EVGA CLC 280 (Asetek) Fan Speed missing
Not sure when this changed but the fan speed for the Asetek EVGA CLC 280 AIO has now disappeared from the sensor list.
I checked EVGA flowcontrol software and the pump/fans are reecognised and reporting correctly.
OK, I figured out the problem. When EVGA software is set to auto for the fans, aidia64 sets the fan to 0rpm unless I check the tick boxes for Asetek fan control in the hardware monitoring preferences. I am not entirely sure what is going on here.
That's normal. Some Asetek based liquid coolers require manual fan setting in AIDA64 Preferences in order to work properly.
