Tony Morton Posted November 13, 2014 Posted November 13, 2014 Hi i have the same problem running the stability test as a person named njudell, my system is ok with prime95 for hours, but will not run for a min without giving an hardwire error. also i followed njudell's post, ie checking dll's and reinstalling etc, to no success!. p.s. i have attached a report of my system. Report.txt Quote
Mice007 Posted November 19, 2014 Posted November 19, 2014 Hi, Please try Stability Test with factory default CPU and memory clock and voltages. If this eliminates the issue with AIDA64 test, then it means the overclock rate was too high. Hi i have the same problem running the stability test as a person named njudell, my system is ok with prime95 for hours, but will not run for a min without giving an hardwire error. also i followed njudell's post, ie checking dll's and reinstalling etc, to no success!. p.s. i have attached a report of my system. Quote
Tony Morton Posted November 20, 2014 Author Posted November 20, 2014 Hi i have already tried, my system back in default settings before i posted the problem, also my AIDA64 has just upgraded to version 4.70.3237, and still have the problem, the only thing that, i have noticed is that it will run with only the CPU being stressed, but still gives an hardware error when FTP and/ or Cache selected.! Quote
Tony Morton Posted December 16, 2014 Author Posted December 16, 2014 AIDA64 updated to version 5.00.3308, still the same problem, ie A hardware error and test shutdown. i have retested my system with prim95 for many hours with no failures. Quote
