Yautja Hunter Posted April 7, 2011 Posted April 7, 2011 Hello! I have a strange problem. I can't disable AIDA from launching upon Windows startup. The "Startup with Winodws" box in AIDA's options is NOT ticked. I have checked all startup branches in registry, startup folder in "Windows Start Menu" - no trace of AIDA. I've checked windows services and couldn't find it there either. I am completelty at a loss. WHERE DOES IT START FROM??? Thanks! Quote
Fiery Posted April 7, 2011 Posted April 7, 2011 Under Windows Vista and Windows 7 AIDA64 uses the Task Scheduler to start itself at Windows boot. You need to start the Task Scheduler and manually remove AIDA64 entry from there, since apparently for some reason on your system AIDA64 cannot remove its task. Regards, Fiery Quote
Yautja Hunter Posted April 7, 2011 Author Posted April 7, 2011 I've finally figured it out! It was launached by my keyboard manager. I've got Logitech G19 keyboard with LCD display where you see AIDA's sensors. Quote
Squall Leonhart Posted April 10, 2011 Posted April 10, 2011 ah yes, i was just about to mention that. Quote
dna Posted July 3, 2020 Posted July 3, 2020 thanks for this. My issue was actually being caused by having AIDA64 integrated into MSI Afterburner software (which adds some extra sensors/monitoring into Afterburner) Quote
