sblantipodi Posted November 28, 2015 Share Posted November 28, 2015 As title.Is there a reading for the PSU fan?I have a Corsair AX860i. Thanks Quote Link to comment Share on other sites More sharing options...
Fiery Posted November 28, 2015 Share Posted November 28, 2015 Corsair AXi PSUs are not supported by the AIDA64 hardware monitor module. Only HXi and RMi PSUs are supported, and only when they are directly connected via USB (not via Corsair Link Commander). Regards, Fiery Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 30, 2015 Share Posted December 30, 2015 We've implemented support for Corsair Link sensor devices (including Link Commander, Commander Mini, H80, H80i, H100, H100i, H100i GT, H110i, H110i GT, and various Corsair Link capable PSU models) in the latest AIDA64 Extreme beta update available at: http://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Please note that since Corsair's own Corsair Link software is not synchronized with any other monitoring software, it is very important to make sure it is closed, and also that its background service is not running. It's best if you completely uninstall the Corsair Link software. Due to the special precautions required to use the new Corsair Link feature of AIDA64, it is disabled by default. You have to go to AIDA64 / main menu / File / Preferences / Stability, and enable (check) Corsair Link sensor support to activate the new feature. Let us know how it works on your system. If you find any issues, please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Corsair Link Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> USB PSU Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Quote Link to comment Share on other sites More sharing options...
