Bojanum Posted January 31, 2016 Posted January 31, 2016 Hi there, I have one problem and I think you guys/girls can help me out with it. My "Cache and memory benchmark" results are low, at least I think they are low,especially "write speed" and latency. I tried changing timings, voltage and nothing helped. Default timings are 13-11-10-30 CR1.With 10-10-10-28 CR1 I managed to lower the latency for a bit and that's it. Please, if you can, help. Thank you in advance. I forgot to write modules name: Kingston HyperX Fury 1866MHz 3x8Gb Quote
Fiery Posted January 31, 2016 Posted January 31, 2016 The results look fine to me, considering your system spec. Regards, Fiery Quote
Bojanum Posted January 31, 2016 Author Posted January 31, 2016 Are you sure?Latency and writing speed seems quite low considering benchmarks made by others with almost the same spec. Quote
Fiery Posted January 31, 2016 Posted January 31, 2016 Our FX-8350 based, Dual Channel DDR3-1866 system that uses slightly different RAM latency settings (9-10-9-27 CR2) than yours can push: Memory Read: 26426 MB/s Memory Write: 17328 MB/s Memory Copy: 22802 MB/s Memory Latency: 61.6 ns Quote
Bojanum Posted January 31, 2016 Author Posted January 31, 2016 Well, I will try with those settings and see if there is going to be some improvement, if those setting will work with my modules. Thanks mate for your help. Quote
lamb0985 Posted August 4, 2016 Posted August 4, 2016 Try increasing NB speed to 2400 or higher. You may have to raise CPU/NB voltage in order to pass the benchmark after this or to even boot properly (try 0.025 increments until it stabilizes). The highest I was able to push my NB was 2700 and it took almost 1.4V on the CPU/NB to get it to boot and benchmark, but the difference was night and day in the benchmarks. Quote
