tistou77 Posted October 18, 2014 Posted October 18, 2014 HelloIn this tab, there are 2 times the North Bridge: Intel Haswell-E IMCThe 2nd is superfluous I think (but some values ​​are different) And in "Memory Slot" is indicated 2GB by "Dram Slot", but I have 4GB modules Thanks Quote
Fiery Posted October 18, 2014 Posted October 18, 2014 Haswell-E/EN/EP/EX processors feature two quad-channel memory controllers (IMC), but on Haswell-E only the first one is utilized. Server parts (Haswell-EP for example) may have both controllers utilized, so you can use a total of eight DDR4 memory channels per CPU socket. As for the DIMM module size issue, we're aware of that, but it seems a bit complicated. The chipset (IMC) itself reports that memory module size, and so far we haven't found a proper way to come up with a workaround for that. We'll keep trying Till then, you can use the Motherboard / SPD page to check the full and accurate details on your installed memory modules. Regards, Fiery Quote
tistou77 Posted October 18, 2014 Author Posted October 18, 2014 Thank you for your explanationThis is not a problem, it was just to report Quote
