Hello
I have skylake c236 motherboard + xeon processor + ECC UDIMM memory
I run "best practices analyzer" scan on hyper-v role on windows server 2012r2
And got error
Title:Use RAM that provides error correction
Severity Error
Problem: The RAM in use on this computer is not error-correcting (ECC) RAM.
Impact:Microsoft does not support  on computers without error-correcting RAM.
Then I tryed AIDA latest beta (from this topic https://forums.aida64.com/topic/3404-fixed-ecc-supported-but-disabled-skylake-imc/)
DMI
[ Memory Arrays / System Memory ]
   Memory Array Properties:
   Location   Motherboard
   Memory Array Function   System Memory
   Error Correction   Single-bit ECC
   Max. Memory Capacity   64 GB
   Memory Devices   4
[ Memory Devices / DIMM_A1 ]
   Memory Device Properties:
   Form Factor   DIMM
   Type   DDR4
   Type Detail   Synchronous
   Size   16 GB
   Max. Clock Speed   2133 MHz
   Current Clock Speed   2133 MHz
   Total Width   64-bit  (my note, this value must be 72-bit for ECC module)
   Data Width   64-bit
   Ranks   2
   SPD
 [ DIMM1: Samsung M391A2K43BB1-CPB ]
     Memory Module Properties:
   Module Name   Samsung M391A2K43BB1-CPB
   Serial Number   322136A0h (2687902002)
   Manufacture Date   Week 15 / 2016
   Module Size   16 GB (2 ranks, 16 banks)
   Module Type   Unbuffered DIMM
   Memory Type   DDR4 SDRAM
   Memory Speed   DDR4-2133 (1066 MHz)
   Module Width   72 bit
   Module Voltage   1.2 V
   Error Detection Method   ECC
   DRAM Manufacturer   Samsung
   DRAM Stepping   00h
   SDRAM Die Count   1
Chipset
 [ North Bridge: Intel Skylake-S WS IMC ]
      Error Correction:
   ECC   Supported, Enabled
   ChipKill ECC   Not Supported
   RAID   Not Supported
   ECC Scrubbing   Not Supported
Please answer, ECC is full enabled? Why windows server thinks it is not enabled?
Yes, it's fully enabled. It's most likely a bug in Windows Server that you need to report to Microsoft.
