Dutch Posted March 14, 2016 Report Share Posted March 14, 2016 I have two SSDs and one HDD, and all three show, but I see only one SMART result. What does the one SMART result indicate? smartdump.txt I noticed an anomaly between AIDA64 and aquasuite with the Shared Memory Windows Services function. The power supply unit correctly lists as "W" in the AIDA64 sensor list, but aquasuite picks the unit up as "V". Is there a possible typo on the unit definition when passed to shared memory? Quote Link to comment Share on other sites More sharing options...
Fiery Posted March 15, 2016 Report Share Posted March 15, 2016 I have two SSDs and one HDD, and all three show, but I see only one SMART result. What does the one SMART result indicate? It's a global SMART status. If it says "OK", all drives are fine. Otherwise, one or more drives report an imminent failure. I noticed an anomaly between AIDA64 and aquasuite with the Shared Memory Windows Services function. The power supply unit correctly lists as "W" in the AIDA64 sensor list, but aquasuite picks the unit up as "V". Is there a possible typo on the unit definition when passed to shared memory? The shared memory tags for power values say "pwr"; whereas the tags for voltages say "volt". If another software picks power readings up as voltages, it's due to a bug of that other software and not an issue about AIDA64 Quote Link to comment Share on other sites More sharing options...
Dutch Posted March 15, 2016 Author Report Share Posted March 15, 2016 OK, thank you. Quote Link to comment Share on other sites More sharing options...
