Masterofpuppets Posted January 12, 2016 Posted January 12, 2016 Hello,sorry for my bad english Ich have a Problem with my Sensor Panel I use a Aquastream XT ultra pump. I have connected radiator fan, a external temp sensor and a flow sensor direct to the aquastream xt. In the software "aquasuite" i have the following values: -Water temp -External Water temp -pump-electronic temp -fan rpm -fan voltage -fan speed in % -pump rpm -flow in litre per hour or litre per minute -pump frequenz -pump voltage -pump current But in Aida it shows only the following values: -Water temp -ext. water temp -pump electronic temp -fan rpm -fan voltage -pump rpm -pump current Ist that normal that i dont get the other values? Inspecially i miss the flow sensor But it were nice if the values in aida availble too: -fan speed in % -pump frequenz -pump voltage Best regards Pierre 1 Quote
Fiery Posted January 13, 2016 Posted January 13, 2016 Pump frequency is simply 45000000 / RPM, so it would be redundant to report it when AIDA64 already reports the RPM value. Fan speed % (duty cycle value) is also not that useful, since even a non-zero duty cycle value could mean the fan or pump is stopped. So when a RPM value is available, AIDA64 usually don't report the duty cycle. Pump voltage and flow rate can be reported, but we do not have the necessary technical information to convert the raw readings to meaningful values. If you could help us by sending us a register dump, and also the values as measured by Aquasuite, we should be able to implement the missing values in AIDA64. Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Aquaero Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
Masterofpuppets Posted January 13, 2016 Author Posted January 13, 2016 Hey Fiery, thank you for your fast response! I'll send you the dump file here in 2 hours, when im at home from work, another question is, Can aida handle the aquacomputer mps sensors alone without a aquero, only connected via usb? Best regards Pierre Quote
Fiery Posted January 13, 2016 Posted January 13, 2016 Hey Fiery, thank you for your fast response! I'll send you the dump file here in 2 hours, when im at home from work Thank you in advance! another question is, Can aida handle the aquacomputer mps sensors alone without a aquero, only connected via usb? Yes, it can. Quote
Masterofpuppets Posted January 13, 2016 Author Posted January 13, 2016 Perfect! Then i buy 2 of these sensors one for measuring the flow and one pressure sensor for measuring the filling level Then i dont need the connected flow sensor on the ASXT But i send you the dump however there is a nother one who have this problem Quote
Masterofpuppets Posted January 13, 2016 Author Posted January 13, 2016 so here is the file aquaerodump.txt Quote
Fiery Posted January 13, 2016 Posted January 13, 2016 Thank you. Please let me know the pump voltage and flow rate values when the dump was created, as they are displayed by Aquasuite. Or, in case those values vary greatly, then please post a new dump while visually checking the values in Aquasuite, to make sure the dump registers and the values match. Quote
Masterofpuppets Posted January 13, 2016 Author Posted January 13, 2016 So ok? a new dump and a screenshot from aquasuite software with the sensor information. i hope you can handle the german words like "durchfluss" (flow). aquaerodumpnew.txt Quote
Fiery Posted January 13, 2016 Posted January 13, 2016 Thank you, we'll add flow rate measurement for AquaStream XT in the next AIDA64 beta update due in a few days from now. As for the pump voltage, it is already reported as +12V VRM voltage Quote
Masterofpuppets Posted January 13, 2016 Author Posted January 13, 2016 how can i get informed about the update? Quote
Fiery Posted January 13, 2016 Posted January 13, 2016 how can i get informed about the update? I will drop a message into this topic once the new beta is available for download. Alternatively, you can also enable automatic updates to beta packages in AIDA64 / main menu / File / Preferences / General / NetUpdate / Update type. Quote
Fiery Posted January 18, 2016 Posted January 18, 2016 The above mentioned new AIDA64 beta update is available for download at: http://www.aida64.com/downloads/latesta64xebeta Quote
