Fritz_the_Germ Posted December 22, 2014 Posted December 22, 2014 Yo guys, since about two weeks all my cachemem.png or AIDA64 CPUID.png are saved as a white paper. No colors or letters are be seen: I am using the version 5.00.3308 Beta. There is an attachment down below! Try to open it! No matter which AIDA64 version I am using. All the cachemem.png or CPUID.png screenhots are unreadable. Is there anybody out there?! This is an big bug I am reporting about! 1 Quote
Fiery Posted December 30, 2014 Posted December 30, 2014 That's an issue we've never seen before, it's quite interesting. Did it start to happen after you've performed an AIDA64 upgrade? Or did you change a hardware component and that triggered the issue? Thanks, Fiery Quote
Fritz_the_Germ Posted December 30, 2014 Author Posted December 30, 2014 EDIT: I had a Asrock X99X-Killer before and changed to a ASUS X99-Deluxe! This issue is pretty new and I can not imagine what it is related to. I sure know that everything was fine with the AIDA64 4xx Version. No matter if I am using a beta-version or the 5.00.300. What am I supposed to do? The cachemem.png is part of the tool I ve paid for Quote
Fiery Posted December 30, 2014 Posted December 30, 2014 Can you please check what bit depth do you use for your Windows Desktop? Is it the default 32-bit? Quote
Fritz_the_Germ Posted December 30, 2014 Author Posted December 30, 2014 It is 32 bits: The story is when I start the cachemem or the CPUID the screens show up like they should. Only the saves won't work. Quote
Fiery Posted December 30, 2014 Posted December 30, 2014 Thank you. The hardware change shouldn't make a difference, but maybe you've also reinstalled Windows after changing the motherboard? Do you have the same type of Windows installed now than was on your previous motherboard? Quite frankly, the only case where we've seen such white screen shots was about Acrobat Reader, when a certain document streaming solution prevented the user to make screen shots of sensitive document pages. In such cases the screen shots just showed a blank white page. Can you please check what happens if you open the AIDA64 CPUID panel or Cache & Memory Benchmark panel, and you press Alt+PrtScr, and then you start MS Paint (like via mspaint.exe entered in the Run dialog box after pressing WindowsKey+R), and press Ctrl+V (Paste) in MS Paint? I wonder if it also results in a white shot, or it works properly. If that solution works properly, then you can use it as a temporary alternative to the save screen shot feature of AIDA64 until we can find the root cause of the issue and fix it up. BTW, there's a chance the issue is due to a recent Windows patch, due to a recent ForceWare update or something else that is not necesserily related to AIDA64. We will do our best to find out what's causing it, and fix it up if possible. Quote
Fritz_the_Germ Posted December 31, 2014 Author Posted December 31, 2014 Yo Fiery, I did not have to reinstall Windows after I had screwed the new ASUS X99-Deluxe into my system. I just had to activate Windows by phone again. AIDA64 cachemem.pngs aren't sensitive documents (lol) The way you told me in order to save the AIDA64 panel shots worked fine as you see at the pic below. Well, there is an easier way to capture cachemem.png pics using the windows "snipping tool" like I have to go this way until you guys find out what is causing the "blank panal shots". Quote
