Vulkan Posted April 13, 2011 Posted April 13, 2011 Hi, we just got Aida64, I used to use Everest so I'm familiar with the program to a point, however our help file doesn't seem to work, when accessing it through the menu, pressing F1, or launching the CHM file directly every page just says "Navigation to the web page was cancelled", then tell's you to retype the address?? any idea what's up with that? Quote
Fiery Posted April 13, 2011 Posted April 13, 2011 Probably Windows blocks access to the .CHM file due to security settings. Please try to do the following: 1) Press right-click on the .CHM file --> Properties 2) Press the Unblock button 3) Press OK Let me know if it helps. Thanks, Fiery Quote
Vulkan Posted April 13, 2011 Author Posted April 13, 2011 Wow, learn something new everyday been a while since i used CHM files wasn't aware windows would do that. Seems to be good now Thanks for the quick Reply Fiery! Quote
Squall Leonhart Posted April 14, 2011 Posted April 14, 2011 windows 7 and maybe vista do not include winhlp32 which is required for reading .chm format help files. see KB917607 for the fix. Quote
dicht Posted April 15, 2011 Posted April 15, 2011 Hi, do not mix things :-), just for .hlp files you need winhlp32.exe (http://support.microsoft.com/kb/917607/en-us), .chm Files are just fine under Win7 only the unblocking thing needs to be done sometimes like Fiery tells . (http://didierdanse.net/blogs/dev_en/archive/2009/09/08/windows-7-how-to-display-chm-content.aspx) regards dicht windows 7 and maybe vista do not include winhlp32 which is required for reading .chm format help files. see KB917607 for the fix. Quote
Squall Leonhart Posted April 16, 2011 Posted April 16, 2011 Hi, do not mix things :-), just for .hlp files you need winhlp32.exe (http://support.microsoft.com/kb/917607/en-us), .chm Files are just fine under Win7 only the unblocking thing needs to be done sometimes like Fiery tells . (http://didierdanse.net/blogs/dev_en/archive/2009/09/08/windows-7-how-to-display-chm-content.aspx) regards dicht oh shi..... yeah my bad Quote
