timiman Posted September 3, 2014 Posted September 3, 2014 Hello. I'm using the Shared Memory option of AIDA64 to send out many sensors' data to my application (G15/G19 Smart Process). Is there a way to add to the Shared Memory the sensors that shows the speed in MHz of the available CPU Cores ? It would be great if you do. Thank you and keep the good work ! Quote
Fiery Posted September 10, 2014 Posted September 10, 2014 The requested feature will be implemented in the next AIDA64 beta update It will be rolled out later this week. Regards, Fiery Quote
Fiery Posted September 12, 2014 Posted September 12, 2014 We've implemented CPU core clock measurement in the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/aida64extremebuild3143zrvflpc9mdzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works Quote
timiman Posted September 19, 2014 Author Posted September 19, 2014 I've just install the latest beta. Clock Speed per CPU Core is working just fine. Thanks ! Quote
