In fixing a connection problem somehow I turned off drive temperature sensors.  So where do I go to fix this?
Make sure to have the following 2 options both enabled (checked) in AIDA64 Preferences:
- Stability / Low-level SMART operations
- Hardware Monitoring / Enable disk temperature measurement
