USB Attached SCSI (UAS) (USB Devices) reporting incorrect speed
When attaching USB 3.0 drive that supports UASP the drive speed is reported as USB 2. As USB 2 tops out at 60MBs and this drive is benchmarking at 260MBs then I assume this is incorrect. If I use a non UASP device the correct speed is shown.
Please see attached jpg.
Hi
The USB controller is a NEC - µPD720202 connected to a Samsung 840 EVO 120GB in a Startech S2510BPU33 UASP external case.
Let me know if you need any other info.
Many thanks
Adrian
  • 2 months later...
We've got a S2510BPU33 box today, and connected it to an Etron USB 3.0 controller.  The information reported by AIDA64 on its  Devices / USB Devices page looks like this:
  [ USB Mass Storage Device (USB3.0 Device) ]
    Device Properties:
      Device Description                                USB Mass Storage Device
      Device ID                                         174C-1053
      Device Class                                      08 / 06 (Mass Storage)
      Device Protocol                                   50
      Manufacturer                                      Generic
      Product                                           USB3.0 Device
      Serial Number                                     AC0000000001
      Supported USB Version                             3.00
      Current Speed                                     Super  (USB 3.0)
I think in your case the SATA-to-USB 3.0 bridge chip of the box (ASMedia ASM1053) may be having an issue with the NEC USB 3.0 controller, and that's why it switches down to USB 2.0 mode.
i am not sure if this is related but, the version posted on the screenshot here is kinda old: 4.30.2900
could it be that the newest beta 4.50.3029 fixes this?
