Hello
Why change the "CPU package temperature" in the latest beta (Haswell-E)
It is much higher than before.
And does not correspond with the temperature in the bios.
With previous beta, it was good
Thanks
Previous AIDA64 versions weren't able to measure the CPU package temperature on Haswell-E at all. Can you show a screen shot where it could measure it?
Please do not mix "CPU" and "CPU Package" temperatures, they come from very different sources.
CPU Package is measured by the CPU itself, so in theory it should be the most accurate reading among various CPU-related temperature readouts.
