tistou77 Posted October 20, 2014 Posted October 20, 2014 Hello I set the CPU Cache Voltage in "Offset Mode", and with AIDA64 it's the same voltage at idle and load In the bios, the voltage is lower Is this is a problem of reading of AIDA64? Thanks Quote
Fiery Posted October 20, 2014 Posted October 20, 2014 AIDA64 shows what the motherboard reports as cache voltage. In case the motherboard sensor reports an incorrect value, AIDA64 will also report the wrong value. Quote
tistou77 Posted October 20, 2014 Author Posted October 20, 2014 Ok thanks Fiery I'll get into the bios, if there are settings to be made Quote
tistou77 Posted October 20, 2014 Author Posted October 20, 2014 It's OK with "Cache Min" in AUTO Thanks Quote
