Grestorn Posted June 17, 2017 Posted June 17, 2017 I know this has been an issue many times already, but I'd like to bring it up again, sorry for that. I know that setting the update frequency to a low value doesn't do any good if the update cycle of all sensor data is taking longer than the update frequency. I tried to speed up the cycle by disabling everything but "Load kernel driver" in the Stability tab. Still, the update is at best about once a second. Some values (like volume) even much lower. Isn't there any way to speed this up?  Quote
Fiery Posted June 19, 2017 Posted June 19, 2017 In the state where you've disabled all the unnecesary modules (in Preferences / Stability), please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> Sensor Profiling Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. We need to see that to find out which sensor module causes the delays on your particular configuration. Thanks, Fiery Quote
Grestorn Posted June 19, 2017 Author Posted June 19, 2017 Hi Fiery, I didn't know about that function. You learn something new every day... So, in my case it's the aquearo that takes almost all of the time. Is that a technical neccessity or something that could be optimized, either on your side or on the side of AquaComputer? Thanks! ------[ Versions ]------ Program Version : AIDA64 Extreme v5.90.4251 Beta BenchDLL Version: 4.3.741-x64 Windows Version : Microsoft Windows 10 Pro 10.0.15063.413 (64-bit) ------[ Motherboard Info ]------ Motherboard ID    : <DMI> Motherboard Model  : Asus Rampage V Extreme Motherboard Chipset : Intel Wellsburg X99, Intel Haswell-E DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product    : RAMPAGE V EXTREME DMI MB Version    : Rev 1.xx DMI MB Serial    : 140830368100543 DMI SYS Manufacturer: ASUS DMI SYS Product   : All Series DMI SYS Version   : System Version DMI SYS Serial    : System Serial Number DMI BIOS Version   : 3402 ------[ Video Adapters ]------ nVIDIA GeForce GTX 1080 Ti Founders Edition (PG611) [10DE-1B06 / 10DE-120F] ------[ Video Driver ]------ nvapi.dll: 22.21.13.8253 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumdx.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll|||C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_2d81f3535ced17c6\nvldumd.dll ------[ Sensor Profiling (Init) ]------ SensorInfo     : 1163.095 ms GPUSensorInfo   :  10.895 ms GPU01 / NV Diode  :   0.003 ms GPU01 / NV Fan PWM:   0.000 ms HDD        :   0.001 ms SPD        :   1.008 ms AMB        :   0.002 ms Asus EPU2     :   0.000 ms Asus EPU1     :   0.000 ms nVIDIA SPP     :   0.000 ms nVIDIA MCP     :   0.000 ms Intel GMCH     :   0.000 ms Intel PCH     :   0.003 ms Intel SNB     :   0.025 ms Zambezi      :   0.000 ms Kaveri       :   0.000 ms Zen        :   0.000 ms AMD SVI2      :   0.000 ms MTC0303      :   0.000 ms Smart Battery   :   0.000 ms Kraken X52     :   0.000 ms LM78        :  81.617 ms TT DPS       :  19.547 ms Digifanless    :   0.000 ms Corsair RMi    :   0.000 ms Corsair AXi    :   0.000 ms Odin        :   0.000 ms Aquaero      :  993.738 ms ------[ Sensor Profiling (Last) ]------ SensorInfo     :  991.506 ms GPUSensorInfo   :  14.261 ms GPU01 / NV Diode  :   0.005 ms GPU01 / NV Fan PWM:   0.000 ms HDD        :   0.001 ms SPD        :   1.473 ms AMB        :   0.002 ms Asus EPU2     :   0.000 ms Asus EPU1     :   0.000 ms nVIDIA SPP     :   0.000 ms nVIDIA MCP     :   0.001 ms Intel GMCH     :   0.000 ms Intel PCH     :   0.005 ms Intel SNB     :   0.033 ms Zambezi      :   0.000 ms Kaveri       :   0.000 ms Zen        :   0.001 ms AMD SVI2      :   0.000 ms MTC0303      :   0.000 ms Smart Battery   :   0.000 ms Kraken X52     :   0.000 ms LM78        :  81.374 ms TT DPS       :  81.047 ms Digifanless    :   0.000 ms Corsair RMi    :   0.000 ms Corsair AXi    :   0.000 ms Odin        :   0.000 ms Aquaero      :  756.723 ms  Quote
Fiery Posted June 23, 2017 Posted June 23, 2017 Thank you. Sadly, Aquaero uses a slow USB protocol, and there's nothing we can do to get around that limitation Quote
