steve.vukelich Posted August 1 Posted August 1 4 hours ago, lifter said: Where can I find the Images 0-59 for the flip panel. I looked in Local in assets nothing there or in program (86). When in manager Trying to create it . Says no images and the location it is trying to go to I do not have that asset number Go to Flip clock Images - Free Download on Magnific (formerly Freepik) Quote
lifter Posted August 2 Posted August 2 Anyone have a zip file with Flip Numbers they could send me. Lifterjack@yahoo.com Quote
Surjeet Posted August 2 Posted August 2 36 minutes ago, lifter said: Anyone have a zip file with Flip Numbers they could send me. Lifterjack@yahoo.com Please check your inbox. Keep the numbers name same as 0 to 9 only! Direct/browse to this folder and you will have the working flip clock easily! Quote
lifter Posted August 23 Posted August 23 On 8/2/2026 at 9:43 AM, lifter said: Anyone have a zip file with Flip Numbers they could send me. Lifterjack@yahoo.com Does anyone have the flip numbers with Month, Day, and Day of the week Name, also year. Thanks Quote
Surjeet Posted August 24 Posted August 24 20 hours ago, lifter said: Does anyone have the flip numbers with Month, Day, and Day of the week Name, also year. Thanks I think Month, Day, and Day of the week Name, and year are not supported by Flip function yet! Quote
lifter Posted August 25 Posted August 25 On 8/24/2026 at 6:05 AM, Surjeet said: I think Month, Day, and Day of the week Name, and year are not supported by Flip function yet! It looks looks like BHSY on tab 4 has done it. Quote
BHSY Posted August 26 Posted August 26 46 minutes ago, lifter said: It looks looks like BHSY on tab 4 has done it. The month, day, and week are shown as static digital image sensors, acting as fixed readouts rather than flip mechanisms. They update once at midnight, so there is no functional reason to use them as flipping displays. Quote
pricls Posted August 27 Posted August 27 它的资源使用正常吗?透明背景可能占用10%的GPU,OpenGL约占3%——除非目标帧率设置为1。然而,AIDA64内置的系统对性能完全没有影响。 勾选OpenGL选项时,透明背景变成黑色。我需要一个透明背景来配合壁纸,但我又不想让它影响到我的游戏 Quote
GaHile Posted August 29 Author Posted August 29 On 8/27/2026 at 3:00 PM, pricls said: Is its resource usage normal? A transparent background can consume 10% of the GPU, and OpenGL around 3%—unless the target framerate is set to 1.The one built into AIDA64, however, manages to have absolutely no impact on performance. Checking the OpenGL option the transparent background turns black. I need a transparent background to use with my wallpaper, but I don't want it to interfere with my gaming—what should I do? Yes, that’s normal for now, so please don’t worry. 😊 We’ll continue improving this in future updates. Regarding the transparent background, did you experience the same issue when running without OpenGL? If so, I can dig deeper into it in my test lab and see what we can do to improve it. 👍 Thanks again for the feedback - it really helps us identify these edge cases and make the experience better. 🙏 Quote
GaHile Posted August 29 Author Posted August 29 Hey hey hey! 😄 It’s a little too quiet in here… Come on, guys - let’s make some noise! 🔥📣 @Loyd Thank you so much for your continuous support. It truly means a lot! 🙏 I hope you’ve had a chance to test the Sensors Order in SynQ Manager and verify that it’s being saved in the same order as the sensors are added, including when any movement/changes are made up/down. @BHSY Thank you for all the testing, feedback, and amazing ideas that keep the ball rolling! 🚀 I really appreciate your support, guidance, and all the effort you’re putting in to keep this moving forward. @Surjeet No “thank you” for you haha! 😂 As you already know, you’ve been making everything possible behind the scenes since Day One. LOL! 🙌 @Everyone - Now I want to hear from all of you! 👀 What would you like to see next in SynQPanel? What new features, ideas, or possibilities should we explore? Let me kick things off with my first point: 1. Open up Add-ons! I’m going to work on making Add-ons open so anyone can build and add their own add-ons to SynQPanel. The possibilities are endless! 🔥 Thanks again, everyone, for the feedback and support. It genuinely helps us uncover real-world use cases, identify edge cases, and keep making the experience better for everyone. 🙏 Now… don’t be shy - let’s hear those ideas! 😄 1 1 Quote
lifter Posted September 5 Posted September 5 In Aida64 I am Showing my 21 Hard Drives but in SynQPanel I am showing only 13 of those Drives. Is there a remedy. Quote
