tistou77 Posted January 13, 2015 Posted January 13, 2015 Hello I would put http://koolance.com/adt-fm03-flow-meter-frequency-adapter in my setup with the http://koolance.com/ins-fm17n-coolant-flow-meterIs that with AIDA64 I could have the indication liter / hour instead of rpm? Thanks Quote
Fiery Posted January 13, 2015 Posted January 13, 2015 Do you mean the flow rate for your Koolance flow meter is shown as a fan RPM in AIDA64? Or you mean the flow rate is completely missing from the list of measured values? Thanks, Fiery Quote
tistou77 Posted January 13, 2015 Author Posted January 13, 2015 I have not yet bought the flow meter.The adapter is used to return the signal into "rpm" (seen as a fan)And I wondered if with AIDA64, it was possible to have in liters / hour instead of RPM Thanks Quote
tistou77 Posted January 13, 2015 Author Posted January 13, 2015 If I understand correctly, the "RPM" displayed is in ml/minFor example 2000rpm => 2000 ml/minIs that Aida64 can do the calculation to go in l/h?2000 ml/mn => 2 l/min => 120 l/h Quote
Fiery Posted January 14, 2015 Posted January 14, 2015 If the mentioned device is connected to a fan header, and AIDA64 can measure it as a regular fan, then no conversion is possible. However, in case you connect it to a device that can measure it directly as a flow meter (in LPH), then we can display that natively, using LPH measurement unit. Quote
