korhanby Posted October 23, 2017 Posted October 23, 2017 Hello to all of you, I can't see my fan speeds, water pump speed and voltage values in AIDA64. My motherboard is asus tuf x299 mark 1. Is there any possible way that i can see these values. I am waiting your helps thank you. Quote
korhanby Posted October 23, 2017 Author Posted October 23, 2017 And here are the debug info, All the missing values are however shown in debug info. The debug file is generated using "aida64extreme_build_4376_hj2g9dwprb" beta version. debug_info_tuf_x299_mark_1.txt Quote
Fiery Posted October 25, 2017 Posted October 25, 2017 Thank you. We'll implement advanced support for your motherboard in the next AIDA64 beta update due in a few days from now. I'll post a message into this topic once the new AIDA64 beta build is available for download. Quote
korhanby Posted October 25, 2017 Author Posted October 25, 2017 Thank you Fiery. I am waiting for the new beta release. Quote
Fiery Posted October 27, 2017 Posted October 27, 2017 On 2017. 10. 25. at 11:36 AM, korhanby said: Thank you Fiery. I am waiting for the new beta release. The above mentioned new AIDA64 beta build is now available for download: https://www.aida64.com/downloads/latesta64xebeta Quote
korhanby Posted October 29, 2017 Author Posted October 29, 2017 On 27.10.2017 at 7:47 PM, Fiery said: The above mentioned new AIDA64 beta build is now available for download: https://www.aida64.com/downloads/latesta64xebeta Hello Fiery, thank you for the download. There are two strange things. Firstly, some temperature values sometimes shown and sometimes they get disappear or N/A. Another thing is, the fan control section in AI Suite is very laggy when AIDA 64 runs in the background. Also, CPU package temperature in AIDA64 has +5 degree celcius offset. I don't know why this is happening. Thank you. I am again sending the debug info. debug_info_new.txt Quote
Fiery Posted October 30, 2017 Posted October 30, 2017 On 2017. 10. 29. at 10:58 AM, korhanby said: Hello Fiery, thank you for the download. There are two strange things. Firstly, some temperature values sometimes shown and sometimes they get disappear or N/A. Another thing is, the fan control section in AI Suite is very laggy when AIDA 64 runs in the background. Also, CPU package temperature in AIDA64 has +5 degree celcius offset. I don't know why this is happening. Thank you. I am again sending the debug info. debug_info_new.txt Thank you for your feedback! AI Suite can indeed collide with other software that also polls the EC (Embedded Controller) chip for sensor registers. Sadly, Asus still haven't made any steps to synchronize AI Suite or other software of theirs with 3rd party monitoring applications. Other than uninstalling AI Suite and all its background services there's no solution to this issue I'm afraid. As for CPU Package, there's no offset to use on any processors, as far as we know. So AIDA64 should report the accurate readout as it is provided by the CPU. If you however are adamant that there's an offset to be applied, then you can configure it in AIDA64 / main menu / File / Preferences / Hardware Monitoring / Correction. Quote
