Several sensors do not work, or are incorrect.
CPU core is wrong, CPU VTT is zero, N/B core is zero, CPU clock is wrong, no N/B temperature, no VRM temperature.
Also right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
Also, please create a screen show of EVGA's own utility (E-LEET) to have a reference list of readings that we could use to calibrate the temperatures and voltages in AIDA64. In case E-LEET fails to support your motherboard, then please create a photo of the H/W Monitor page of the BIOS Setup (UEFI Setup) for the same purpose ;)
Core clock is OK.
Dumps:
------[ AIDA64 Extreme v5.70.3861 Beta ]------
------[ Microsoft Windows 7 Ultimate 6.1.7601.23418 Service Pack 1 (64-bit) ]------
Motherboard ID      : 63-0100-000001-00101111-051315-Chipset$0AAAA000_BIOS DATE: 03/18/16 09:15:30 VER: 05.0000B
Motherboard Model   : EVGA Z170 Classified K (E178)
Motherboard Chipset : Intel Sunrise Point Z170, Intel Skylake-S
DMI MB Manufacturer : EVGA INTERNATIONAL CO.,LTD
DMI MB Product      : 142-SS-E178
DMI MB Version      : 1.0
DMI MB Serial       : Default string
DMI SYS Manufacturer: EVGA INTERNATIONAL CO.,LTD
DMI SYS Product     : Default string
DMI SYS Version     : Default string
DMI SYS Serial      : Default string
DMI BIOS Version    : 1.03
ITE SuperIO Port           = 00h
ITE SuperIO HWMonitor Port = 0000h (0000h / 0000h)
ITE SuperIO Device ID      = 0000h (0000h / 0000h)
ITE SuperIO Version        = 00h   (  00h /   00h)
Winbond SuperIO Port              = 00h
Winbond SuperIO Device ID         = 1005h (0000h / 1005h)
Fintek SuperIO Port           = 4Eh
Fintek SuperIO HWMonitor Port = 0290h (0000h / 0290h)
Fintek SuperIO Device ID      = 1005h (0000h / 1005h)
SMSC SuperIO Port           = 00h
SMSC SuperIO Device ID      = 0000h (0000h / 0000h)
ASpeed SuperIO Port = 00h
------[ LM78 ISA Sensor Device at 0290 ]------
0000  FF C3 00 01  01 FF FF 00  00 00 02 00  64 4C 00 30
0010  00 00 00 00  00 00 06 FF  FF FF FF FF  FF FF FF FF
0020  CF 47 76 76  8A 97 A1 D3  C7 FF FF FF  FF FF 99 7F
0030  7A D7 FF FF  FF FF C9 C8  75 85 FF FF  FF FF FF 00
0040  44 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0050  FF FF FF FF  FF FF FF FF  FF FF 03 04  10 19 34 FF
0060  00 02 00 00  FF FF 02 00  00 00 FF 0E  40 24 FF 00
0070  FF FF 1C FF  1D FF 1E FF  1C 00 1F 1F  1F 00 00 00
0080  FF FF 64 55  64 55 55 46  FF FF FF FF  FF FF A8 FF
0090  00 06 06 00  10 FF 17 FF  44 02 00 15  55 05 99 1A
00A0  01 C7 00 F7  00 E3 3C 32  28 1E FF D8  B2 99 7F 0D
00B0  0F FF 00 99  03 FF 3C 32  28 1E FF D8  B2 99 7F 0C
00C0  0F FF 00 7F  03 FF 2D 28  23 1E FF CC  A5 7F 66 0F
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00E0  00 00 00 00  00 00 00 00  00 FF FF FF  00 00 01 00
00F0  00 00 00 00  00 00 33 FF  00 33 FF 00  FF 00 FF FF
   0070 0072 0074 0076 0078 0079 007A 007B 007C 007D 007E 007F
T:  255   28   29   30   28    0   32   32   32    0    0    0
T:  255   29   29   30   29    0   29   29   29    0    0    0
T:  255   28   29   30   28    0   28   28   28    0    0    0
T:  255   28   29   30   28    0   27   27   27    0    0    0
T:  255   27   29   30   27    0   27   27   27    0    0    0
T:  255   27   30   30   27    0   27   27   27    0    0    0
   0020 0021 0022 0023 0024 0025 0026 0027 0028
V:  CF   47   76   76   8A   97   A2   D3   C7   [ VID = 1.16492 V ]
V:  CF   46   76   76   8A   96   A2   D2   C7   [ VID = 1.16492 V ]
V:  CF   46   76   76   8A   97   A2   D3   C7   [ VID = 1.16492 V ]
V:  CF   46   76   76   8A   96   A2   D3   C7   [ VID = 1.16492 V ]
V:  CF   46   76   76   8A   96   A2   D3   C6   [ VID = 1.16492 V ]
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             : <TYPE>0</TYPE><LEN>4</LEN><DATA>3010</DATA>
_TZ_.TZ01._TMP             : <TYPE>0</TYPE><LEN>4</LEN><DATA>3030</DATA>
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.SBRG.EC0_.TH0R   :
_SB_.PCI0.SBRG.EC0_.TH1R   :
_SB_.PCI0.SBRG.EC0_.F0TS   :
_SB_.PCI0.SBRG.EC0_.F1TS   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
_SB_.PCI0.SBRG.EC0_.CUTP   :
_SB_.PCI0.SBRG.EC0_.PHTP   :
_SB_.PCI0.SBRG.EC0_.DIMT   :
_SB_.PCI0.SBRG.EC0_.INLE   :
_SB_.PCI0.SBRG.EC0_.PANT   :
_SB_.PCI0.SBRG.EC0_.F0RM   :
_SB_.PCI0.SBRG.EC0_.F0DT   :
_SB_.PCI0.SBRG.EC0_.F1RM   :
_SB_.PCI0.SBRG.EC0_.F1DT   :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
CPUT                       :
GPUT                       :
SYST                       :
FANT                       :
BATT                       :
------[ SMBus #0 ]------
SMBus Type  : Intel ICH
SMBus Port  : F000
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B00-D19 ]------
  0000  00 00 00 00 00 C1 1C 22 FF FF FF FF FF FF FF FF  ......."........
  0010  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0020  FF FF 00 FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0030  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0040  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0050  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0060  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0070  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0080  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0090  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0000  EF00 0000 0000 0000 0000 D4C1 681C 0122 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0010  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0020  FFFF FFFF 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0030  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0040  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0050  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0060  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0070  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0080  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0090  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00A0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00B0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00C0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00D0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00E0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00F0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ SMBus Device B00-D1B ]------
------[ SMBus Device B00-D2E ]------
  0000  00 00 00 00 1B 40 00 00 00 D0 9C 00 00 9D 3F 40  .....@........?@
  0010  FF FF FF F8 00 64 00 00 00 00 00 00 00 00 00 00  .....d..........
  0020  00 01 7F 00 07 03 03 03 00 04 EE 80 F4 32 40 00  ............2@.
  0030  55 00 55 00 55 00 55 00 55 00 64 64 64 64 64 FF  U.U.U.U.U.ddddd.
  0040  00 FF 00 FF 00 FF 00 CC CC FF FF FF F8 F8 F8 7F  ...............
  0050  3F 07 8F BF 3F 00 3F 00 00 00 00 00 00 00 03 00  ?...?.?.........
  0060  FF FF 7C 00 00 00 00 00 00 00 8C 8C 8C 02 0A 0A  ..|.............
  0070  7F 84 84 84 53 53 53 30 FF 00 80 00 00 FF FF FF  ...SSS0........
  0080  19 23 2D 37 3C 8C AA C8 E6 FF FF FF FF FF FF FF  .#-7<...........
  0090  19 23 2D 37 3C 8C AA C8 E6 FF FF FF FF FF FF FF  .#-7<...........
  00A0  19 23 2D 37 3C 8C AA C8 E6 FF FF FF FF FF FF FF  .#-7<...........
  00B0  00 00 00 00 00 00 00 00 00 00 FF FF FF FF 00 0B  ................
  00C0  00 3D 3D 3D 00 00 00 39 33 33 FF 00 00 00 40 00  .===...933....@.
  00D0  00 AA 0A 0A 0A 0A 02 F2 81 1E 00 18 07 41 7F 70  .............Ap
  00E0  E4 00 00 00 00 00 00 00 00 00 00 00 00 00 10 F0  ................
  00F0  00 30 00 FF 00 05 FF FF 00 08 0D 02 FF 50 C3 21  .0...........P.!
  0000  FF00 FF00 FF00 FF00 FF1B FF40 FF00 FF00 FF00 FFD0 FF9C FF00 FF00 FF9C FF3F FF40
  0010  FFFF FFFF FFFF FFF8 FF00 FF64 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0020  FF00 FF01 FF7F FF00 FF07 FF03 FF03 FF03 FF00 FF04 FFEE FF80 FFF4 FF32 FF40 FF00
  0030  FF55 FF00 FF55 FF00 FF55 FF00 FF55 FF00 FF55 FF00 FF64 FF64 FF64 FF64 FF64 FFFF
  0040  FF00 FFFF FF00 FFFF FF00 FFFF FF00 FFCC FFCC FFFF FFFF FFFF FFF8 FFF8 FFF8 FF7F
  0050  FF3F FF07 FF8F FFBF FF3F FF00 FF3F FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF03 FF00
  0060  FFFF FFFF FF7C FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF8C FF8C FF8C FF02 FF0A FF0A
  0070  FF7F FF84 FF84 FF84 FF53 FF53 FF53 FF30 FFFF FF00 FF80 FF00 FF00 FFFF FFFF FFFF
  0080  FF19 FF23 FF2D FF37 FF3C FF8C FFAA FFC8 FFE6 FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0090  FF19 FF23 FF2D FF37 FF3C FF8C FFAA FFC8 FFE6 FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00A0  FF19 FF23 FF2D FF37 FF3C FF8C FFAA FFC8 FFE6 FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00B0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FF00 FF0B
  00C0  FF00 FF3D FF3D FF3D FF00 FF00 FF00 FF39 FF33 FF33 FFFF FF00 FF00 FF00 FF40 FF00
  00D0  FF00 FFAA FF0A FF0A FF0A FF0A FF02 FFF2 FF81 FF1E FF00 FF18 FF07 FF41 FF7F FF70
  00E0  FFE4 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF10 FFF0
  00F0  FF00 FF30 FF00 FFFF FF00 FF05 FFFF FFFF FF00 FF08 FF03 FF04 FFFF FF50 FFC3 FF21
------[ SMBus Device B00-D2F ]------
  0000  00 00 00 00 1D 40 00 00 00 D2 97 00 A5 A4 8B 40  .....@.........@
  0060  FF FF 7F 00 00 00 00 00 00 00 8C 8C 8C 02 0A 0A  ...............
  00F0  00 30 00 FF 00 05 FF FF 00 08 19 01 FF 50 C3 21  .0...........P.!
  0000  FF00 FF00 FF00 FF00 FF1D FF40 FF00 FF00 FF00 FFD2 FF97 FF00 FFA5 FFA4 FF8B FF80
  0060  FFFF FFFF FF7F FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF8C FF8C FF8C FF02 FF0A FF0A
------[ SMBus Device B00-D30 ]------
  0000  8A 78 75 70 66 65 5D 1D 65 65 67 66 66 67 80 80  .xupfe].eegffg..
  0010  89 49 3F 33 5E 69 62 07 19 C7 46 77 40 FF FF 4D  .I?3^ib...Fw@..M
  0020  00 66 00 66 B0 A2 A0 0A FF FF 00 A1 00 00 00 40  .f.f...........@
  0030  00 00 00 00 80 EE EE 54 28 FF 08 04 1C 00 00 20  .......T(......
  0040  E2 2B 75 20 5E 26 28 14 90 94 EF 6C 6C 38 10 00  .+u ^&(....ll8..
  0050  E0 FF A8 90 A0 90 03 81 40 02 00 7D 1A 18 67 00  ........@..}..g.
  0060  C0 00 00 FF FF 00 99 00 DF 88 28 02 02 64 44 55  ..........(..dDU
  0070  03 70 71 FF AB 4B 02 54 00 89 96 08 00 00 00 00  .pq..K.T........
  0080  3C 07 00 52 49 00 00 00 01 04 FF FF 00 00 00 00  <..RI...........
  0090  00 00 00 00 00 00 00 00 D5 2C 00 00 00 00 FF FF  .........,......
  00A0  20 00 23 18 06 16 00 00 00 00 00 00 00 00 00 00   .#.............
  00B0  B8 A1 03 30 60 00 00 00 10 55 18 E8 D1 19 19 00  ...0`....U......
  00C0  00 C8 60 05 89 00 02 C0 05 D4 00 00 00 03 00 40  ..`............@
  00D0  0C AD 00 00 00 3F 00 C0 E4 0F 00 00 00 02 00 00  .....?..........
  00E0  00 00 00 82 7C 00 00 80 03 01 00 00 00 00 00 00  ....|...........
  00F0  00 00 00 00 00 00 00 00 00 00 03 4D 49 52 FF FF  ...........MIR..
  0000  788A 7578 7075 6670 6566 5D65 1D5D 651D 6565 6765 6667 6666 6766 8067 8080 8980
  0010  4989 3F49 333F 5E33 695E 6269 0762 1907 C719 46C7 7746 4077 FF40 FFFF 4DFF 004D
  0020  6600 0066 6600 B066 A2B0 A0A2 0AA0 FF0A FFFF 00FF A100 00A1 0000 0000 4000 0040
  0030  0000 0000 0000 8000 EE80 EEEE 54EE 2854 FF28 08FF 0408 1C04 001C 0000 2000 E220
  0040  2BE2 752B 2075 5E20 265E 2826 1428 9014 9490 EF94 6CEF 6C6C 386C 1038 0010 E000
  0050  FFE0 A8FF 90A8 A090 90A0 0390 8103 4081 0240 0002 7D00 1A7D 181A 6718 0067 C000
  0060  00C0 0000 FF00 FFFF 00FF 9900 0099 DF00 88DF 2888 0228 0202 6402 4464 5544 0355
  0070  7003 7170 FF71 ABFF 4BAB 024B 5402 0054 8900 9689 0896 0008 0000 0000 0000 3C00
  0080  073C 0007 5200 4952 0049 0000 0000 0100 0401 FF04 FFFF 00FF 0000 0000 0000 0000
  0090  0000 0000 0000 0000 0000 0000 0000 D500 2CD5 002C 0000 0000 0000 FF00 FFFF 20FF
  00A0  0020 2300 1823 0618 1606 0016 0000 0000 0000 0000 0000 0000 0000 0000 0000 B800
  00B0  A1B8 02A1 3002 6030 0060 0000 0000 1000 5510 1855 E818 D1E8 19D1 1919 0019 0000
  00C0  C800 60C8 0560 8905 0089 0400 C004 06C0 D205 00D2 0000 0000 0300 0003 4000 0C40
  00D0  AD0C 00AD 0000 0000 3F00 003F C000 E4C0 0FE4 000F 0000 0000 0200 0002 0000 0000
  00E0  0000 0000 8200 7C82 007C 0000 8000 0380 0103 0001 0000 0000 0000 0000 0000 0000
  00F0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0300 4D03 494D 5249 FF52 FFFF 8AFF
------[ SMBus Device B00-D31 ]------
  0000  FF 00 04 0B 01 FF FF FF FF FF FF FF FF FF FF FF  ................
  0020  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0050  FF FF FF FF FF FF FF FF FF FF 08 08 01 19 34 FF  ..............4.
  00F0  00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0000  FFFF FF00 FF04 FF0B FF01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0020  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0050  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FF08 FF08 FF01 FF19 FF34 FFFF
  00F0  FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ SMBus Device B00-D32 ]------
  0000  9D 74 79 6C 61 60 41 00 64 60 66 2D 29 2D 80 80  .tyla`A.d`f-)-..
  0010  76 65 62 4D 5C 5F 0B 07 1C C8 48 6C 40 FF FF 4D  vebM\_....Hl@..M
  0020  00 66 00 66 B0 A2 11 04 FF 33 00 00 00 00 00 45  .f.f.....3.....E
  0030  00 00 00 00 80 EE E8 7C 3E FF 00 04 1E 00 00 21  .......|>......!
  0040  9E 6B 86 20 21 26 A9 05 CC CF CF 20 4D 38 70 00  .k. !&..... M8p.
  0050  E0 FF A8 90 A0 90 E0 81 50 00 00 7D 1A 18 68 00  ........P..}..h.
  0060  80 00 80 FF FF 00 6A 00 DF 7B 28 42 01 63 41 53  ......j..{(B.cAS
  0070  03 70 71 FF 2B 4B 01 94 00 65 78 08 00 00 00 00  .pq.+K...ex.....
  0090  00 00 00 00 00 00 00 00 D5 FC 00 00 00 00 FF FF  ................
  00B0  00 00 01 30 60 00 00 00 10 51 00 00 00 19 19 00  ...0`....Q......
  00C0  00 C8 D7 05 86 00 00 C1 00 00 00 00 00 03 00 40  ...............@
  00E0  00 00 00 00 00 00 00 80 03 01 00 00 00 00 00 00  ................
  0000  749D 7974 6C79 616C 6061 4160 0041 6400 6064 6660 2D66 292D 2D29 802D 8080 7680
  0010  6576 6265 4D62 5C4D 5F5C 0B5F 070B 1C07 C81C 48C8 6C48 406C FF40 FFFF 4DFF 004D
  0020  6600 0066 6600 B066 A2B0 11A2 0411 FF04 33FF 0033 0000 0000 0000 0000 4500 0045
  0030  0000 0000 0000 8000 EE80 E8EE 7CE8 3E7C FF3E 00FF 0400 1E04 001E 0000 2100 9E21
  0040  6B9E 866B 2086 2120 2621 A926 05A9 CC05 CFCC CFCF 20CF 4D20 384D 7038 0070 E000
  0050  FFE0 A8FF 90A8 A090 90A0 E090 81E0 5081 0050 0000 7D00 1A7D 181A 6818 0068 8000
  0060  0080 8000 FF80 FFFF 00FF 6A00 006A DF00 7BDF 287B 4228 0142 6301 4163 5341 0353
  0070  7003 7170 FF71 2BFF 4B2B 014B 9401 0094 6500 7865 0878 0008 0000 0000 0000 3C00
  0090  0000 0000 0000 0000 0000 0000 0000 D500 FCD5 00FC 0000 0000 0000 FF00 FFFF 20FF
  00A0  0020 2300 1823 0618 1606 0016 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
  00B0  0000 0100 3001 6030 0060 0000 0000 1000 5110 0051 0000 0000 1900 1919 0019 0000
  00C0  C000 D7C8 05D7 8505 0084 0000 C100 00C1 0000 0000 0000 0000 0300 0003 4000 0C40
  00E0  0000 0000 0000 0000 0000 0000 8000 0380 0103 0001 0000 0000 0000 0000 0000 0000
  00F0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0300 4D03 494D 5249 FF52 FFFF 9DFF
------[ SMBus Device B00-D34 ]------
  0000  2B 19 1F 03 13 17 AC 60 63 57 91 66 66 45 FF FF  +......`cW.ffE..
  0010  22 22 80 32 0D 3C 1E C2 C9 00 00 00 00 00 00 00  "".2.<..........
  0020  00 00 50 60 20 0A FF 80 00 E0 DC A9 28 1D 18 25  ..P` .......(..%
  0030  49 0A 90 52 52 64 86 1E 00 E0 80 00 00 FF 00 00  I..RRd..........
  0040  1E 14 00 00 00 00 00 00 14 14 77 40 C0 80 80 FF  ..........w@....
  0050  FF 00 44 A7 55 F0 F0 17 02 02 62 00 21 03 03 28  ..D.U.....b.!..(
  0060  30 01 C2 01 A4 28 1E 77 80 00 E7 00 00 FD 06 FF  0....(.w........
  0070  FF 20 00 00 00 00 00 00 00 00 00 00 15 15 00 00  . ..............
  0080  00 00 00 00 00 00 00 00 88 89 01 C3 45 00 00 1F  ............E...
  0090  00 05 43 C2 C9 01 70 74 27 A7 B3 A0 00 00 1D 1D  ..C...pt'.......
  00A0  00 00 00 00 00 00 01 01 08 55 22 17 F9 00 00 04  .........U".....
  00B0  00 00 00 00 00 00 00 64 00 04 67 77 13 09 00 00  .......d..gw....
  00C0  00 00 00 6E 33 00 00 00 00 00 00 02 00 45 00 00  ...n3........E..
  00D0  00 00 AD 50 0C 00 10 00 3F 00 00 00 23 C0 F0 00  ...P....?...#...
  00E0  00 00 00 10 00 03 01 88 00 00 00 00 00 00 00 00  ................
  00F0  00 00 00 00 00 33 00 00 00 00 00 00 00 00 00 00  .....3..........
  0000  2B2B 1919 1F1F 0303 1313 1717 ACAC 6060 6363 5757 9191 6666 6666 4545 FFFF FFFF
  0010  2222 2222 8080 3232 0D0D 3C3C 1E1E C2C2 C9C9 0000 0000 0000 0000 0000 0000 0000
  0020  0000 0000 5050 6060 2020 0A0A FFFF 8080 0000 E0E0 DCDC A9A9 2828 1D1D 1818 2525
  0030  4949 0A0A 9090 5252 5252 6464 8686 1E1E 0000 E0E0 8080 0000 0000 FFFF 0000 0000
  0040  1E1E 1414 0000 0000 0000 0000 0000 0000 1414 1414 7777 4040 C0C0 8080 8080 FFFF
  0050  FFFF 0000 4444 A7A7 5555 F0F0 F0F0 1717 0202 0202 6262 0000 2121 0303 0303 2828
  0060  3030 0101 C2C2 0101 A4A4 2828 1E1E 7777 8080 0000 E7E7 0000 0000 FDFD 0606 FFFF
  0070  FFFF 2020 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 1515 1515 0000 0000
  0080  0000 0000 0000 0000 0000 0000 0000 0000 8888 8989 0101 C3C3 4545 0000 0000 1F1F
  0090  0000 0505 4343 C2C2 C9C9 0101 7070 7474 2727 A7A7 B3B3 A0A0 0000 0000 1D1D 1D1D
  00A0  0000 0000 0000 0000 0000 0000 0101 0101 0808 5555 2222 1717 F9F9 0000 0000 0404
  00B0  0000 0000 0000 0000 0000 0000 0000 6464 0000 0404 6767 7777 1212 0909 0000 0000
  00C0  0000 0000 0000 6E6E 3333 0000 0000 0000 0000 0000 0000 0202 0000 4545 0000 0000
  00D0  0000 0000 ADAD 5050 0C0C 0000 1010 0000 3F3F 0000 0000 0000 2323 C0C0 F0F0 0000
  00E0  0000 0000 0000 1010 0000 0303 0101 8888 0000 0000 0000 0000 0000 0000 0000 0000
  00F0  0000 0000 0000 0000 0000 3333 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
------[ SMBus Device B00-D35 ]------
  0000  FF 00 00 00 01 FF FF FF FF FF FF FF FF FF FF FF  ................
  0000  FFFF FF00 FF00 FF00 FF01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0000  00 00 00 04 00 00 00 00 00 25 14 04 05 09 06 16  .........%......
  0010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0000  FF00 FF00 FF00 FF04 FF00 FF00 FF00 FF00 FF00 FF26 FF14 FF04 FF05 FF09 FF06 FF16
  0010  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0020  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0030  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0040  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0050  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0060  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0070  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0080  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0090  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00A0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00B0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00C0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00D0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00E0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  00F0  FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00 FF00
  0000  23 11 0C 02 85 21 00 08 00 60 00 03 01 03 00 00  #....!...`......
  0010  00 00 08 0D F8 03 00 00 6E 6E 6E 11 08 76 F0 0A  ........nnn..v..
  0020  20 08 00 05 00 A8 1E 2B 2E 00 78 00 14 3C 00 00   ......+..x..<..
  0030  00 00 00 00 00 00 00 00 00 00 00 00 16 36 16 36  .............6.6
  0040  16 36 16 36 00 00 16 36 16 36 16 36 16 36 00 00  .6.6...6.6.6.6..
  0070  00 00 00 00 00 83 B5 CE 00 00 00 00 E7 C2 2D 24  ..............-$
  0080  11 11 20 00 00 00 00 00 00 00 00 00 00 00 00 00  .. .............
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 1C A0  ................
  0100  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0110  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0120  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0130  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0140  04 CD 00 00 00 00 00 00 00 46 34 2D 33 36 30 30  .........F4-3600
  0150  43 31 36 2D 38 47 54 5A 00 00 00 00 00 00 80 CE  C16-8GTZ........
  0160  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0170  00 00 00 00 00 00 00 00 00 00 00 00 00 00 8E CF  ................
  0180  0C 4A 17 20 00 00 00 00 00 A3 00 00 05 00 02 00  .J. ............
  0190  00 47 47 47 00 9F E6 F0 0A 20 08 00 05 00 C0 1C  .GGG..... ......
  01A0  28 00 00 00 00 00 00 00 00 00 00 91 FA FA FA BA  (...............
  01B0  00 00 00 00 00 00 00 00 94 00 00 05 00 01 00 00  ................
  01C0  48 48 48 0B 6F EF 00 A2 00 80 00 50 0C 01 C2 80  HHH.o......P....
  01D0  00 00 00 00 00 00 00 00 00 0C E0 00 00 0E 70 00  ..............p.
  01E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
------[ SMBus Device B00-D53 ]------
------[ SMBus Device B00-D57 ]------
  0000  5F 4D 41 43 00 1F BC 11 CA 18 56 13 FF FF FF FF  _MAC......V.....
  0100  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0110  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0120  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0130  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0140  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0150  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0160  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0170  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0180  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0190  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  01A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  01B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  01C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  01D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  01E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  01F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
------[ Chips Found ]------
B00-D2E: Nuvoton NCT7511Y/7802Y
B00-D2F: Nuvoton NCT7802Y
B00-D31: Fintek F72262
B00-D34: IRF IR3570B
B00-D35: Fintek F72262
SMBus Port  : F000
Can Have SPD: Yes
Scan Type   : Full
E-LEET screenshot:
Thank you, and yes, it's all fine so far. The problem is: the sensor solution is quite complex on this motherboard, so we need a bit more time to figure out everything. Please give us 2 or 3 more days to come up with a new AIDA64 beta ;)
Tried the new BETA.
Unfortunately, it does not show the correct VCore; 1.325 in BIOS set to Override (constant voltage, and C states are disabled), 1.136 in AIDA64.
Also, I am not sure if there are North Bridge and CPU VTT sensors, but both of those show 0.
Also, North Bridge and VRM temperatures show N/A. Again, not sure if those sensor are present.
Thanks
Tried the new BETA.
Thanks
Vcore in the BIOS Setup tends to be higher than under Windows, since in the BIOS Setup the CPU cannot go to low-power state by executing idle cycles. Make sure to compare Vcore readings in AIDA64 against E-LEET.
As for the other readings, only those readings are available on your motherboard that you can see on the Monitoring page of E-LEET. If you miss some readings, then please create a screen shot that shows AIDA64 Sensor page and the Monitoring page of E-LEET side-by-side, so we can compare every reading against a reference list of readings.
Yes, I understand. That is why I mention that I have the BIOS configured to disable all C-states, and the CPU voltage control set to 'Override' which forces a constant voltage that should never change.
I have asked eVGA if the missing sensors are, in fact, present on this motherboard, but have yet to receive a response.
Not really sure how to get the sensor page up?
There's a chance E-LEET reports CPU VID voltage as Vcore. Can you please check if CPU VID, as reported by AIDA64, matches the Vcore reading in E-LEET?
What I meant is: start AIDA64, go to its Computer / Sensor page, move AIDA64 window to the left side (left half) of the Windows Desktop. Then open E-LEET, go to its Monitoring page, move E-LEET window to the right side of the Windows Desktop, and then make a screen shot that would show all sensor readings both software in the same time, on a single shot.
Thank you. Please check if CPU VID, as reported by AIDA64 on the Computer / Overclock page matches CPU Vcore as measured by E-LEET. If it does, then we'll replace the Vcore reading by the CPU VID value.
Thank you. That's quite puzzling. Maybe we're using a different multiplier for Vcore calculation than what we should? Can you please create a screen shot with AIDA64 Sensor Page + E-LEET Monitoring page at a different Vcore setting in the BIOS Setup?
Thank you! The Vcore register of the sensor chip seems to be fixed, no matter what Vcore you use. I'm afraid we need more dumps from you to further investigate this issue -- I hope you don't mind ;) Please do the following:
1) Select a Vcore setting, note down the value that you've selected in the BIOS Setup. Also note down the Vcore reading that E-LEET shows. Then create a new ISA Sensor Dump and SMBus Dump (Full) dump.
2) Then select a different Vcore setting, note down the value that you've selected in the BIOS Setup. Also note down the Vcore reading that E-LEET shows. Then create a new ISA Sensor Dump and SMBus Dump (Full) dump.
Please compress those 4 dumps and attach the ZIP file to your post. If you prefer to send the files in email instead, please send me a private message.
Thank you in advance!
I wanted to thank you for updating AIDA64 for my motherboard.
I was looking at the Computer>Sensor page when I noticed a sensor named PCH 1.8V. But, there is no option to display that sensor in Sensor Panel.
Also, looking at the BIOS, i see the following voltages:
Core PLL
VSA
VCCPLL_OC
I am not sure if those BIOS voltages are able to be monitored, or if they are named something else in AIDA64?
Thanks again.
Core PLL
VSA
VCCPLL_OC
Thanks again.
We'll add PCH +1.8 V as a sensor item in the next AIDA64 beta update.
As for the other voltages, you're right, not all of them can be monitored. Only those can be monitored for sure that E-LEET can monitor, since it's the reference software made by the same guys who made your motherboard ;) The rest may or may not be monitored by the motherboard. Except for VSA which should be VCCSA, and it's already monitored by AIDA64.
An update, I believe there remains an issue with the VCore.
I was stress-testing with OCCT, running AIDA64 alongside ELEET:
About .05V difference.
Also, although I did not manage to capture it, I saw the VCore reading in AIDA64 hit 2.03 for an instant.
