Villager4 Posted December 17, 2017 Share Posted December 17, 2017 I recently installed AIDA64 Extreme so I could perform a system stability test and monitor my temperatures. However, my CPU temperatures are not showing up in the program. I checked to make sure I was running the latest version, and rebooted my system afterward, but still no temps. Is this a bug or am I missing something? Quote Link to comment Share on other sites More sharing options...
Fiery Posted December 17, 2017 Share Posted December 17, 2017 1) Does your Windows user have administrator privileges? 2) Are you sure AIDA64 is properly installed? Check if all its necessary files are in the same installation folder than AIDA64.EXE (main executable binary). At the bare minimum you need KERNELD.X64 and AIDA64.DAT files for AIDA64 to operate properly. Quote Link to comment Share on other sites More sharing options...
bbeck500 Posted April 9, 2022 Share Posted April 9, 2022 I have the same issue. Have GPU temps but no cpu temps. Running Win 11 Pro and a Gen 12 i7. Aida64Ex came with my 7 inch Lampteon HMO70 sensor screen Quote Link to comment Share on other sites More sharing options...
DJSTRAUSS Posted December 31, 2022 Share Posted December 31, 2022 Same here pics up GPU Temps not CPU on a custom loop. Ryzen 5950x. Anyone solved this? Quote Link to comment Share on other sites More sharing options...
Trace_ZEN Posted January 11, 2023 Share Posted January 11, 2023 Same issue. No motherboard/CPU sensor temps or fans. PC is waterblocked CPU/VRM + GPU . Sensors were good w/ the out-of-the-box BIOS, but I am now 4 updates past that and am otherwise stable. HWInfo and SIV64X both see everything CPU/mobo AIDA is missing. Was hoping for monitoring on a 7" screen. Any advice is appreciated! Sensor Properties Sensor Type CPU, HDD, Bixby, Zen GPU Sensor Type Driver (NV-DRV) Temperatures GPU 32 °C GPU Hotspot 38 °C GPU Memory 38 °C Sabrent Rocket 4.0 1TB (DF3907150B1A00001239) 40 °C Sabrent Rocket 4.0 1TB (7CB407150CFB00000541) 44 °C ST2000DM008-2FR102 43 °C Sabrent Rocket 4.0 500GB 42 °C HGST HUS724040ALE640 48 °C Cooling Fans GPU 0 RPM GPU2 0 RPM Voltage Values CPU VDD 3.150 V CPU VDDNB 3.150 V GPU Core 0.762 V Current Values CPU VDD 0.00 A CPU VDDNB 0.00 A Power Values CPU VDD 0.00 W CPU VDDNB 0.00 W GPU 33.97 W GPU TDP% 10% 0 ------[ Motherboard Info ]------ Motherboard ID : <DMI> Motherboard Model : Asus ROG Crosshair VIII Hero (Wi-Fi) Motherboard Chipset : AMD Bixby X570, AMD K19.2 FCH, AMD K19.2 IMC DMI MB Manufacturer : ASUSTeK COMPUTER INC. DMI MB Product : ROG CROSSHAIR VIII HERO (WI-FI) DMI MB Version : Rev X.0x DMI MB Serial : 211093347100524 DMI SYS Manufacturer: ASUS DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 4304 ------[ PCI Devices ]------ ITE SuperIO Port = 00h ITE SuperIO HWMonitor Port = 0000h ( 0000h / 0000h) ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h) ITE SuperIO Device ID = 0000h ( 0000h / 0000h) ITE SuperIO Version = 00h ( 00h / 00h) Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port/60 = 0000h (0000h / 0000h) Winbond SuperIO HWMonitor Port/64 = 0000h (0000h / 0000h) Winbond SuperIO Device ID = 0000h (0000h / 0000h) Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h (0000h / 0000h) Fintek SuperIO Device ID = 0000h (0000h / 0000h) SMSC SuperIO Port = 00h SMSC SuperIO HWMonitor Port = 0000h (0000h / 0000h) SMSC SuperIO Device ID = 0000h (0000h / 0000h) ASpeed SuperIO Port = 00h ------[ K15.6/K15.7/K16.6/K17/K17.1/K17.2/K17.3/K17.5/K17.6/17.7/K18/K19.2/K19.4/K19.5/K21 PM2 at 0CD0 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ K15.6/K15.7/K16.6/K17/K17.1/K17.2/K17.3/K17.5/K17.6/17.7/K18/K19.2/K19.4/K19.5/K21 PM at 0CD6 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.SBRG.EC0_.TH0R : _SB_.PCI0.SBRG.EC0_.TH1R : _SB_.PCI0.SBRG.EC0_.F0TS : _SB_.PCI0.SBRG.EC0_.F1TS : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : _SB_.PCI0.LPCB.EC0_.OTPC : _SB_.PCI0.LPCB.EC0_.VGAT : _SB_.PCI0.LPCB.EC0_.CHPT : _SB_.PCI0.LPCB.EC0_.CPUT : _SB_.PCI0.LPCB.EC0_.SYST : _SB_.PCI0.LPCB.EC0_.DTS1 : _SB_.PCI0.LPCB.EC0_.DTS2 : _SB_.PCI0.LPCB.EC0_.DIMM : _SB_.PCI0.LPCB.EC0_.FANH : _SB_.PCI0.LPCB.EC0_.FANL : _SB_.PCI0.LPCB.EC0_.CUTP : _SB_.PCI0.LPCB.EC0_.PHTP : _SB_.PCI0.LPCB.EC0_.DIMT : _SB_.PCI0.LPCB.EC0_.INLE : _SB_.PCI0.LPCB.EC0_.PANT : _SB_.PCI0.LPCB.EC0_.F0RM : _SB_.PCI0.LPCB.EC0_.F0DT : _SB_.PCI0.LPCB.EC0_.F1RM : _SB_.PCI0.LPCB.EC0_.F1DT : _SB_.PCI0.SBRG.EC0_.CUTP : _SB_.PCI0.SBRG.EC0_.PHTP : _SB_.PCI0.SBRG.EC0_.DIMT : _SB_.PCI0.SBRG.EC0_.INLE : _SB_.PCI0.SBRG.EC0_.PANT : _SB_.PCI0.SBRG.EC0_.F0RM : _SB_.PCI0.SBRG.EC0_.F0DT : _SB_.PCI0.SBRG.EC0_.F1RM : _SB_.PCI0.SBRG.EC0_.F1DT : _SB_.SAMB.TMPC : _SB_.SAMB.TMPH : _SB_.STR0._TMP : _SB_.STR1._TMP : _SB_.STR2._TMP : _SB_.STR3._TMP : _SB_.STR4._TMP : _SB_.STR5._TMP : _SB_.STR6._TMP : _SB_.STR7._TMP : CPUT : GPUT : SYST : FANT : BATT : ========================================================================== ------[ 0 SMBuses detected ]------ Quote Link to comment Share on other sites More sharing options...
KC8DKT Posted June 2, 2023 Share Posted June 2, 2023 (edited) MSI MAG X670E Tomahawk with a 7800X3D Same for me, no CPU temps but ram and video card temps show up fine. This was for my Old build and was just getting started on redoing it for the new system but cannot get the CPU temps to show. Edited June 2, 2023 by KC8DKT added board info Quote Link to comment Share on other sites More sharing options...
