testmans Posted April 13, 2011 Posted April 13, 2011 Everest program and restart the computer system providing information about the report and would like to build. Nilgisayar will not open after the restart. Cause of the problem? Quote
Fiery Posted April 13, 2011 Posted April 13, 2011 I'm sorry, but I don't think I understand what you mean. Can you please rephrase your question or explain it more detailed? Is your question related to AIDA64 at all? What is "Nilgisayar" ? Thanks, Fiery Quote
testmans Posted April 13, 2011 Author Posted April 13, 2011 On 4/13/2011 at 7:26 AM, testmans said: Everest program and restart the computer system providing information about the report and would like to build. Nilgisayar will not open after the restart. Cause of the problem? I'm sorry English is bad: ( Problem I am writing again, the computer running the latest version of AIDA64, and build hardware information report, the report created in the first restart the computer will not open at all I understand the ram failure occurred after the detection of computer. (change new memory install) Restart my computer after I changed the RAM but still does not open and I got the report back. I guess I failed again ram Why is that problem? please help Quote
Fiery Posted April 13, 2011 Posted April 13, 2011 I guess there's a flaw either with your memory modules SPD chip, or the way how your motherboard communicates with the SPD chip on your memory modules. You may want to replace the memory modules with ones from another brand, or stop using AIDA64. However, I'd like to warn you that such issues may come up with any hardware monitoring or hardware diagnostic software as well, e.g. HWMonitor, CPU-Z, HWiNFO32, Sandra, etc. We've seen such issues a few years ago, when the memory module in certain Toshiba notebooks couldn't handle Everest memory bandwidth benchmarks and they failed. It turned out the memory modules were of bad quality and simply couldn't stand the excessive stress that our benchmarks put them through. Quote
testmans Posted April 14, 2011 Author Posted April 14, 2011 On 4/13/2011 at 3:08 PM, Fiery said: I guess there's a flaw either with your memory modules SPD chip, or the way how your motherboard communicates with the SPD chip on your memory modules. You may want to replace the memory modules with ones from another brand, or stop using AIDA64. However, I'd like to warn you that such issues may come up with any hardware monitoring or hardware diagnostic software as well, e.g. HWMonitor, CPU-Z, HWiNFO32, Sandra, etc. We've seen such issues a few years ago, when the memory module in certain Toshiba notebooks couldn't handle Everest memory bandwidth benchmarks and they failed. It turned out the memory modules were of bad quality and simply couldn't stand the excessive stress that our benchmarks put them through. The problem is the product Foxconn NT 535 This is the product page; http://www.foxconnchannel.com/product/Barebones/NT535/index.html This is more than one product we all have the same problem. Report away, after you restart the computer does not open. RAM fails, another computer I'm testing this ram does not work in any way. Computers do not have any other problems. This is a problem in the future are we live? Quote
Squall Leonhart Posted April 14, 2011 Posted April 14, 2011 then your ram is just of bad quality, find a new supplier. Quote
testmans Posted April 25, 2011 Author Posted April 25, 2011 Problem Solved!! Chromtel source of the problem, the HDMI codec. With the manufacturer about it this way, the response from them passed through connect. Display adapter voltage during the reporting everest chromtel chip layout, so they have a problem because of disruptive, Ram s disturbing. They wanted to use our program to another report. Quote
