Grestorn Posted November 30, 2014 Posted November 30, 2014 I'm in the progress to create a complex sensor panel for the Arx Control display. One recurring problem is that after a while the sensor inputs are mixed up. Meaning, all of the controls show wrong values which are obviously meant for other controls. See the following screenshot and the accompanied export file. As you can see, the value for the utilization of the GPUs are completely off (showing some fraction). All of the other values are off as well, but it's most obvious with them. It looks like the assignment for the sensor inputs are somehow moved around or randomized. 2014-11-30.zipFetching info... Quote
Fiery Posted November 30, 2014 Posted November 30, 2014 Such issue may occur when the Arx app fails to refresh the web page after you changed the layout. Is it an iOS or Android device? Quote
Grestorn Posted November 30, 2014 Author Posted November 30, 2014 It's an iPad 3. Funny thing is that the display was fine and when I looked at the display after a while, it was corrupted. I don't think that I changed the layout in between. But who knows... Quote
Fiery Posted December 1, 2014 Posted December 1, 2014 On 11/30/2014 at 11:44 PM, Grestorn said: It's an iPad 3. Funny thing is that the display was fine and when I looked at the display after a while, it was corrupted. I don't think that I changed the layout in between. But who knows... Are you using the latest AIDA64 beta build of 3244? The previous build (3242) had a bug that we've fixed in 3244. Quote
Grestorn Posted December 1, 2014 Author Posted December 1, 2014 Yes, it's 3244. And Auto Update is also enabled, so I'm usually using the latest version. Quote
Fiery Posted December 2, 2014 Posted December 2, 2014 We've fixed the issue in the latest beta version of AIDA64 Extreme available at: http://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works Quote
Grestorn Posted December 2, 2014 Author Posted December 2, 2014 Updated, so far it works. If I encounter any problems I will let you know. By the way, I wanted to add Water Quality and Pump Frequency and realized, that these values are not available for LCD panels. Is that intended? And another thing: As discussed in another thread, fan controls are not rendered if the value is zero. That problem only exists for fans, not for flow values (even though most of them are also 0). Is there no way to avoid that? Quote
Fiery Posted December 3, 2014 Posted December 3, 2014 On 12/2/2014 at 9:48 PM, Grestorn said: Updated, so far it works. If I encounter any problems I will let you know. Thank you for the feedback. Quote By the way, I wanted to add Water Quality and Pump Frequency and realized, that these values are not available for LCD panels. Is that intended? Water Quality is not there yet, but pumps should be there, albeit not as frequencies but as RPM. Quote And another thing: As discussed in another thread, fan controls are not rendered if the value is zero. That problem only exists for fans, not for flow values (even though most of them are also 0). Is there no way to avoid that? Stopped fans disappear only from the Computer / Sensor page, but their RPM is still shown as zero on the LCD. Same goes for pumps. Flow sensors indicating zero flow are still displayed both on the Sensor page and LCD. If it doesn't work the way you wish, please let me know what exactly happens vs. what would you expect to happen. Quote
Grestorn Posted December 3, 2014 Author Posted December 3, 2014 Stopped fans are not rendered, at least not as Arc Gauges. They don't render in the LCD setup screen either. Even when the fans start to spin, they're not rendered unless I make the Arx Control to reset completely (by updating the layout or restarting AIDA64). However, if they're rendered in the first place, they will remain visible, even if the fan stops later. Sorry about the pump frequencies, I now remember that you already stated that they're only shown as RPM... Quote
Fiery Posted December 9, 2014 Posted December 9, 2014 On 12/3/2014 at 9:33 AM, Grestorn said: Stopped fans are not rendered, at least not as Arc Gauges. They don't render in the LCD setup screen either. Even when the fans start to spin, they're not rendered unless I make the Arx Control to reset completely (by updating the layout or restarting AIDA64). However, if they're rendered in the first place, they will remain visible, even if the fan stops later. We've just rolled out AIDA64 v5.00 stable release, that implements a fix for the stopped fans issue: http://forums.aida64.com/topic/2660-aida64-v500-is-out/ Let us know how it works on your system Quote
