_behemoth_ Posted March 24, 2011 Posted March 24, 2011 Hello to everyone, yesterday i played League of Legends and i noticed frequently freezes. Its like a FPS drop to 0 and then instant back to normal and again to 0 the whole Time BUT only if i run AIDA64. Have anyone else this Problem or is it just me? With Everest all runs fine. Quote
Fiery Posted March 24, 2011 Posted March 24, 2011 1) Do you have any RAID arrays defined? 2) Do you have any external (USB, FireWire or eSATA) drives connected? 3) Do you have a GeForce 4xx or 5xx card? 4) What motherboard and CPU do you have? Thanks, Fiery Quote
_behemoth_ Posted March 24, 2011 Author Posted March 24, 2011 Hello Fiery, i have a GTX 280 and no RAID arrays defined. I forget to mention that i use the LCD Plugin of AIDA64 on my G19. edit: Motherboard is a EVGA Nforce 780i SLI and the CPU is a Q9550. I noticed there is a similiar Thread to mine -> Quote
Fiery Posted March 24, 2011 Posted March 24, 2011 Please try to disable the option "nVIDIA GPU SMBus access through nVIDIA ForceWare" in AIDA64 / main menu / File / Preferences / Stability, and restart AIDA64. Let me know if it helps. Quote
_behemoth_ Posted March 24, 2011 Author Posted March 24, 2011 I disabeld the Option that you mentioned and now it seems to work perfectly. Thanks Fiery for the fast help ! Maybe you should Sticky this Solution for other ppl with the same problem. Quote
Fiery Posted March 24, 2011 Posted March 24, 2011 Thanks for the feedback I've put a sticky on this Quote
Squall Leonhart Posted March 26, 2011 Posted March 26, 2011 i guess theres a bug in nvidia's NVAPI again or something. Quote
