When aida64 is running, my razer chroma keyboard and mouse lose their lighting,  If I stop Aida64, the lights come back on.
I assume that the constant polling of the kn/usb/mouse port settings is what is killing it.
This always was a bit problematic, but since taking the Win10 Creators update sunday, it is consistent and reproducible.
Any way or something you can look at?
Do you have RGB LED support enabled in AIDA64 / main menu / File / Preferences / Hardware Monitoring / RGB LED, or Razer LCD support enabled in AIDA64 / main menu / File / Preferences / Hardware Monitoring / LCD / Razer?
i do have rgb led support on
I have razer support turned off.
Should they both be off to enable standard razer lighting?
edit - tried turning both off, lights go off when aida64 starts
edit-edit  It is all set.  The turning off did not take effect.  Forgot apply.  Restart aida64, working fine
