fixed: Samsung 850 EVO SSD temps (Intel RST v15 issue)
Hi Fiery,
For some time now my 850 EVO temps are not being reported - could be a Asus Strix X99 Gaming MB firmware issue?
Thanks!
DJ
They should be reported. Can you see detailed SMART attributes info for your 850 Evo drive on the Storage / SMART page in AIDA64?
Hi Fiery,
No, only one of two Vertex SSDs shows, none of the four Samsung 850 EVOs do. ATA shows the same Vertex and the RAID set in an Areca PCI card, and Physical Drives shows the Areca RAID set and the two RAID volumes in the Intel on-board controller, one from two Vertex SSDs and the one from the four Samsung EVOs.
Thanks!
Do you have the two RAID related options in AIDA64 / main menu / File / Preferences / Stability both enabled?
Hi Fiery,
Yes, RAID member enumeration and RAID SMART Support are both checked. Also Low-level SMART. Currently running BIOS 1401 on the Strix MB.
Please right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> RAID Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Also right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> SMART Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
Finally, right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> Disk Controllers Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
Thank you.  That looks odd: somehow the Areca RAID driver reports 5 connected drives, and they're all 3 TB Seagate HDDs.  There seems to be no SSDs connected to the Areca RAID controller.  Maybe you've got more than one RAID arrays defined for the single Areca RAID controller?
No, that's correct. The Areca controller has 5 3TB HDs as a RAID 6 disk with 2 volumes defined in Windows. The four 850 EVO SSDs are connected to the Intel on-board SATA as RAID 10 with 1 volume in Windows, and the two OCZ Vertex also to the Intel SATA as RAID 0 with 3 volumes in Windows.
Please give us a few more days to dig down deeper. So far we've concluded that Intel changed something in their RST drivers between Version 13 and Version 15, that caused our existing RAID member enumeration code to stop working. We need to find out what we have to change to continue supporting the latest Intel RST driver generation.  I'll post a message into this topic once we have a fixed AIDA64 build that you can try ;)
Please sign in to comment
Sign In Now
