wwcanoer Posted January 21, 2016 Posted January 21, 2016 GPGPU Benchmark hangs at 32-bit Integer IOPS Windows 8.0 not all updated (clean restore but update failed) Lenovo T430s i5-3210M, 2600 MHz, with 16GB memory HD Graphics 4000 with 2GB memory Aida 64 portable trial downloaded today. Question: What are the chances this is a hardware issue? I just purchased this used computer, 8 days left on manufacturer warranty so testing it now. I hope that this is just a driver issue but Windows update tried in stalling 183 updates and once, failed, and reverted everything, which took 8+ hours, so I am testing first. Thanks, Brian Quote
Fiery Posted January 21, 2016 Posted January 21, 2016 Does it hang at the GPU test or CPU test? In other words: left column or right column on the GPGPU Benchmark Panel? Quote
Fiery Posted January 22, 2016 Posted January 22, 2016 It means the issue caused by a bug in the OpenCL compiler which is part of the OpenCL driver which is part of the video driver for your GPU. Try to update your video driver, it should help. Quote
