pbcopter Posted September 7, 2016 Posted September 7, 2016 Malwarebytes flags file aida_icons10.dll as containing spyware.banker. I hope this is just a false positive. Also, just a question. Why has Aida64 almost doubled in size? Thank you. 1 Quote
Fiery Posted September 7, 2016 Posted September 7, 2016 Yes, it is a false positive. Just let it submit the file to Malwarebytes. AIDA64 files got considerably bigger because we're in the process of implementing DPI scaling (DPI awareness) in AIDA64. And it requires adding high-resolution versions of the existing graphical content (e.g. splash screen, report wizard theme image, About box logo, CPUID Panel background, icons, etc). And since we need to prepare AIDA64 to scale to 400% and even beyond that, we need to add quite large images to the resources of the main module (AIDA64.EXE) as well as to existing DLL resource modules. But don't worry, it doesn't mean AIDA64 would load those images to RAM all the time They are only used when such high DPI setting is actually in use, and even so only one of the high-resolution images is loaded, not all of them. Quote
pbcopter Posted September 7, 2016 Author Posted September 7, 2016 Fiery Thanks for the explanation. I wasn't worried about the size, just curious. Paul Quote
Mamed2 Posted September 28, 2016 Posted September 28, 2016 Did you include help file in this beta version cause now i dont have any help files for qm Quote
Fiery Posted September 29, 2016 Posted September 29, 2016 Did you include help file in this beta version cause now i dont have any help files for qm Yes, it should still be there. However, you may need to unblock access to the file by navigating to the installation folder of AIDA64, finding the AIDA64.CHM help file --> right-click context menu --> Properties --> Unblock (checkbox) --> OK. Quote
