Crimson Posted February 3, 2011 Share Posted February 3, 2011 The CPU temperature is incorrect. The core temperatures are OK, the values are identical with CoreTemp results, but the CPU temperature is incorrect. While the cores are about 30 degrees C each, the CPU temperature reads 128 degrees C. When I stress the CPU, the core temps rise but the CPU temp stays fixed at 128 degrees. At first I thought that CPU shows the sum of the 4 core temps, but definitely this is not the case. My CPU is an Athlon II X4 605e. The M/B is an Asus M4A88TD-M/USB3. I'm running AIDA64 Extreme v1 50.1200 on Windows 7 Home Premium x64. Quote Link to comment Share on other sites More sharing options...
Fiery Posted February 3, 2011 Share Posted February 3, 2011 1) Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. 2) Also copy-paste the full content of the Computer / Sensor page of AIDA64 into this topic. Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
Crimson Posted February 3, 2011 Author Share Posted February 3, 2011 ISA sensor dump content: The CPU temperature seems to be correct here, but the stability test graph and statistics are still showing 128 degrees. ------[ AIDA64 v1.50.1200 ]------ ------[ Microsoft Windows 7 Home Premium 6.1.7600 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 65-0601-000001-00101111-061010-RS880_SB850$A1642001_BIOS DATE: 06/10/10 21:28:10 VER: 06.01 Motherboard Model : Asus M4A88TD-M/USB3 Motherboard Chipset : AMD 880G, AMD K10 DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : M4A88TD-M/USB3 DMI MB Version : Rev X.0x DMI MB Serial : MT7008049601204 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 0601 ITE 87xx Port = 2Eh ITE 87xx HWMonitor Port = 0290h ITE 87xx Device ID = 8721h ITE 87xx Version = 03h Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port = 0000h Winbond SuperIO Device ID = FFFFh Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h Fintek SuperIO Device ID = 0000h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = FFFFh ------[ LM78 ISA Sensor Device at 0290 ]------ 0000 11 06 FF 03 37 FF 07 37 FF 07 58 0F 03 91 FF FF 0010 5B 04 15 7F C7 80 80 80 01 FF FF 12 00 90 90 90 0020 F0 EB 47 8B 10 DE A8 08 8D 28 2D 80 80 C0 42 42 0030 00 18 E5 50 94 E5 48 06 12 80 A1 98 66 15 E3 09 0040 19 90 2A 91 85 B1 5F 40 AD 6A D4 00 FF FF FF FF 0050 27 18 7F 7F 7F 40 56 56 90 56 38 12 E0 00 00 00 0060 80 14 5A 33 A0 41 00 FF 80 00 7F FF 00 41 00 FF 0070 80 00 7F FF 00 41 00 FF FF FF FF FF FF FF FF FF 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 F1 02 AC 0090 32 17 20 00 FF 00 00 00 FF FF FF FF FF FF FF FF 00A0 AC 07 07 07 07 07 07 FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Reg$20 CPU Core: r = 240, r*0.016 = 3.84 Reg$21 CPU Aux: r = 235, r*0.016 = 3.76 Reg$22 +3.3 V: r = 71, r*0.016 = 1.14 Reg$23 +5 V: r = 139, r*0.016 = 2.22 Reg$24 +12 V: r = 16, r*0.016 = 0.26 Reg$25 -12 V: r = 222, r*0.016 = 3.55 Reg$26 -5 V: r = 168, r*0.016 = 2.69 ------[ SB7xx/8xx PM2 at 0CD0 ]------ 0000 01 1E F7 E0 BE 4F FB 90 53 9D AB A9 10 80 FF FF 0010 02 1F F7 6E BE 4F FB 90 53 9D AB A9 10 80 FF FF 0020 06 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 0030 06 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 0040 06 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0060 1F 00 00 00 00 00 01 00 00 FF FF 01 00 00 FF FF 0070 01 00 00 FF FF 01 00 00 FF FF 01 00 00 FF FF FF 0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0090 1F 55 01 00 00 C0 A0 00 00 00 00 00 00 C0 35 00 00A0 00 80 12 00 00 00 00 00 00 FF FF FF FF FF FF FF 00B0 43 FF 45 55 FF 00 00 FF C0 FF 00 00 C0 02 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 C0 FF 00 00 00 00 00 00 FF FF FF FF FF FF FF FF 00E0 03 00 00 00 00 00 02 00 00 FF 86 1F 01 00 00 02 00F0 19 0A 02 05 C8 20 80 00 05 06 00 00 08 08 00 42 Reg$59VIN0: r = $FFFF, r*0.000046 = 3.0146 Reg$5DVIN1: r = $FFFF, r*0.000046 = 3.0146 Reg$61VIN2: r = $0000, r*0.000046 = 0.0000 Reg$65VIN3: r = $0100, r*0.000046 = 0.0118 Reg$69VIN4: r = $FFFF, r*0.000046 = 3.0146 Reg$6DVIN5: r = $FF00, r*0.000046 = 3.0029 Reg$71VIN6: r = $0000, r*0.000046 = 0.0000 Reg$75VIN7: r = $0001, r*0.000046 = 0.0000 ------[ SB7xx/8xx PM at 0CD6 ]------ 0000 0E 00 4F 4A 00 04 00 02 34 05 04 02 06 21 43 55 0010 FF 0F 00 00 FF 0F 00 00 00 00 00 00 00 00 00 00 0020 00 00 D1 FE 01 00 D8 FE 25 0B 00 00 01 0B 00 00 0030 00 00 00 00 07 00 C0 FE 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 C0 F1 00 C0 FE 03 00 00 00 0050 1F 00 D0 FE 90 00 00 97 01 FF 10 66 00 05 00 06 0060 00 08 04 08 08 08 10 08 20 08 B0 00 00 FE B8 00 0070 00 00 00 00 17 00 00 04 FF FF 00 00 85 01 E0 A0 0080 1F 1A 00 20 00 00 00 00 30 10 00 00 9E 00 80 00 0090 02 05 02 0B 01 00 10 00 00 10 00 10 19 92 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 0B 05 05 08 00 08 40 02 00 51 00 00C0 F9 03 58 40 3C 02 00 00 0C 40 28 00 FF FF FF FF 00D0 00 00 30 00 00 00 00 00 15 00 91 00 01 00 10 03 00E0 D8 0C 00 00 00 00 00 02 00 00 00 00 03 12 00 7F 00F0 9C 03 00 00 00 00 00 21 6C 27 00 00 00 00 00 00 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : ------[ Asus ATK0110 ]------ Motherboard ID: M4A88TD-M-USB3 ICPU/VCPU/PCPU: 0 / 0 / 0 CPU Temperature : 40.0 C MB Temperature : 45.0 C CHASSIS FAN Speed : 0 RPM CPU FAN Speed : 1683 RPM +12 Voltage : 11.980 V +3.3 Voltage : 3.327 V +5 Voltage : 4.935 V Vcore Voltage : 1.080 V CPU Temperature : 40.0 C MB Temperature : 45.0 C Chassis Fan Speed : 0 RPM CPU Fan Speed : 1683 RPM +12V Voltage : 11.980 V +3.3V Voltage : 3.336 V +5V Voltage : 4.935 V Vcore Voltage : 1.080 V CPU Voltage : 1075000 V CPU/NB Voltage : 1100000 V DRAM Voltage : 1.54500 V GPU Voltage : 1.25000 V HT Voltage : 1.20000 V NB1.8 Voltage : 1.800 V SB Voltage : 1.100 V VDDA Voltage : 2.50000 V CPU Frequency : 200.00 MHz GPU Engine Clock : 200.00 MHz GPU Pstate : 0.00 MHz GPU SidePort Clock: 1333.00 MHz GPU switch Pstate : 0.00 MHz DRAM Frequency : 1333 MHz CPU Ratio : 11.5x Quote Link to comment Share on other sites More sharing options...
Crimson Posted February 3, 2011 Author Share Posted February 3, 2011 sensor report: Sensor Properties: Sensor Type ITE IT8721F (ISA 290h) GPU Sensor Type Diode (ATI-Diode) Chassis Intrusion Detected No Temperatures: Motherboard 45 °C (113 °F) CPU #1 / Core #1 29 °C (84 °F) CPU #1 / Core #2 29 °C (84 °F) CPU #1 / Core #3 29 °C (84 °F) CPU #1 / Core #4 29 °C (84 °F) Aux 40 °C (104 °F) GPU Diode 55 °C (131 °F) OCZ-AGILITY2 1 °C (34 °F) SAMSUNG HD103SJ 36 °C (97 °F) Cooling Fans: CPU 1683 RPM GPU 37% Voltage Values: CPU Core 0.852 V +3.3 V 3.336 V +5 V 4.935 V +12 V 11.981 V Debug Info F 0191 FFFF FFFF 0000 0000 Debug Info T 40 45 128 Debug Info V F0 EB 47 8B 10 DE A8 08 8D --------[ Debug - PCI ]------------------------------------------------------------------------------------------------- B00 D00 F00: AMD RS780/RS880 Chipset - Host Bridge Offset 000: 22 10 01 96 06 00 30 22 00 00 00 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 3E 84 Offset 030: 00 00 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 08 9C 00 C0 C1 00 00 00 37 00 00 00 42 20 05 00 Offset 050: 43 10 3E 84 08 40 00 90 08 10 05 00 08 00 00 00 Offset 060: 3C 00 00 00 00 00 00 00 00 02 20 00 0B C0 86 81 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 20 Offset 080: 00 00 00 00 10 00 00 03 20 D4 00 00 31 20 00 00 Offset 090: 00 00 00 D0 7F 00 00 00 00 00 00 00 08 F8 7C D0 Offset 0A0: 26 00 66 00 00 00 00 80 00 00 00 00 79 01 C0 07 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 80 08 54 80 01 20 10 11 11 D0 00 00 00 Offset 0D0: 60 0B 75 1E 02 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 FF FF FF FF F0 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 80 80 00 08 00 00 E0 00 00 00 00 B00 D02 F00: AMD RS780/RS880 Chipset - PCI Express Graphics Port 0 Offset 000: 22 10 03 96 07 01 10 00 00 00 04 06 10 00 01 00 Offset 010: 00 00 00 00 00 00 00 00 00 01 01 00 B1 B1 00 20 Offset 020: 90 FE 90 FE 01 D0 F1 DF 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 12 01 1B 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00 Offset 060: 10 08 00 00 02 0D 30 00 40 00 02 F1 80 25 14 00 Offset 070: 00 00 48 01 00 00 01 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 42 00 01 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 05 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 0D B8 00 00 43 10 3E 84 08 00 03 A8 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D07 F00: AMD RS780/RS880 Chipset - PCI Express Port 3 Offset 000: 22 10 07 96 06 01 10 00 00 00 04 06 10 00 01 00 Offset 010: 00 00 00 00 00 00 00 00 00 02 02 00 F1 01 00 20 Offset 020: A0 FE A0 FE F1 FF 01 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 13 01 07 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00 Offset 060: 10 08 00 00 12 0C 30 04 40 00 12 F0 80 0C 3C 00 Offset 070: 00 00 48 01 00 00 01 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 42 00 01 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 05 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 0D B8 00 00 43 10 3E 84 08 00 03 A8 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D09 F00: AMD RS780/RS880 Chipset - PCI Express Port 4 Offset 000: 22 10 08 96 07 01 10 00 00 00 04 06 10 00 01 00 Offset 010: 00 00 00 00 00 00 00 00 00 03 03 00 C1 C1 00 20 Offset 020: B0 FE B0 FE F1 FF 01 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 11 01 07 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00 Offset 060: 10 08 00 00 12 0C 30 00 40 00 11 70 80 0C 4C 00 Offset 070: 00 00 48 01 00 00 01 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 42 00 01 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 05 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 0D B8 00 00 43 10 3E 84 08 00 03 A8 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D0A F00: AMD RS780/RS880 Chipset - PCI Express Port 5 Offset 000: 22 10 09 96 07 01 10 00 00 00 04 06 10 00 01 00 Offset 010: 00 00 00 00 00 00 00 00 00 04 04 00 D1 D1 00 00 Offset 020: F0 FF 00 00 F1 FD F1 FD 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 12 01 07 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 58 03 C8 00 00 00 00 10 A0 42 01 20 80 00 00 Offset 060: 10 08 00 00 12 0C 30 01 40 00 11 70 80 0C 54 00 Offset 070: 00 00 48 01 00 00 01 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 42 00 01 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 05 B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 0D B8 00 00 43 10 3E 84 08 00 03 A8 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D11 F00: ATI SB800 - SATA AHCI Controller Offset 000: 02 10 91 43 07 01 30 02 40 01 06 01 10 40 00 00 Offset 010: 01 A0 00 00 01 90 00 00 01 80 00 00 01 70 00 00 Offset 020: 01 60 00 00 00 FC 8F FE 00 00 00 00 43 10 43 84 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 13 01 00 00 Offset 040: 10 80 80 00 01 00 20 00 00 00 80 00 00 00 00 00 Offset 050: 05 70 84 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 01 50 22 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 12 A4 10 00 0F 00 00 00 38 01 00 00 00 00 00 00 Offset 080: 00 00 00 00 06 1A 14 00 AB 01 08 00 F0 00 00 00 Offset 090: 27 60 74 C7 02 43 06 00 00 01 00 00 01 58 B1 02 Offset 0A0: 0C 00 00 00 13 00 06 03 00 00 64 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 Offset 0E0: 80 00 00 00 00 00 00 00 00 00 00 00 10 00 00 3F Offset 0F0: 00 00 00 00 00 00 00 00 77 77 77 00 00 00 F0 CF B00 D12 F00: ATI SB800 - OHCI USB Controller Offset 000: 02 10 97 43 16 01 A0 02 00 10 03 0C 10 40 80 00 Offset 010: 00 E0 8F FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 43 84 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00 Offset 040: 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 40 00 00 F0 00 00 00 00 10 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D12 F02: ATI SB800 - EHCI USB 2.0 Controller Offset 000: 02 10 96 43 06 01 B0 02 00 20 03 0C 10 40 00 00 Offset 010: 00 F8 8F FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 43 84 Offset 030: 00 00 00 00 C0 00 00 00 00 00 00 00 11 02 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 40 21 80 A0 01 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 20 00 00 01 00 00 00 00 00 00 00 00 Offset 0A0: 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D13 F00: ATI SB800 - OHCI USB Controller Offset 000: 02 10 97 43 16 01 A0 02 00 10 03 0C 10 40 80 00 Offset 010: 00 D0 8F FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 43 84 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00 Offset 040: 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 40 00 00 F0 00 00 00 00 32 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D13 F02: ATI SB800 - EHCI USB 2.0 Controller Offset 000: 02 10 96 43 06 01 B0 02 00 20 03 0C 10 40 00 00 Offset 010: 00 F4 8F FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 43 84 Offset 030: 00 00 00 00 C0 00 00 00 00 00 00 00 11 02 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 40 21 80 A0 01 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 20 00 00 01 00 00 00 00 00 00 00 00 Offset 0A0: 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D14 F00: ATI SB800 - SMBus Controller Offset 000: 02 10 85 43 03 04 20 02 42 00 05 0C 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D14 F01: ATI SB800 - IDE Controller Offset 000: 02 10 9C 43 05 00 30 02 40 8A 01 01 00 00 00 00 Offset 010: 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00 Offset 020: 01 FF 00 00 00 00 00 00 00 00 00 00 43 10 43 84 Offset 030: 00 00 00 00 70 00 00 00 00 00 00 00 00 02 00 00 Offset 040: 99 20 00 00 FD 20 80 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 Offset 070: 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D14 F03: ATI SB800 - PCI-LPC Bridge Offset 000: 02 10 9D 43 0F 00 20 02 40 00 01 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 43 84 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 04 00 00 00 43 C0 03 FF 17 FF 40 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 30 02 00 00 0E 00 0F 00 E0 FF FF FF Offset 070: 67 45 00 00 00 00 00 00 1C 00 00 00 05 0A 00 00 Offset 080: 08 00 03 A8 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 01 10 D6 FE Offset 0A0: 02 00 C1 FE 2E 01 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 09 39 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D14 F04: ATI SB800 - PCI-PCI Bridge Offset 000: 02 10 84 43 07 05 A0 02 40 01 04 06 00 40 81 00 Offset 010: 00 00 00 00 00 00 00 00 00 05 05 40 E0 E0 80 22 Offset 020: F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 Offset 040: 26 00 04 FF 00 00 00 00 0C 0F 3D D1 00 01 00 00 Offset 050: 01 00 00 00 08 00 03 A8 00 00 00 00 85 00 FF FF Offset 060: CA 0E 17 00 BA 98 10 02 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 01 00 02 06 Offset 0E0: 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D14 F05: ATI SB800 - OHCI USB Controller Offset 000: 02 10 99 43 16 01 A0 02 00 10 03 0C 10 40 00 00 Offset 010: 00 C0 8F FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 43 84 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00 Offset 040: 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 40 00 00 F0 00 00 00 00 FF FF FF FF 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D16 F00: ATI SB800 - OHCI USB Controller Offset 000: 02 10 97 43 16 01 A0 02 00 10 03 0C 10 40 80 00 Offset 010: 00 70 8F FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 43 84 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00 Offset 040: 80 01 00 F0 11 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 40 00 00 F0 00 00 00 00 54 06 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 10 01 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D16 F02: ATI SB800 - EHCI USB 2.0 Controller Offset 000: 02 10 96 43 06 01 B0 02 00 20 03 0C 10 40 00 00 Offset 010: 00 F0 8F FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 43 84 Offset 030: 00 00 00 00 C0 00 00 00 00 00 00 00 11 02 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 40 21 80 A0 01 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 20 00 00 01 00 00 00 00 00 00 00 00 Offset 0A0: 01 00 00 00 00 20 00 C0 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 01 E4 02 7E 00 00 40 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 0A 00 E0 20 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D18 F00: AMD K10 - HyperTransport Technology Configuration Offset 000: 22 10 00 12 00 00 10 00 00 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00 Offset 050: 01 02 04 00 01 02 04 00 01 02 04 00 01 02 04 00 Offset 060: 00 00 03 00 E0 00 00 00 20 A8 4F 00 20 F8 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 08 00 01 21 20 30 11 11 60 0B F5 8F 13 00 00 00 Offset 090: CF 02 85 80 00 00 02 00 07 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D18 F01: AMD K10 - Address Map Offset 000: 22 10 01 12 00 00 00 00 00 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 03 00 00 00 00 00 2F 01 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 03 0A 00 00 00 0B 00 00 03 00 D0 00 00 FF DF 00 Offset 0B0: 03 00 E0 00 80 FF EF 00 03 00 F0 00 00 DF FF 00 Offset 0C0: 13 10 00 00 00 F0 FF 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 03 00 00 07 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 03 30 00 D0 00 00 00 00 00 00 00 00 00 00 00 00 B00 D18 F02: AMD K10 - DRAM Controller Offset 000: 22 10 02 12 00 00 00 00 00 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: E0 3F 78 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 06 00 48 0D 50 00 02 18 Offset 080: 07 00 00 00 D4 00 24 00 45 96 16 00 55 79 32 00 Offset 090: 00 00 01 00 0D 09 48 3F 20 00 00 80 A0 00 A9 00 Offset 0A0: 00 02 00 00 00 00 00 00 40 00 00 00 00 00 00 00 Offset 0B0: 22 F1 7E D8 21 00 00 00 8F 78 01 82 50 EB 07 80 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: FE D3 81 9A 4F A0 82 F3 BC 2F 8E FC 92 EC C1 B3 Offset 0E0: 6C 0C AE 47 D8 54 5B 91 89 3F 40 5B A4 44 6A 23 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 110: C4 05 00 00 00 00 00 00 24 A4 40 04 F8 0F E0 2C Offset 120: 94 00 45 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 130: 36 90 81 07 14 49 0D 6B 13 37 C6 AC 13 79 9C 8E Offset 140: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 160: E0 3F 78 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 170: 00 00 00 00 00 00 00 00 06 00 C8 0D 50 00 02 18 Offset 180: 07 00 00 00 D4 00 24 00 45 96 16 00 66 B9 32 00 Offset 190: 00 00 01 00 0D 09 48 3F 07 03 00 80 00 00 00 00 Offset 1A0: 00 02 00 00 00 00 00 00 40 00 00 00 00 00 00 00 Offset 1B0: 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D18 F03: AMD K10 - Miscellaneous Control Offset 000: 22 10 03 12 00 00 10 00 00 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 Offset 040: FF FF FF 3F 5C 00 B0 4A 00 00 00 00 00 00 00 00 Offset 050: 20 7F 2E FC BB 59 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 05 62 5F 34 00 00 00 30 51 80 01 60 Offset 070: 51 11 32 60 01 01 98 00 14 0C 20 00 0D 08 07 00 Offset 080: 81 E6 0B E6 E6 41 E6 01 08 00 00 00 00 60 58 42 Offset 090: 00 00 00 00 4B 0A 00 00 50 9E ED 4B 00 00 00 00 Offset 0A0: B2 08 09 B0 EF 0F 48 1F 0C 07 04 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 26 0F 81 C8 15 24 38 03 38 53 27 00 Offset 0E0: 00 00 00 00 30 14 C0 1D 59 7F 07 00 00 00 00 00 Offset 0F0: 0F 00 10 00 00 00 00 00 00 00 00 00 53 0F 10 00 B00 D18 F04: AMD K10 - Link Control Offset 000: 22 10 04 12 00 00 00 00 00 00 00 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B01 D00 F00: ATI Radeon HD 5670 (Redwood) Video Adapter Offset 000: 02 10 D8 68 07 05 10 00 00 00 00 03 10 00 80 00 Offset 010: 0C 00 00 D0 00 00 00 00 04 00 9E FE 00 00 00 00 Offset 020: 01 B0 00 00 00 00 00 00 00 00 00 00 4B 17 71 E1 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 4B 17 71 E1 Offset 050: 01 58 03 06 00 00 00 00 10 A0 12 00 A1 8F 2C 01 Offset 060: 10 29 09 00 02 0D 00 00 40 00 02 11 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 1F 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 02 00 01 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 05 00 81 00 0C F0 E0 FE 00 00 00 00 B0 49 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B01 D00 F01: ATI Redwood/Madison - High Definition Audio Controller Offset 000: 02 10 60 AA 06 01 10 00 00 00 03 04 10 00 80 00 Offset 010: 04 C0 9B FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 4B 17 60 AA Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 13 02 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 4B 17 60 AA Offset 050: 01 58 03 06 00 00 00 00 10 A0 12 00 A1 8F 2C 01 Offset 060: 10 29 09 00 02 0D 00 00 40 00 02 11 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 1F 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B02 D00 F00: NEC uPD720200 USB 3.0 Host Controller Offset 000: 33 10 94 01 06 05 10 00 03 30 03 0C 10 00 00 00 Offset 010: 04 E0 AF FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 13 84 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 70 C3 C9 08 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 30 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 05 90 86 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 11 A0 07 80 00 10 00 00 80 10 00 00 00 00 00 00 Offset 0A0: 10 00 02 00 C0 8F 00 00 00 28 19 00 12 EC 07 00 Offset 0B0: 40 01 12 10 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 10 08 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: FC 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 08 14 60 00 00 00 00 00 00 00 00 00 00 00 00 00 B03 D00 F00: VIA PATA Controller Offset 000: 06 11 15 04 05 01 10 00 00 85 01 01 10 00 00 00 Offset 010: 01 CC 00 00 81 C8 00 00 01 C8 00 00 81 C4 00 00 Offset 020: 01 C4 00 00 00 00 00 00 00 00 00 00 43 10 8F 83 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 11 01 00 00 Offset 040: 00 00 00 00 FF 10 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 70 03 76 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 04 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 05 90 80 01 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 10 00 11 00 00 80 64 00 00 20 09 00 11 4C 03 00 Offset 0A0: 40 00 11 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: A8 A8 33 B6 07 07 00 00 00 00 00 00 01 00 00 00 Offset 0D0: 30 00 09 00 00 02 00 00 02 01 00 00 8A 13 12 00 Offset 0E0: 8E 46 12 00 8A 13 12 00 8E 46 12 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B04 D00 F00: Realtek RTL8168/8111 PCI-E Gigabit Ethernet Adapter Offset 000: EC 10 68 81 07 05 10 00 06 00 00 02 10 00 00 00 Offset 010: 01 D8 00 00 00 00 00 00 0C F0 FF FD 00 00 00 00 Offset 020: 0C 80 FF FD 00 00 00 00 00 00 00 00 43 10 32 84 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00 Offset 040: 01 50 C3 FF 08 01 00 00 00 00 00 00 00 00 00 00 Offset 050: 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 10 B0 02 02 C1 8C 64 00 00 50 10 00 11 3C 07 00 Offset 080: 40 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 10 00 00 00 10 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 11 D0 03 80 04 00 00 00 04 08 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B05 D05 F00: C-Media CMI8788 Audio Chip Offset 000: F6 13 88 87 05 01 10 02 00 00 01 04 00 20 00 00 Offset 010: 01 E8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 8E 83 Offset 030: 00 00 00 00 C0 00 00 00 00 00 00 00 14 01 02 18 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 01 00 02 06 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 PCI-1002-9601: ATI ClkConfig Offset 00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 40: 01 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 42 00 00 00 Offset 60: 00 00 00 00 08 08 08 08 9F 10 03 00 80 00 00 00 Offset 70: 01 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 3F 5F C4 80 Offset 90: FF 03 00 00 1F FF FE 6A 40 00 00 00 00 00 00 00 Offset A0: 60 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 FF FF 10 00 Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset D0: 00 00 00 00 6C 7B 00 00 9D 00 00 00 00 00 00 00 Offset E0: 01 00 4D 07 0C 01 00 00 00 00 00 EC 03 00 00 00 Offset F0: 00 00 00 00 00 00 00 00 30 CF 00 00 00 00 00 00 PCI-1002-9601: ATI RS690/RD780/RD790/RS740/RS780/RX790/RS880 NBMCIND Offset 00: 00AC0056 88148200 00030200 00000000 Offset 04: 08881018 0000BBBB 80000102 00000018 Offset 08: 00000A00 40000008 50505411 00100000 Offset 0C: 0F000000 00054064 0AAAA000 00000000 Offset 10: 00FF0000 00000000 00000000 00000000 Offset 14: 00000000 08CC8888 000E2403 D1E01094 Offset 18: 01FFFF0F 00000000 00000000 00000000 Offset 1C: 00000000 0000FFFF 0000FFFF 0000FFFF Offset 20: 0000FFFF 0000FFFF 0000FFFF 11111111 Offset 24: 00000010 00000010 00000000 00000000 Offset 28: 00000000 12280000 00070440 0710FFF0 Offset 2C: 00010908 00000000 00000000 00000000 Offset 30: 00000001 02000001 04000000 04000000 Offset 34: 04000000 04000000 04000000 04000000 Offset 38: 00F83FE0 1FF83FE0 1FF83FE0 1FF83FE0 Offset 3C: 000000BB 00000001 02000001 04000000 Offset 40: 04000000 04000000 04000000 04000000 Offset 44: 04000000 00F83FE0 1FF83FE0 1FF83FE0 Offset 48: 1FF83FE0 000000BB 00020007 00000000 Offset 4C: 00000000 00000000 00000000 00000000 Offset 50: 00000000 00000000 00000000 00000000 Offset 54: 00000000 00000000 00000000 00000000 Offset 58: 00000000 00000000 00000000 00000000 Offset 5C: 00000400 00000000 00000000 00000000 Offset 60: 00000000 00000000 00000000 00000000 Offset 64: 00000000 00000000 00000000 00000000 Offset 68: 00000000 00000000 00000000 00000000 Offset 6C: 00000000 00000000 00000000 00000000 Offset 70: 00000000 00000000 00000000 00000000 Offset 74: 00000000 00000000 00000000 00000000 Offset 78: 00000000 00000000 00000000 00000000 Offset 7C: 00000000 00000000 00000000 00000000 Offset 80: 00000000 00000000 00000000 00000000 Offset 84: 00000000 00000000 00000000 00000000 Offset 88: 00000000 00000000 00000000 00000000 Offset 8C: 00000000 00000000 00000000 00000000 Offset 90: 00000000 00000000 00000000 00000000 Offset 94: 00000000 00000000 00000000 00000000 Offset 98: 00000000 00000000 00000000 00000000 Offset 9C: 00000000 00000000 00000000 00000000 Offset A0: 00F00000 01F10000 74F20000 4AF30000 Offset A4: 22224851 00000000 00000000 00000000 Offset A8: 68488834 10282018 23212421 21482286 Offset AC: 00000000 00000000 00000000 00040000 Offset B0: 48800000 00000263 00000202 00000000 Offset B4: 05000A00 0CBDDDDC 00000033 00000044 Offset B8: BBBBBBBB BBBBBBBB 55555555 BBBBBBBB Offset BC: BBBBBBBB 00000000 00000000 00000000 Offset C0: 00000000 00000000 00000000 80006B01 Offset C4: 04355554 00000000 00000000 00000010 Offset C8: 23F00000 01F10000 00F20000 05F30000 Offset CC: 68488834 10282018 33212421 21482286 Offset D0: 00000202 00000000 00000033 00000044 Offset D4: 00000000 00000000 00000000 00000000 Offset D8: 00A000A0 00A000A0 00000000 00000000 Offset DC: 00000000 00000000 00000000 00000000 Offset E0: 00380038 00380038 00000000 00000000 Offset E4: 00000000 00000000 00000000 00000000 Offset E8: 00380038 00380038 00000000 00000000 Offset EC: 00000000 00000000 00000000 00000000 Offset F0: 00000000 00000000 00000000 00000000 Offset F4: 00000000 00000000 00000000 00000000 Offset F8: 00000000 00000000 00000000 00000000 Offset FC: 00000000 00000000 00000000 00000000 Offset 100: 00AC0056 88148200 00030200 00000000 Offset 104: 08881018 0000BBBB 80000102 00000018 Offset 108: 00000A00 40000008 50505411 00100000 Offset 10C: 0F000000 00054064 0AAAA000 00000000 Offset 110: 00FF0000 00000000 00000000 00000000 Offset 114: 00000000 08CC8888 000E2403 D1E01094 Offset 118: 01FFFF0F 00000000 00000000 00000000 Offset 11C: 00000000 0000FFFF 0000FFFF 0000FFFF Offset 120: 0000FFFF 0000FFFF 0000FFFF 11111111 Offset 124: 00000010 00000010 00000000 00000000 Offset 128: 00000000 12280000 00070440 0710FFF0 Offset 12C: 00010908 00000000 00000000 00000000 Offset 130: 00000001 02000001 04000000 04000000 Offset 134: 04000000 04000000 04000000 04000000 Offset 138: 00F83FE0 1FF83FE0 1FF83FE0 1FF83FE0 Offset 13C: 000000BB 00000001 02000001 04000000 Offset 140: 04000000 04000000 04000000 04000000 Offset 144: 04000000 00F83FE0 1FF83FE0 1FF83FE0 Offset 148: 1FF83FE0 000000BB 00020007 00000000 Offset 14C: 00000000 00000000 00000000 00000000 Offset 150: 00000000 00000000 00000000 00000000 Offset 154: 00000000 00000000 00000000 00000000 Offset 158: 00000000 00000000 00000000 00000000 Offset 15C: 00000400 00000000 00000000 00000000 Offset 160: 00000000 00000000 00000000 00000000 Offset 164: 00000000 00000000 00000000 00000000 Offset 168: 00000000 00000000 00000000 00000000 Offset 16C: 00000000 00000000 00000000 00000000 Offset 170: 00000000 00000000 00000000 00000000 Offset 174: 00000000 00000000 00000000 00000000 Offset 178: 00000000 00000000 00000000 00000000 Offset 17C: 00000000 00000000 00000000 00000000 Offset 180: 00000000 00000000 00000000 00000000 Offset 184: 00000000 00000000 00000000 00000000 Offset 188: 00000000 00000000 00000000 00000000 Offset 18C: 00000000 00000000 00000000 00000000 Offset 190: 00000000 00000000 00000000 00000000 Offset 194: 00000000 00000000 00000000 00000000 Offset 198: 00000000 00000000 00000000 00000000 Offset 19C: 00000000 00000000 00000000 00000000 Offset 1A0: 00F00000 01F10000 74F20000 4AF30000 Offset 1A4: 22224851 00000000 00000000 00000000 Offset 1A8: 68488834 10282018 23212421 21482286 Offset 1AC: 00000000 00000000 00000000 00040000 Offset 1B0: 48800000 00000263 00000202 00000000 Offset 1B4: 05000A00 0CBDDDDC 00000033 00000044 Offset 1B8: BBBBBBBB BBBBBBBB 55555555 BBBBBBBB Offset 1BC: BBBBBBBB 00000000 00000000 00000000 Offset 1C0: 00000000 00000000 00000000 80006B01 Offset 1C4: 04355554 00000000 00000000 00000010 Offset 1C8: 23F00000 01F10000 00F20000 05F30000 Offset 1CC: 68488834 10282018 33212421 21482286 Offset 1D0: 00000202 00000000 00000033 00000044 Offset 1D4: 00000000 00000000 00000000 00000000 Offset 1D8: 00A000A0 00A000A0 00000000 00000000 Offset 1DC: 00000000 00000000 00000000 00000000 Offset 1E0: 00380038 00380038 00000000 00000000 Offset 1E4: 00000000 00000000 00000000 00000000 Offset 1E8: 00380038 00380038 00000000 00000000 Offset 1EC: 00000000 00000000 00000000 00000000 Offset 1F0: 00000000 00000000 00000000 00000000 Offset 1F4: 00000000 00000000 00000000 00000000 Offset 1F8: 00000000 00000000 00000000 00000000 Offset 1FC: 00000000 00000000 00000000 00000000 --------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------ C000:0000 U.y.%.........................IBM;.............. 761295520...... C000:0040 ................08/12/10 22:31..9................@.............. C000:0080 .............................h..........113-17100SA-S21 .REDWOOD C000:00C0 .PCI_EXPRESS.GDDR5...REDWOOD XT C02903 GDDR5 32Mx32 512M UCODEv: C000:0100 12602 ..... ...© 1988-2005, ATI Tec C000:0140 hnologies Inc. .ATOMBIOSBK-ATI VER012.020.000.032.000000.171X020 C000:0180 5.S21.565234 .156856 . .C02903\Config.h....$...ATOM.... C000:01C0 y...........K.q...>.....PCIR...h........y.......ATI ATOMBIOS..W. C000:0200 M.........ZDT..Z......]v(....V.......LP. .^..fPfQfRfSfUfVfW..... C000:0240 ........M.......f......f.(......2......-&.,&.(&........%..%.Z..k C000:0280 ..DP. u......e.Oe....U..LP........DX.......f.......fP. .....fXt. C000:02C0 . f.6.......f_f^f]f[fZfYfX.............F.f3..F...F..R......DZ... C000:0300 .......f........f.\.f.L.;.u...f.^.f.N............>...u.......... C000:0340 ...f....e.....@.....B.............|.^m..~.....qq........Yg...... C000:0380 ......[g.kg.}g...PMID...L......................f................ C000:03C0 .........fPfR.1f...f....fZfX.fPfR.1f...f....fZfX........u..:&..u Quote Link to comment Share on other sites More sharing options...
Crimson Posted February 3, 2011 Author Share Posted February 3, 2011 This is the sceenshot of the problem. See the gray 128 line at the top of the labels. Quote Link to comment Share on other sites More sharing options...
Fiery Posted February 10, 2011 Share Posted February 10, 2011 Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1251oq1xi5ergvzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote Link to comment Share on other sites More sharing options...
Crimson Posted February 12, 2011 Author Share Posted February 12, 2011 Thanks for the fix, the CPU temperature is correctly shown now. I really appreciate your work! Thanks! Quote Link to comment Share on other sites More sharing options...
Fiery Posted February 14, 2011 Share Posted February 14, 2011 Thank you for the feedback Quote Link to comment Share on other sites More sharing options...
Ronald Alberto Avella Posted December 21, 2019 Share Posted December 21, 2019 Hello, im having the exact same issue, core temps seem fine but cpu and motherboard temps show 128c steady, wich makes little sense. also when i run the stress test my pc ends up shutting down. i did not understand how you guys solved this. help please!!!! attached: isa sensor dump and computer--sensor paga  isasensordump.txt Report sensor.txt Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 30, 2019 Share Posted December 30, 2019 On 12/21/2019 at 7:26 AM, Ronald Alberto Avella said: Hello, im having the exact same issue, core temps seem fine but cpu and motherboard temps show 128c steady, wich makes little sense. also when i run the stress test my pc ends up shutting down. i did not understand how you guys solved this. help please!!!! attached: isa sensor dump and computer--sensor paga Please avoid posting a single issue into multiple topics. The fix we've implemented for Asus M4A88TD-M motherboard doesn't apply to other motherboards made by Asus, Dell or others. Quote Link to comment Share on other sites More sharing options...
