fixed: SMART data from Highpoint RocketRAID 2740
I see this info in a FAQ about reading smart data from raid cards.
"SMART information (including disk temperature measurement) for RAID array member drives can be displayed for 3ware, Areca, HighPoint RocketRAID 26xx, Intel, JMicron, and LSI MegaIDE RAID controllers. Other RAID controllers either do not have a driver that makes SMART readout possible, or they are not supported by AIDA64. Starting from AIDA64 v1.70, RAID SMART support is disabled by default. To enable SMART support for RAID arrays, you need to go to AIDA64 / main menu / File / Preferences / Stability, and enable the option "RAID SMART support" there. "
Would it be possible to add the Highpoint RocketRAID 27xx series to the supported cards? Other software (e.g. HWiNFO) is able to read this so it must be possilbe?
Please right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> RAID Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
Then right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> SMART Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
Also right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> Disk Controllers Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post.
Thank you. We will fix the issue in the next AIDA64 beta update due in a few days from now. I'll post a message into this topic once the new AIDA64 beta build is available for download.
