sblantipodi Posted December 7, 2015 Posted December 7, 2015 As title. This is not a complain since I'm a big fan of Aida64, it's only a bug report that I have seen in the latest Aida64 5.50.3657. If I set a maximum CPU temperature in bios, my TJmax should vary and AIDA should read the temp accordingly. It's not.If I change the max cpu temperature in bios AIDA readings are completely scrambled. Is this a known issue you are working ? My mobo is a Asus X99 Deluxe with the latest 2001 BIOS. Thanks Quote
Fiery Posted December 7, 2015 Posted December 7, 2015 When you have a custom TJMax set in the BIOS Setup, please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic, or attach it as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Please also let us know the TJMax value you've configured in the BIOS Setup, to let us compare it against the CPU registers output. Thanks, Fiery Quote
sblantipodi Posted December 7, 2015 Author Posted December 7, 2015 When you have a custom TJMax set in the BIOS Setup, please right-click on the bottom status bar of AIDA64 main window --> CPU Debug --> CPUID & MSR Dump. Copy-paste the full results into this topic, or attach it as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Please also let us know the TJMax value you've configured in the BIOS Setup, to let us compare it against the CPU registers output. Thanks, Fiery Hi, thanks for the reply, I set 95°c in BIOS but aida shows 90°C as TJMAX. ------[ Versions ]------ Program Version : AIDA64 v5.50.3657 Beta BenchDLL Version: 4.1.643-x64 ------[ CPU Info ]------ CPU Type : HexaCore Intel Core i7-5930K, 3500 MHz (35 x 100) CPU Alias : Haswell-E CPU Platform : LGA2011-v3 CPU Stepping : R2 Instruction Set : x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, AVX, AVX2, FMA, AES CPUID Manufacturer: GenuineIntel CPUID CPU Name : Intel® Core i7-5930K CPU @ 3.50GHz CPUID Revision : 000306F2h IA Brand ID : 00h (Unknown) Platform ID : 4Bh (LGA2011-v3) HTT / CMP Units : 2 / 6 Max. NUMA Node : 0 Tjmax Temperature : 90 Celsius HTC Temperature Limit : 0 Celsius CPU TDP : 140 W DRAM TDP : 24.5 W CPU TDC : Unlimited CPU Max Power Limit : Unlimited Power / Unlimited Time CPU Power Limit 1 (Long) : 4095 W / 1.00 sec (Unlocked) CPU Power Limit 2 (Short) : 4095 W / 7.81 ms (Unlocked) Max Turbo Boost Multipliers: 1C: 42x, 2C: 42x, 3C: 42x, 4C: 42x, 5C: 42x, 6C: 42x ------[ Logical CPU #0 ]------ allcpu: Package 0 / Core 0 / Thread 0: Valid CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-00100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-00000000 [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-00000000 [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ Logical CPU #1 ]------ allcpu: Package 0 / Core 0 / Thread 1: Valid, Virtual CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-01100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-00000001 [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-00000001 [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ Logical CPU #2 ]------ allcpu: Package 0 / Core 1 / Thread 0: Valid CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-02100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-00000002 [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-00000002 [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ Logical CPU #3 ]------ allcpu: Package 0 / Core 1 / Thread 1: Valid, Virtual CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-03100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-00000003 [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-00000003 [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ Logical CPU #4 ]------ allcpu: Package 0 / Core 2 / Thread 0: Valid CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-04100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-00000004 [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-00000004 [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ Logical CPU #5 ]------ allcpu: Package 0 / Core 2 / Thread 1: Valid, Virtual CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-05100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-00000005 [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-00000005 [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ Logical CPU #6 ]------ allcpu: Package 0 / Core 3 / Thread 0: Valid CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-06100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-00000006 [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-00000006 [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ Logical CPU #7 ]------ allcpu: Package 0 / Core 3 / Thread 1: Valid, Virtual CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-07100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-00000007 [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-00000007 [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ Logical CPU #8 ]------ allcpu: Package 0 / Core 4 / Thread 0: Valid CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-08100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-00000008 [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-00000008 [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ Logical CPU #9 ]------ allcpu: Package 0 / Core 4 / Thread 1: Valid, Virtual CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-09100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-00000009 [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-00000009 [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ Logical CPU #10 ]------ allcpu: Package 0 / Core 5 / Thread 0: Valid CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-0A100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-0000000A [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-0000000A [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ Logical CPU #11 ]------ allcpu: Package 0 / Core 5 / Thread 1: Valid, Virtual CPUID 00000000: 0000000F-756E6547-6C65746E-49656E69 [GenuineIntel] CPUID 00000001: 000306F2-0B100800-7FFEFBBF-BFEBFBFF CPUID 00000002: 76036301-00F0B5FF-00000000-00C10000 CPUID 00000003: 00000000-00000000-00000000-00000000 CPUID 00000004: 1C004121-01C0003F-0000003F-00000000 [sL 00] CPUID 00000004: 1C004122-01C0003F-0000003F-00000000 [sL 01] CPUID 00000004: 1C004143-01C0003F-000001FF-00000000 [sL 02] CPUID 00000004: 1C03C163-04C0003F-00002FFF-00000006 [sL 03] CPUID 00000005: 00000040-00000040-00000003-00002120 CPUID 00000006: 00000077-00000002-00000009-00000000 CPUID 00000007: 00000000-000037AB-00000000-00000000 CPUID 00000008: 00000000-00000000-00000000-00000000 CPUID 00000009: 00000001-00000000-00000000-00000000 CPUID 0000000A: 07300403-00000000-00000000-00000603 CPUID 0000000B: 00000001-00000002-00000100-0000000B [sL 00] CPUID 0000000B: 00000004-0000000C-00000201-0000000B [sL 01] CPUID 0000000C: 00000000-00000000-00000000-00000000 CPUID 0000000D: 00000007-00000340-00000340-00000000 [sL 00] CPUID 0000000D: 00000001-00000000-00000000-00000000 [sL 01] CPUID 0000000D: 00000100-00000240-00000000-00000000 [sL 02] CPUID 0000000E: 00000000-00000000-00000000-00000000 CPUID 0000000F: 00000000-00000017-00000000-00000002 [sL 00] CPUID 0000000F: 00000000-00006000-00000017-00000001 [sL 01] CPUID 80000000: 80000008-00000000-00000000-00000000 CPUID 80000001: 00000000-00000000-00000021-2C100000 CPUID 80000002: 65746E49-2952286C-726F4320-4D542865 [intel® Core(TM] CPUID 80000003: 37692029-3339352D-43204B30-40205550 [) i7-5930K CPU @] CPUID 80000004: 352E3320-7A484730-00000000-00000000 [ 3.50GHz] CPUID 80000005: 00000000-00000000-00000000-00000000 CPUID 80000006: 00000000-00000000-01006040-00000000 CPUID 80000007: 00000000-00000000-00000000-00000100 CPUID 80000008: 0000302E-00000000-00000000-00000000 L1 Data Cache: 32 KB, 8-way Associative, 64-byte Line L1 Instr. Cache: 32 KB, 8-way Associative, 64-byte Line L2 Unified Cache: 256 KB, 8-way Associative, 64-byte Line L3 Unified Cache: 15 MB, 20-way Associative, 64-byte Line ------[ All CPUs ]------ CPU 0: APICID 0 / Package 0 / Core 0 / Thread 0: Valid CPU 1: APICID 1 / Package 0 / Core 0 / Thread 1: Valid, Virtual CPU 2: APICID 2 / Package 0 / Core 1 / Thread 0: Valid CPU 3: APICID 3 / Package 0 / Core 1 / Thread 1: Valid, Virtual CPU 4: APICID 4 / Package 0 / Core 2 / Thread 0: Valid CPU 5: APICID 5 / Package 0 / Core 2 / Thread 1: Valid, Virtual CPU 6: APICID 6 / Package 0 / Core 3 / Thread 0: Valid CPU 7: APICID 7 / Package 0 / Core 3 / Thread 1: Valid, Virtual CPU 8: APICID 8 / Package 0 / Core 4 / Thread 0: Valid CPU 9: APICID 9 / Package 0 / Core 4 / Thread 1: Valid, Virtual CPU 10: APICID 10 / Package 0 / Core 5 / Thread 0: Valid CPU 11: APICID 11 / Package 0 / Core 5 / Thread 1: Valid, Virtual ------[ MSR Registers ]------ MSR 00000017: 0008-0000-0000-0000 [PlatID = 2] MSR 0000001B: 0000-0000-FEE0-0900 MSR 00000035: 0000-0000-0006-000C MSR 0000008B: 0000-0036-0000-0000 MSR 000000CE: 0008-0C3B-F381-2300 [eD = 0] MSR 000000E7: 0000-001B-FE41-D514 [s200] MSR 000000E7: 0000-001C-05A9-D404 [s200] MSR 000000E7: 0000-001C-0933-D790 MSR 000000E8: 0000-0017-9497-9798 [s200] MSR 000000E8: 0000-0017-957A-0EB5 [s200] MSR 000000E8: 0000-0017-97EE-CAEE MSR 00000194: 0000-0000-000E-0000 MSR 00000198: 0000-1999-0000-0C00 [s200] MSR 00000198: 0000-1999-0000-0C00 [s200] MSR 00000198: 0000-1971-0000-0C00 MSR 00000199: 0000-0000-0000-1600 MSR 0000019A: 0000-0000-0000-0000 MSR 0000019B: 0000-0000-0000-0000 MSR 0000019C: 0000-0000-8834-0000 [s200] MSR 0000019C: 0000-0000-8833-0000 [s200] MSR 0000019C: 0000-0000-8834-0000 MSR 0000019D: 0000-0000-0000-0000 MSR 000001A0: 0000-0000-0085-0089 MSR 000001A2: 0000-0000-005A-0A00 MSR 000001A4: 0000-0000-0000-0000 MSR 000001AA: 0000-0000-0040-0000 MSR 000001AC: < FAILED > MSR 000001AD: 2424-2A2A-2A2A-2A2A MSR 000001AE: 2424-2424-2424-2424 MSR 000001AF: 0000-0000-0000-2424 MSR 000001B0: 0000-0000-0000-0006 MSR 000001B1: 0000-0000-882B-0000 MSR 000001B2: 0000-0000-0000-0000 MSR 000001FC: 0000-0000-2B04-0059 MSR 00000300: 0000-0000-8000-FF00 MSR 0000030A: 0000-0000-0000-0000 [s200] MSR 0000030A: 0000-0000-0000-0000 [s200] MSR 0000030A: 0000-0000-0000-0000 MSR 0000030B: 0000-0000-0000-0000 [s200] MSR 0000030B: 0000-0000-0000-0000 [s200] MSR 0000030B: 0000-0000-0000-0000 MSR 00000480: 00DA-0400-0000-0012 MSR 00000481: 0000-00FF-0000-0016 MSR 00000482: FFF9-FFFE-0401-E172 MSR 00000483: 007F-FFFF-0003-6DFF MSR 00000484: 0000-FFFF-0000-11FF MSR 00000485: 0000-0000-3004-81E5 MSR 00000486: 0000-0000-8000-0021 MSR 00000487: 0000-0000-FFFF-FFFF MSR 00000488: 0000-0000-0000-2000 MSR 00000489: 0000-0000-0017-27FF MSR 0000048A: 0000-0000-0000-002A MSR 0000048B: 0000-3FFF-0000-0000 MSR 0000048C: 0000-0F01-0633-4141 MSR 0000048D: 0000-00FF-0000-0016 MSR 0000048E: FFF9-FFFE-0400-6172 MSR 0000048F: 007F-FFFF-0003-6DFB MSR 00000490: 0000-FFFF-0000-11FB MSR 00000601: 0010-1414-0000-1FFF MSR 00000602: < FAILED > MSR 00000603: 0016-0000-001C-1C1C MSR 00000604: < FAILED > MSR 00000606: 0000-0000-000A-0E03 MSR 0000060A: 0000-0000-0000-0000 MSR 0000060B: 0000-0000-0000-0000 MSR 0000060C: 0000-0000-0000-0000 MSR 0000060D: 0000-0000-0000-0000 MSR 00000610: 0007-FFF8-0015-FFF8 MSR 00000611: 0000-0000-000C-A8E0 [s200] MSR 00000611: 0000-0000-000C-B094 [s200] MSR 00000611: 0000-0000-000C-B87C MSR 00000613: 0000-0000-0000-4DAF MSR 00000614: 0000-0000-0178-0460 MSR 00000618: 0000-0000-0000-0000 MSR 00000619: 0000-0000-0000-0000 [s200] MSR 00000619: 0000-0000-0000-0000 [s200] MSR 00000619: 0000-0000-0000-0000 MSR 0000061B: 0000-0000-0000-0000 MSR 0000061C: 002F-0160-002E-00C4 MSR 0000061E: 0000-0000-0000-0000 MSR 00000620: 0000-0000-0000-0E26 MSR 00000621: 0000-0000-0000-000E MSR 00000638: 0000-0000-0000-0000 MSR 00000639: 0000-0000-0000-0000 [s200] MSR 00000639: 0000-0000-0000-0000 [s200] MSR 00000639: 0000-0000-0000-0000 MSR 0000063A: < FAILED > MSR 0000063B: < FAILED > MSR 00000640: < FAILED > MSR 00000641: < FAILED > MSR 00000642: < FAILED > MSR 00000648: 0000-0000-0000-0023 MSR 00000649: 00BC-0000-0020-0460 MSR 0000064A: 00BC-0000-0000-0000 MSR 0000064B: 0000-0000-0000-0000 MSR 0000064C: 0000-0000-0000-00FF MSR 00000690: 0000-0000-C500-0000 MSR 000006B0: < FAILED > MSR 000006B1: 0000-0000-0000-0000 PerformanceFrequency = 3417961 CPU Clock M.Method = 8 (APIC SNB) PM Timer Address = 1032 (0408h) APIC Clock = 100.00 MHz (AT = 52395 / TT = 15004 / try = 1 / SKL = 0.00 MHz) APIC Clock = 100.00 MHz (AT = 52395 / TT = 15004 / try = 1 / SKL = 0.00 MHz) APIC Clock = 100.00 MHz (AT = 52392 / TT = 15003 / try = 1 / SKL = 0.00 MHz) APIC Clock = 100.00 MHz (AT = 52390 / TT = 15003 / try = 1 / SKL = 0.00 MHz) APIC Clock = 100.00 MHz (AT = 52391 / TT = 15003 / try = 2 / SKL = 0.00 MHz) INTPERFCTR2 = 1200.00 MHz / INTPERFCTR1 (TSC) = 3500.00 MHz INTPERFCTR2 = 2797.00 MHz / INTPERFCTR1 (TSC) = 3496.25 MHz INTPERFCTR2 = 2200.00 MHz / INTPERFCTR1 (TSC) = 3500.01 MHz INTPERFCTR2 = 1200.00 MHz / INTPERFCTR1 (TSC) = 3499.99 MHz INTPERFCTR2 = 1199.99 MHz / INTPERFCTR1 (TSC) = 3499.97 MHz ------[ OC MailBox ]------ C 01 / P1 00 / P2 00: 00000750 C 01 / P1 01 / P2 00: 00000000 C 01 / P1 02 / P2 00: 00000750 C 01 / P1 03 / P2 00: 00000400 C 02 / P1 00 / P2 00: 50505050 C 02 / P1 00 / P2 01: < FAILED > C 10 / P1 00 / P2 00: 07A4D72A C 10 / P1 01 / P2 00: 00000000 C 10 / P1 02 / P2 00: 23E00050 C 10 / P1 03 / P2 00: 1D800000 C 12 / P1 00 / P2 00: 8000079A C 14 / P1 00 / P2 00: 00000003 Quote
sblantipodi Posted December 7, 2015 Author Posted December 7, 2015 now I tried setting 90°C in BIOS and AIDA reads 85°C.What does it means? If I set 95°C for example, AIDA reads 90°C, and max temp readings are greater by 5°C than if I leave TJMax on Auto in BIOS. Quote
Fiery Posted December 12, 2015 Posted December 12, 2015 We've looked into it, and it seems the only way to detect a custom TJMax configuration (initiated by a BIOS Setup option) is by using a non-documented interface of Intel processors. And using that interface is quite dangerous, since it is linked to the FIVR (integrated VRM) of the CPU, so if anything slips, your CPU may just get a voltage spike that causes irreversible damages. And we don't want to go down that path But if you know the right TJMax temperature value, then you can specify it in AIDA64 / main menu / File / Preferences / Hardware Monitoring. Quote
sblantipodi Posted December 14, 2015 Author Posted December 14, 2015 We've looked into it, and it seems the only way to detect a custom TJMax configuration (initiated by a BIOS Setup option) is by using a non-documented interface of Intel processors. And using that interface is quite dangerous, since it is linked to the FIVR (integrated VRM) of the CPU, so if anything slips, your CPU may just get a voltage spike that causes irreversible damages. And we don't want to go down that path But if you know the right TJMax temperature value, then you can specify it in AIDA64 / main menu / File / Preferences / Hardware Monitoring. ok, thank you Quote
