Nereus Posted May 7, 2017 Posted May 7, 2017 Pretty much as the title says, when adding a sensor/simple sensor fan speed, I would love to have an additional input field to manually enter the fan's known max rpm, so that the display can then give fan speed as a % rather than just rpm. Thanks. Quote
Fiery Posted May 8, 2017 Posted May 8, 2017 I'm afraid we don't have plans to enable such deep customization of sensor readouts. However, you can use the Correction feature (AIDA64 / main menu / File / Preferences / Hardware Monitoring / Correction) to scale the RPM values down to a 0 to 100 range, in order to convert the RPM readings into percentage values. Quote
Nereus Posted May 31, 2017 Author Posted May 31, 2017 Thanks very much, the correction is exactly what I needed - it was for the fan speed values: Quote
