vabchgent Posted April 11, 2016 Report Share Posted April 11, 2016 Is there any way to add a check box to change LPH to LPM so when I look at the sensor page the conversion is already done and shows as LPM rather then LPH. Thanks in advance . Quote Link to comment Share on other sites More sharing options...
Fiery Posted April 11, 2016 Report Share Posted April 11, 2016 You can override the unit with your own choice, but you also have to make sure the measured value is scaled accordingly. You can use the Correction feature (AIDA64 / main menu / File / Preferences / Hardware Monitoring / Correction) to do that. Quote Link to comment Share on other sites More sharing options...
vabchgent Posted May 5, 2016 Author Report Share Posted May 5, 2016 Just logged in to say . Thanks it works Quote Link to comment Share on other sites More sharing options...
