My iPad Sensor Panel
Grestorn
I've spend a couple of hours to create my own Panel for my iPad. I was especially looking to create some nice effects with transparent textures. You can achieve quite some interesting things that way, see for yourself.
The first shot has been created right after the system has been started:
On the water cooling tower on the bottom the tubes and the airflow indicators are actually colored depending on the temperature. Here a shots while running a game:
The water level is also shown on the left and right of the water tower, which is hard to see, because it's at 100% in the shot. Here a shot during a stress test of the system (GPU Burner + Prime95):
There's still some things to be finished and some detail work. The network info is still missing and I'm looking to add sensor info about my power source once it has been added to AIDAs monitor (as promised :) ).
Please let me know if you like that panel. I've there's some interest, I'd be happy to share the files. It should also run on the RemoteSensor solution as well as the Logitech ArxControl app. And, even though I didn't try it, it should work on Smartphones as well, but the displays might be a bit too small.
Hello there... :)
I also did one on my iPad, but i think a lot simpler. :D As you can see, i am a big Terminator Fan. :D
10869871_747566305334499_655106499682047
There is one Question: Is it possible to display the Write and Read Speed of Harddisks or a Raid System?
I saw this @ a friend of mine, but he uses another tool for that.
Hello there... :)
It looks awesome, good job! :)
Currently it's not possible. We may work on that in 2015 ;)
Great work you did alot of hours to build no? :D
