  • Fiery changed the title to 12V-2x6 monitoring on Thermal Grizzly WireView Pro II
Hi!
I just saw that the latest beta version includes the wireview II sensors which is great! But somehow i am to stupid to find them...can anybody help?
Best
Nils
Not yet if I'm not mistaken. Read somewhere they're implementing support for wireview pro 2 if I'm not mistaken. Does anyone know if it's true and when it should be available?
On 2/26/2026 at 11:24 PM, Skinny12 said:
Hi!
Best
Nils
We are already working on it...
  • Like 2
@Skinny12 @Kleimo @Tanis53 @braintez @ParisV
We've implemented support for Thermal Grizzly WireView Pro II in the latest AIDA64 beta update available at:
  • Like 3
I attempted to modify my panel tonight and it appears that just the power values for the device are being captured (see screenshot).  What I, and I think others that are interested in seeing, are the current values per pin.
It could be that the device isn't detected perhaps?  Is there anything that has to be enabled to see these values?  If the device is indeed detected, is there a way to enable a view of the current for each pin?
Where did you find these? I dont even see them and no setting for wireview.
Can you see the voltage and current readings similarly labelled on the Computer / Sensor page of AIDA64?
Apologies, error on my side.  I had to reseat the device before the current values were detected.
Although I'm able to see the sensors and add them to my panel, I do notice that when I open the Aida app from the taskbar or even after a few minutes, the sensors disappear.  Refreshing sensors and restarting both Wireview and Aida doesn't fix it, nor does closing Wireview so that Aida is the only app running.  A reboot seems to be the only way to restore them.
As in the previous screenshot, they'll be labeled "Power Monitor #1 - #6".  There are also entries for Total Power, Total Current and Power by Pin using the same nomenclature.  I had to unplug and reseat the device before they were detected in Aida.
Windows reboot seems to fix them not showing to me. But those two temperatures do not show up in external application list.
wireview_aida64.thumb.jpg.ad12fe2aec5e69cbf759c077c03a2038.jpgwireview_aida64_external.thumb.jpg.85a8f48ffd6aafc4017d61aef5a54905.jpg
They should be there as Temperature #1 and Temperature #2 in your case.
15 hours ago, Fatso666 said:
I updated to the beta and restarted but they're not showing up for me. Do I need to enable something elsewhere first?
I'm not sure if you have Thermal Grizzly's own software running.  That software may collide with AIDA64, so try to close it and check it again.
Tried closing all other monitoring software so this is all I have left but it is still not showing up in AIDA64
I've got HWInfo and Rivatuner installed with the plugin for Thermal Grizzly into HWInfo, but they were closed to see if that would make the Wireview readings appear into AIDA64
Edit: Uninstalling Sensorpanel made the Wireview Pro show up now
Just purchased an Aida64 Extreme license a few days ago and got my Wireview 2 Pro showing up in the current beta version. For some reason it's disappeared the WV2 doesn't show up under sensors anymore. Thermal Grizzly software not running. Hwinfo not running. Only Riva tuner and MSI afterburner is running. Sensors do work bec Hwinfo and Thermal Grizzly software do see the device when I run them. System reboots do not help. Completely killing power to pc for a bit and turning it back on does not help.
Could the live Aida version that I was running before beta and then uninstalled be clashing with the beta version? Is there a way to clean uninstall and try again?
Any feedback would be appreciated.
Clashing shouldn't be an issue.  Did you do anything to your WireView device between the two attempts?  Maybe updating its firmware?
It works, BUT, the same as with HWInfo, there are USB disconnects when multiple sources try to get information from the WireView 2.
Also, when you have "fast startup" enabled on Windows 11, the connection is not possible anymore, until you reboot, or turn off fast startup.
I know HWInfo fixed this issue, but i'm not sure how. When every monitoring accessing this information is turned off, it will most likely work.
@fip00 can you try to turn off fast startup, turn off auto-start off the wireview software, and possibly HWInfo? My biggest guess is it will start working again.
@Fiery can you look into this?
