a warning during first launch. This is normal behavior for newly released software and does not indicate malware. Why this can happen SynQPanel legitimately accesses: Local configuration files AIDA64 shared memory System and hardware telemetry What to expect ✔ Installer completes successfully ✔ SynQPanel runs normally ✔ No warnings on subsequent launches Windows SmartScreen/Defender If Windows shows “Protected your PC”: Click More info → Run anyway to continue. Transparency: SynQPanel is fully open source, with complete source code available on GitHub. There are no hidden installers, background services, or bundled software. ⚙️ Enable AIDA64 Shared Memory (Required) SynQPanel requires AIDA64 Shared Memory. AIDA64 → Preferences → External Applications Enable: ✅ Shared Memory ✅ Writing sensor values to RivaTuner OSD ✅ Display labels Restart AIDA64 after applying changes. 🧪 Public Preview Notice This is a Public Preview release. Please: Keep backups of your original .sensorpanel, .spzip, or .sqx files Avoid editing your only copy of important panels Use test or duplicated panels when experimenting SynQPanel does not modify AIDA64 itself, but may save changes back to imported panel formats. Provided as-is, without warranty, as permitted under the GPL. 🙏 Final Words This project is shared in the spirit of learning, experimentation, and open-source collaboration. Feedback - positive or critical - is welcome. Thank you to the AIDA64 community for the inspiration over the years. __ SynQPanel contributors Quote
GaHile Posted January 5 Author Posted January 5 =========This Section is reserved for Known Issues============ Known Issues (Public Preview) .rslcd panels are partially supported Some gauges may not render correctly Saving .rslcd panels is not supported at this time When adding new items to .sensorpanel or .spzip panels, new items are currently added to the bottom of the panel list Some .spzip or .sensorpanel files generated by newer AIDA64 versions or having MANY images may fail to import due to format differences. This will be addressed in upcoming updates [FIXED] System short cut in labels are not loaded and appear as $CPUModel, $GPU1Model These limitations are known and will be improved in future updates. =========FIXES============ Update – Fixed, will be available in the upcoming build v1.0.1 Two issues identified during testing have now been resolved: • Background images marked as “Set as background” in AIDA64 panels were not being detected correctly. SynQPanel now respects the BGIMG flag exactly as defined by AIDA64. • Image-based hour hands using the Time (STIME) sensor (including 360 / 720 image clocks) were not rendering correctly when the sensor returned formatted time values. SynQPanel now properly interprets STIME for image-state gauges. Thank you to everyone who tested and reported these - this helped improve compatibility with advanced AIDA64 panels. • Enhanced Shared Memory Reading SynQPanel no longer imposes any shared memory size limits. It dynamically maps and parses the full memory region provided by AIDA64, eliminating XML truncation and sensor-list instability. Quote
GaHile Posted January 5 Author Posted January 5 =============== Instructions: We will keep on updating this =========== 💾 Saving & Exporting Panels Currently supported formats: .sensorpanel .spzip .sqx Saving changes In SynQ Manager, clicking Save writes all changes back to the original imported file Exporting panels Open SynQ Gallery from the left pane Select the panel you want to export Use Export SPZIP or Export SQX Notes on animations GIFs, animations, and advanced visuals are only supported in .sqx If you add animations, export the panel as .sqx for full compatibility +++++++++++++++++++++++++++++++++++++++++++++++ Converting MB to GB or other conversions example: 1 Quote
Loyd Posted January 5 Posted January 5 From GaHile "About the images not loading That’s very useful feedback. Could you please let me know (or share an example) where some image items didn’t load? If you can mention: panel format (.sensorpanel, .spzip, .sqx) image type (static / GIF / web image) and whether they were existing items or newly added I’ll try to reproduce it and address it in the next update." panel format=.spzip, image type static *.png, existing. This was the main image used for the panel. Also did not load the system short cut in labels. Missing the path maybe? Loyd 1 Quote
GaHile Posted January 6 Author Posted January 6 8 hours ago, Loyd said: From GaHile "About the images not loading That’s very useful feedback. Could you please let me know (or share an example) where some image items didn’t load? If you can mention: panel format (.sensorpanel, .spzip, .sqx) image type (static / GIF / web image) and whether they were existing items or newly added I’ll try to reproduce it and address it in the next update." panel format=.spzip, image type static *.png, existing. This was the main image used for the panel. Also did not load the system short cut in labels. Missing the path maybe? Loyd @Loyd: Thank you so much for sharing the details! I really appreciate it ! 🙏 1. Yes, the main image issue is resolved and we found that when any image is set as Background was skipped in the code. This happened as we had the code to skip "Preview" first image. Now its fixed and will be shipped in the next build 2. If you dont mind, please share the screenshot where the system shortcut is not loaded for labels. We will try to fix that too! Really appreciate your interest and support in this matter! 🙏 You guys are amazing 😍 as you all are helping me a lot to diagnose and make this application better! ❤️ Now, I dont feel alone here!! ❤️ 1 Quote
Surjeet Posted January 6 Posted January 6 6 hours ago, GaHile said: @Loyd: Thank you so much for sharing the details! I really appreciate it ! 🙏 1. Yes, the main image issue is resolved and we found that when any image is set as Background was skipped in the code. This happened as we had the code to skip "Preview" first image. Now its fixed and will be shipped in the next build 2. If you dont mind, please share the screenshot where the system shortcut is not loaded for labels. We will try to fix that too! Really appreciate your interest and support in this matter! 🙏 You guys are amazing 😍 as you all are helping me a lot to diagnose and make this application better! ❤️ Now, I dont feel alone here!! ❤️ Thank you so much for the fixes! I’ll run some more rigorous testing with new version and will definitely share if I come across any issues 😊 1 Quote
Loyd Posted January 6 Posted January 6 this is what I mean. That should display CPU & GPU info 1 Quote
GaHile Posted January 6 Author Posted January 6 2 hours ago, Loyd said: this is what I mean. That should display CPU & GPU info Thank you for sharing the details. We have added this to known issues and will try to fix in the next build! Quote
BHSY Posted January 7 Posted January 7 Many thanks to GaHile for the prompt response and for resolving the issues I faced. 🙏💖🥰 I integrated a K.I.T.T. voice video and created a custom LED sensor light animation for my existing sensor panel using SynQPanel. Now the sensor light moves faster than my previous one, and I don't have to use a 3rd-party frameless video.💪 3 Quote
Surjeet Posted January 7 Posted January 7 2 hours ago, BHSY said: Many thanks to GaHile for the prompt response and for resolving the issues I faced. 🙏💖🥰 I integrated a K.I.T.T. voice video and created a custom LED sensor light animation for my existing sensor panel using SynQPanel. Now the sensor light moves faster than my previous one, and I don't have to use a 3rd-party frameless video.💪 This is DOPE Man!! AWESOME!! I love it! 1 2 Quote
GaHile Posted January 7 Author Posted January 7 5 hours ago, BHSY said: Many thanks to GaHile for the prompt response and for resolving the issues I faced. 🙏💖🥰 I integrated a K.I.T.T. voice video and created a custom LED sensor light animation for my existing sensor panel using SynQPanel. Now the sensor light moves faster than my previous one, and I don't have to use a 3rd-party frameless video.💪 Wow, your panels and ideas are really OUT OF THE WORLD!! 🎉 You are the one to show the power of SynQPanel!! LOVE IT!!!! 😍 I really want such kind of encouragement to keep this project enhancing further and further. Thank you!!!! 1 1 Quote
Sensor Moderators COSTAJUNIOR Posted January 7 Sensor Moderators Posted January 7 On 1/5/2026 at 7:22 AM, GaHile said: =============== Instructions: We will keep on updating this =========== 💾 Saving & Exporting Panels Currently supported formats: .sensorpanel .spzip .sqx Saving changes In SynQ Manager, clicking Save writes all changes back to the original imported file Exporting panels Open SynQ Gallery from the left pane Select the panel you want to export Use Export SPZIP or Export SQX Notes on animations GIFs, animations, and advanced visuals are only supported in .sqx If you add animations, export the panel as .sqx for full compatibility +++++++++++++++++++++++++++++++++++++++++++++++ Converting MB to GB or other conversions example: Excellent initiative! The SynQPanel concept is very interesting and significantly expands the possibilities for visualizing AIDA64 data. Congratulations on the project and the work done so far. I downloaded the tool and completed the installation, but I must admit I had some difficulty understanding the initial workflow, especially regarding the creation, import, and configuration of panels. At times, it’s not entirely clear how to build a panel from scratch or how to properly organize elements so everything works as expected. I believe creating a step-by-step video tutorial or more detailed documentation explaining how SynQPanel works — from layout creation and adding sensors to saving the final panel — would be extremely helpful. This would greatly benefit both new and advanced users, making it easier to fully take advantage of the tool. Overall, the project has great potential, and with clearer onboarding materials, adoption within the community will certainly grow. Thank you for sharing and for the excellent work! 4 Quote
Kim Sahyeong Posted January 8 Posted January 8 i got a problem, SynQ tells me it can't read sensor, i have aida run on admin with shared memory ticked and i did reboot my pc i run aida 8.20.8100 p.s even if i don't have sensors, your software looks great, good job guys 1 1 Quote
GaHile Posted January 8 Author Posted January 8 10 hours ago, COSTAJUNIOR said: Excellent initiative! The SynQPanel concept is very interesting and significantly expands the possibilities for visualizing AIDA64 data. Congratulations on the project and the work done so far. I downloaded the tool and completed the installation, but I must admit I had some difficulty understanding the initial workflow, especially regarding the creation, import, and configuration of panels. At times, it’s not entirely clear how to build a panel from scratch or how to properly organize elements so everything works as expected. I believe creating a step-by-step video tutorial or more detailed documentation explaining how SynQPanel works — from layout creation and adding sensors to saving the final panel — would be extremely helpful. This would greatly benefit both new and advanced users, making it easier to fully take advantage of the tool. Overall, the project has great potential, and with clearer onboarding materials, adoption within the community will certainly grow. Thank you for sharing and for the excellent work! Thank you so much for your kind words and for taking the time to try SynQPanel - it truly means a lot, especially coming from the AIDA64 Family/Team. 🙏 You’re absolutely right about the onboarding experience. SynQPanel is still growing, and while the core functionality is there, the workflow for creating and organizing panels needs clearer guidance. A step-by-step video tutorial and improved documentation are definitely next on my roadmap. I also want to sincerely thank a few people who’ve supported me throughout this journey: @Surjeet has been with me from day one - my Mentor, My coding partner - always encouraging me, brainstorming ideas, and helping me push through challenges. ❤️ @BHSY for testing and detailed logs were invaluable in improving shared memory handling. He shared a few panels with me for testing and those were mind blowing. 💓 @Loyd for the first one to test and sharing feedback to include a few updates we will see in the next build ❤️ And of course, the community’s feedback - including yours 😍 - keeps me motivated and moving forward. This project means a lot to me, and I’m genuinely grateful for the support and encouragement. I’m excited to keep improving SynQPanel together and continue enhancing the AIDA64 user's experience. SynQPanel is still early, but the momentum and community support are incredibly motivating. I’m looking forward to refining the experience and continuing to build something useful for the AIDA64 users. 🙏 Thank you again for the support and trust. 🙏 4 Quote
Surjeet Posted January 8 Posted January 8 6 hours ago, Kim Sahyeong said: i got a problem, SynQ tells me it can't read sensor, i have aida run on admin with shared memory ticked and i did reboot my pc i run aida 8.20.8100 p.s even if i don't have sensors, your software looks great, good job guys Hey, this issue is fixed in the following updated build: https://github.com/sursingh-hub/SynQPanel/releases/tag/v1.0.1-ImprovedSharedMem Please let us know how it went as she is constantly working on improving it from day 1 If you still face any issues, please send a private message to @GaHile and she may request and will check some logs to give you the best resolution 🖕 1 1 Quote
Kim Sahyeong Posted January 8 Posted January 8 4 hours ago, Surjeet said: Hey, this issue is fixed in the following updated build: https://github.com/sursingh-hub/SynQPanel/releases/tag/v1.0.1-ImprovedSharedMem Please let us know how it went as she is constantly working on improving it from day 1 If you still face any issues, please send a private message to @GaHile and she may request and will check some logs to give you the best resolution 🖕 it fixed the issue, thank you, didn't see there was another exe ont the github thank you 1 1 Quote
Surjeet Posted January 9 Posted January 9 16 hours ago, Kim Sahyeong said: it fixed the issue, thank you, didn't see there was another exe ont the github thank you You're welcome! 🙂 Great to know that the issue is fixed!! I hope you will enjoy using the software Yes, I agree......all these new exe are just pre-release for testing purpose. New v1.0.1 is coming really soon with many improvements, bug fixes and new features!! Stay Tuned!! @GaHile Thank you!!!! as we know that you are working very hard to polish the software and making it exactly the way we want to use/see/feel/handle it!! 2 Quote
Loyd Posted January 9 Posted January 9 On 1/4/2026 at 11:07 AM, GaHile said: 🚀 SynQPanel v1.0 – Public Preview Released Hello everyone, Following up on my earlier teaser, SynQPanel v1.0 (Public Preview) is now available. SynQPanel is a panel-based desktop visualization tool for AIDA64 users, focused on: clean layouts pixel-precise control secondary displays & always-on dashboards ✨ Highlights Uses AIDA64 Shared Memory Runs on Windows 10 / 11 Profile-based configurations Multiple visual elements (text, gauges, bars, tables) Small set of built-in add-ons for system & runtime context ⚖️ Licensing & Attribution Released under GNU GPL v3.0 or later Derived from an open-source project originally authored by Habib Rehman Since then significantly modified, extended, and independently maintained as SynQPanel AIDA64 is a registered trademark of FinalWire Ltd SynQPanel is not affiliated with or endorsed by FinalWire Ltd Source code & license details: 👉 https://github.com/sursingh-hub/SynQPanel ⬇️ Download Windows installer (Public Preview) Available under GitHub Releases 👉 https://github.com/sursingh-hub/SynQPanel/releases ⚠️ Security Notice (Please Read) SynQPanel is a new, unsigned application. Because of this, Windows SmartScreen or some antivirus tools may briefly scan the installer or display a warning during first launch. This is normal behavior for newly released software and does not indicate malware. Why this can happen SynQPanel legitimately accesses: Local configuration files AIDA64 shared memory System and hardware telemetry What to expect ✔ Installer completes successfully ✔ SynQPanel runs normally ✔ No warnings on subsequent launches Windows SmartScreen/Defender If Windows shows “Protected your PC”: Click More info → Run anyway to continue. Transparency: SynQPanel is fully open source, with complete source code available on GitHub. There are no hidden installers, background services, or bundled software. ⚙️ Enable AIDA64 Shared Memory (Required) SynQPanel requires AIDA64 Shared Memory. AIDA64 → Preferences → External Applications Enable: ✅ Shared Memory ✅ Writing sensor values to RivaTuner OSD ✅ Display labels Restart AIDA64 after applying changes. 🧪 Public Preview Notice This is a Public Preview release. Please: Keep backups of your original .sensorpanel, .spzip, or .sqx files Avoid editing your only copy of important panels Use test or duplicated panels when experimenting SynQPanel does not modify AIDA64 itself, but may save changes back to imported panel formats. Provided as-is, without warranty, as permitted under the GPL. 🙏 Final Words This project is shared in the spirit of learning, experimentation, and open-source collaboration. Feedback - positive or critical - is welcome. Thank you to the AIDA64 community for the inspiration over the years. __ SynQPanel contributors Working on a new panel just to try out this great program. couple of things...the selection area reverts to default when entering new items. I feel it should stay the same ie font type color size etc. That way you don't have to select all the info again and again and again. setting the defaults is a way around this but would be better to be able to select the way I want it to work. When entering gauges and I want more that one of the same gauge, I have to go thru the complete loading process instead of a copy paste. If I copy paste, change source the gauge does not work. problem? gifs work great, love the color gradient section. all in all a great add to AIDA64 Loyd 1 Quote
GaHile Posted January 9 Author Posted January 9 4 hours ago, Loyd said: Working on a new panel just to try out this great program. couple of things...the selection area reverts to default when entering new items. I feel it should stay the same ie font type color size etc. That way you don't have to select all the info again and again and again. setting the defaults is a way around this but would be better to be able to select the way I want it to work. When entering gauges and I want more that one of the same gauge, I have to go thru the complete loading process instead of a copy paste. If I copy paste, change source the gauge does not work. problem? gifs work great, love the color gradient section. all in all a great add to AIDA64 Loyd Hi @Loyd, Thank you for taking the time to share such thoughtful feedback. We’re really glad to hear you’re enjoying SynQPanel and exploring its features - insights like yours help us refine both usability and workflow. We completely understand the importance of minimizing repetitive steps when designing panels, and your observations are very valid. Default Font behavior In SynQ Gallery, once you select the panel you’re working on, the panel properties shown below allow you to set a Default Font Family and Default Font Size. These serve as global defaults for that specific panel. To help us improve this further, could you please clarify your expectation here? Would you prefer these defaults to automatically follow the last-used style, or should this behavior be more explicitly controlled by the user? Duplicating gauges / copy-paste Could you also let us know how you’re duplicating gauges? In SynQ Manager, just above the trash/delete icon, there is a “Duplicate selected item” option. We’ve tested this and confirmed that it properly clones the selected sensor/gauge. After duplicating, you can replace the sensor using the orange “Replace Selected Sensor” button. If this button appears disabled, please ensure: The cloned gauge is selected on the right, and The desired sensor is selected from the AIDA sensor list on the left. Once both are selected, the replacement should work as expected. If your experience differs, please let us know - we’ll be happy to investigate further. Side note: We’ve also fixed the issue you reported where system shortcuts in labels appeared as placeholders (e.g., $CPUModel, $GPU1Model). Thank you @BHSY for the following enhancements: - We have also added Right Click on Sensorpanels to show the ContextMenu - Close to Tray wen X button is pressed These fixes will be included in the next build. Thank you again for your feedback and encouragement. We truly appreciate your support and look forward to your thoughts. 1 Quote
Loyd Posted January 9 Posted January 9 Default Font behavior Personally I prefer the last-used style but to be able to select last used or default would be best. The choice should stay until changed or a reload. Duplicating gauges / copy-paste Could you also let us know how you’re duplicating gauges? Highlight the gauge, duplicate, move dup in place, change source if needed. this did not connect to the new source but it does in AIDA64 In SynQ Manager, just above the trash/delete icon, there is a “Duplicate selected item” option. We’ve tested this and confirmed that it properly clones the selected sensor/gauge. After duplicating, you can replace the sensor using the orange “Replace Selected Sensor” button. If this button appears disabled, please ensure: The cloned gauge is selected on the right, and The desired sensor is selected from the AIDA sensor list on the left. I did this and the new sensor did not work I modify a lot of panels to fit my 1600X1200 display and use this cut and paste sensor frequently as I take a 1024X600 sensor, change to 1600X900. then add a 1600X300 panel to fill it out either by cutting part of the original image or adding the gauges. The image below was 1336X768 and now is 1600X1200. will fill-in the bottom with sensors Loyd Quote
GaHile Posted January 9 Author Posted January 9 1 hour ago, Loyd said: Duplicating gauges / copy-paste Could you also let us know how you’re duplicating gauges? Highlight the gauge, duplicate, move dup in place, change source if needed. this did not connect to the new source but it does in AIDA64 In SynQ Manager, just above the trash/delete icon, there is a “Duplicate selected item” option. We’ve tested this and confirmed that it properly clones the selected sensor/gauge. After duplicating, you can replace the sensor using the orange “Replace Selected Sensor” button. If this button appears disabled, please ensure: The cloned gauge is selected on the right, and The desired sensor is selected from the AIDA sensor list on the left. I did this and the new sensor did not work Hi @Loyd, Thank you for flagging this. You’re absolutely right - during the code update, I accidentally impacted the Replace and Duplicate button logic. My sincere apologies for the inconvenience caused!! 😢 I’ve now reproduced and identified the issue and am already working on the fix. I’ll resolve this on priority and share the updated executable with you very shortly. Thank you for your patience and understanding! I really appreciate that you found this at an early stage 🙏🫡 Regarding Default Font Behavior: Let me check what we can safely include !! Quote
GaHile Posted January 10 Author Posted January 10 @BHSY @Loyd and Hi Everyone, I am excited to announce 🎤 that 🎉SynQPanel v1.0.1 is now available.🎉 This update fixes shared memory truncation issues, improves diagnostics, adds SensorPanel right-click actions, close-to-tray support (Enable in Settings), and implements AIDA-style $LABEL macro resolution (e.g. $CPUMODEL, $GPU1MODEL). Thank you to the AIDA team and community for feedback and logs that helped refine this release. 🙏 The update is available on GitHub here: https://github.com/sursingh-hub/SynQPanel/releases/tag/v1.0.1 Feedback and suggestions are always welcome. 🙏 Thank you again for the support! 🙏 3 Quote
Loyd Posted January 10 Posted January 10 2 hours ago, GaHile said: @BHSY @Loyd and Hi Everyone, I am excited to announce 🎤 that 🎉SynQPanel v1.0.1 is now available.🎉 This update fixes shared memory truncation issues, improves diagnostics, adds SensorPanel right-click actions, close-to-tray support (Enable in Settings), and implements AIDA-style $LABEL macro resolution (e.g. $CPUMODEL, $GPU1MODEL). Thank you to the AIDA team and community for feedback and logs that helped refine this release. 🙏 The update is available on GitHub here: https://github.com/sursingh-hub/SynQPanel/releases/tag/v1.0.1 Feedback and suggestions are always welcome. 🙏 Thank you again for the support! 🙏 "implements AIDA-style $LABEL macro resolution (e.g. $CPUMODEL, $GPU1MODEL)." just how does this work? could not get it working. also the names of the imported files are some sort of date function taken from the file I guess. any way we could rename the file box? Loyd 1 Quote
BHSY Posted January 10 Posted January 10 (edited) 10 hours ago, GaHile said: @BHSY @Loyd and Hi Everyone, I am excited to announce 🎤 that 🎉SynQPanel v1.0.1 is now available.🎉 This update fixes shared memory truncation issues, improves diagnostics, adds SensorPanel right-click actions, close-to-tray support (Enable in Settings), and implements AIDA-style $LABEL macro resolution (e.g. $CPUMODEL, $GPU1MODEL). Thank you to the AIDA team and community for feedback and logs that helped refine this release. 🙏 The update is available on GitHub here: https://github.com/sursingh-hub/SynQPanel/releases/tag/v1.0.1 Feedback and suggestions are always welcome. 🙏 Thank you again for the support! 🙏 Hi GaHile, so far, I’ve run into one issue: the font style isn’t working. I tested with a common font, Arial, selected Bold, and Italic, but nothing changed. The same problem occurs with other fonts as well.😟 The right‑click actions and the close‑to‑tray feature are working perfectly. 👍 Regarding $LABEL, no issue when I import a new .spzip panel. However, my existing .sqx panel with no name label was not updated. I need to reimport the .spzip panel and re-add the videos. Is there any way to update it from SynQPanel? One question: if I changed to a new CPU, will $LABEL automatically update with the new processor name? I assume it will, since SynQPanel shares memory with AIDA. Thanks. Edited January 11 by BHSY 1 Quote
