Fiery Posted February 15, 2017 Posted February 15, 2017 5 hours ago, Ivan79 said: All sensors are shown now. Thank you very much! Thank you for the feedback Quote
SEVEZ Posted February 26, 2017 Posted February 26, 2017 On 2/15/2017 at 9:55 AM, Fiery said: I'm afraid we still haven't found a way to get around the sensor communication issue affecting H270M Pro4 and Z270M Pro4 motherboards. It seems to be a hardware issue that may be possible to fix via a BIOS Update. We will only know for sure that the issue is fixed once ASRock starts offering its own monitoring utility (A-Tuning Utility) for these motherboards too. That utility is already available for other Z270 and H270 chipset based motherboards, but not for H270M Pro4 and Z270M Pro4. The A-tuning app for z270m Pro4 is out now, it shows voltages, temps and fans rpms. Now it's time for your move P.S. The A-tuning didn't require any bios update, btw Quote
Fiery Posted February 26, 2017 Posted February 26, 2017 6 minutes ago, SEVEZ said: The A-tuning app for z270m Pro4 is out now, it shows voltages, temps and fans rpms. Now it's time for your move P.S. The A-tuning didn't require any bios update, btw Please create an ISA Sensor Dump and also a Super I/O Dump before and after launching ASRock's A-Tuning Utility. Maybe it reconfigures the Super I/O chip in order to enable sensor readings. You can create those dumps by right-clicking on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump or Super I/O Dump. Copy-paste the full results into this topic, or attach the results as TXT files to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
SEVEZ Posted February 26, 2017 Posted February 26, 2017 7 hours ago, Fiery said: Please create an ISA Sensor Dump and also a Super I/O Dump before and after launching ASRock's A-Tuning Utility. Maybe it reconfigures the Super I/O chip in order to enable sensor readings. You can create those dumps by right-clicking on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump or Super I/O Dump. Copy-paste the full results into this topic, or attach the results as TXT files to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Compared two ISA dumps and they are identical. But there're some differences in Super IO dumps. asrock_z270m_pro4_after_atuning.txt asrock_z270m_pro4_before_atuning.txt asrock_z270m_pro4_after_atuning_superio_dump.txt asrock_z270m_pro4_before_atuning_superio_dump.txt Quote
Fiery Posted February 27, 2017 Posted February 27, 2017 On 2017. 02. 26. at 9:18 PM, SEVEZ said: Compared two ISA dumps and they are identical. But there're some differences in Super IO dumps. asrock_z270m_pro4_after_atuning.txt asrock_z270m_pro4_before_atuning.txt asrock_z270m_pro4_after_atuning_superio_dump.txt asrock_z270m_pro4_before_atuning_superio_dump.txt Thank you! I've sent you an email about this issue. Quote
Fiery Posted March 7, 2017 Posted March 7, 2017 We've implemented sensor support for ASRock H270M Performance, H270M Pro4 and Z270M Pro4 motherboards in the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Quote
free0704 Posted March 7, 2017 Posted March 7, 2017 Asrock b250m pro4 sensors in the new version are not yet displayed. Chip Nuvoton NCT6683D-T. Quote
Fiery Posted March 9, 2017 Posted March 9, 2017 On 2017. 03. 07. at 9:47 PM, free0704 said: Asrock b250m pro4 sensors in the new version are not yet displayed. Chip Nuvoton NCT6683D-T. Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Make sure to use the latest AIDA64 beta build v5.80.4093: https://www.aida64.com/downloads/latesta64xebeta Quote
free0704 Posted March 9, 2017 Posted March 9, 2017 On 08.02.2017 at 7:55 PM, Fiery said: Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Make sure to use the latest AIDA64 beta build v5.80.4093: isasensordump.txt superiodump.txt Quote
Fiery Posted March 9, 2017 Posted March 9, 2017 14 minutes ago, free0704 said: isasensordump.txt superiodump.txt Thank you! The issue will be fixed in the next AIDA64 beta update due next week. I'll post a message into this topic once the new beta is available for download. Quote
Fiery Posted March 14, 2017 Posted March 14, 2017 The mentioned new AIDA64 beta update is now available for download at: https://www.aida64.com/downloads/latesta64xebeta Quote
